Question about Canon MX300 Office All-In-One Printer
Print cartridge has been changed but error message persists and alarm light is on with a message, "check ink" U163
    President:
  • 787 Answers
Try to press and hold the 'Reset' button down for 5 seconds.
Posted on Oct 06, 2009
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
While faxing...I encountered an error message ...the alarm light is on and the Error message states Check Ink U163. PLEASE HELP
Press and Hold the STOP/RESET button and wait until it self restart.
Release the STOP/RESET button when the printer is restarting
Aug 31, 2010 | Canon PIXMA MX310 All-In-One Printer
Check ink u163 col-on lcd screen. the printer is not respond toany mode
The Error CHECK INK U163
Action : Ink has run out/
Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing , press the Stop/Reset button for atleast 5 seconds with the ink cartridge installed. Then printing can be continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Hope this helps.
Thanks.
Have a good day.
Dec 03, 2009 | Canon PIXMA MX310 All-In-One Printer
My canon pixma 180 has orange alarm light and reads check ink cartridge,. it won't print. it printed yesterday.
One or both print cartridges are defective.Look under the "check ink" what message come.If it's BLK change black cartridge, if it's CLR change the color cartridge.If BLK and CLR change both cartridges.
Nov 05, 2009 | Canon PIXMA MP180 All-In-One InkJet...
I am getting a U163 check ink error, I just installed a new b&W cartridge but color cartridge is empty but still in printer.
Replace the ink
cartridge(s), or press the
OK button.
When selecting to press
the OK button, ink may
run out during printing.
Oct 11, 2009 | Canon MX300 Office All-In-One Printer
CAnon MX310 alarm CHeck ink U163
when the U163 error appear
try to press and hold the STOP/RESET button and wait for a couple of seconds until it self-restart.
then try to print again.
Aug 05, 2009 | Canon MX310 Office All-In-One Printer
Check ink u163 error message
Firstly I suspect you are not using genuine cartridge or you have refilled the cartridge.
To fix this you need to disable the ink checking procedure.
Do you know that low ink or ink has run out message appears once cartridge empty. If you want to use refill ink in that cartridge then you need to deactivate ink level to get your printer run as usual. Check the following tips to fix low ink error message in case of refill ink usage. Below some methods to deactivate ink level detection function for some models due to its similarity.
METHOD I:
Press RESUME/CANCEL button once
Related models:
BJC series: bjc3000,8200,etcS series: s400,600,800,6300,9000etc
i Series: i255,320,350,355,450,470d,550,560,850,950,6100,6500,9100,etc
Pixma series: ip1000,1200,1300,1500,1600,1700,2000,2200,3000,4000,etc
METHOD II:
Hold down RESUME/CANCEL button for 5 seconds or more
Related models:
Latest models of Pixma series: ip1880,1980,3300,3500,4200,4500,5200,6700d,pro9000,9500,ix4000,5000,etc
METHOD III:
Press START button once, select COLOR button for colour cartridge; BLACK button for black cartridge
Applicable models:
Pixma MP150,160,170,180,450,460,475,etc
METHOD IV:
Hold down STOP/RESET button for 5 seconds or more
Applicable models:
Latest models of Pixma MP/MX series: MP145,228,245,520,800,850,970,MX308,318,7600,et
Jun 21, 2009 | Canon MX300 Office All-In-One Printer
MX310 error code U163
Can you tell me, have you replaced the empty tank with a full one? And, have you manually reset the ink level function by pressing Stop/Reset for a full 6 seconds (one second longer than described in your manual?)
If you have, and you still see the ink cartridge light flashing, does it flash every second or every three seconds?
The contacts for the ink cartridge are easy to contaminate by accident. Sometimes wiping the contacts off with alcohol will clean them enough for the ink level to be recognized.
Now, and yes, this is a common problem. Press and Hold the Stop/Reset button for 6 full seconds again after cleaning the contacts and then release it? Use the one Mississippi method of counting.
The Scan cover must be closed completely and locked in place. And the ink cartridge must be firmly locked in place as well.
Please advise me of your results. There may be a more complex problem involved and it is important to have the necessary data in order to get you back to working again. Okay?
How long has it been since you purchased this printer?
Regards,
Worldvet
Oct 15, 2008 | Canon PIXMA MX310 All-In-One Printer
Pixma mx310: error message check ink u163 will not delete after replacing colour inkn cartridge cl 41. unable to use printer.
Ink has run out. Replace the ink cartridge and close the Scanning Unit (Printer Cover). If printing is in progress and you want to continue printing,press the Stop/Reset button for at least 5 seconds with the inkcartridge installed. Then printing can continue under the ink outcondition. The function for detecting the remaining ink level will be disabled. Replace the empty ink cartridge immediately after the printing.The resulting print quality is not satisfactory, if printing iscontinued under the ink out condition.
Thanks for using Fixya
source : http://support-au.canon.com.au/contents/AU/EN/8200172900.html#6
SAM ANDERSON
Sep 26, 2008 | Canon Office Equipment & Supplies
Canon MX300 Office All-In-One Printer Logo
239 people viewed this question
old marine
old marine
