Question about Campbell Hausfeld MIG / Flux Core Wire Feed Welder
Wire won't feed - Campbell Hausfeld MIG / Flux Core Wire Feed Welder
    President:
  • 1,865 Answers
If the feed motor is not turning, then you'll need to have the unit tested by a repairman to find out why it isn't turning
Posted on Oct 06, 2009
I have a craftsman 20511 mig welder it will start welding without pushing trigger
Elmer, If you remove the gun assembly from the machine, if the machine is now not feeding wire, the problem is most likely the gun trigger is faulty. The switch contacts heat up and start sticking over time. If able too disassemble and clean trigger contacts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 934 205111 Operator Manual
commin problem with wire feed welder
Wire won stop feeding
May 02, 2016 | Craftsman Welding Tools
1993 BMW E36 325i odometer and clock won't turn off and kills my battery
fit a battery isolator inside the car under the dash on the battery earth is the cheapest soloution.Or a wiring diagram to trace the wires to locate the fault which i suspect could be on the radio wiring where 2 feeds are used one a permanant 12v feed and one a switchable feed via ignition switch causing a backfeed if done wrong .
Sep 22, 2012 | BMW X3 Series Cars & Trucks
My trigger to my millermatic 250 won't stop feeding the wire even when switch is not pressed
Does it feed with the trigger plug removed from the machine? If so, then it is a circuit board. If no, then wires shorted somewhere in the gun.
Apr 17, 2012 | Miller Welding Tools
I have a kymco agility 50 and it won't start. It has no power what so ever, the starter won't turn over and the break light won't light when I pull the break. I checked the kill switch.
Check with a multi tester for voltage coming through the ignition switch lead wires + to switch wire - to ground you shoul get 12volt or higher, with the switch off you should have one live (feed from battery ), on you should have 2 or 3 in and out feed (possibly 2 out one for ignition one for light curuit), or disconnect the switch and check for continuity (12v battery wire and a bulb if you dont have a multi tester between each pin on the switch plug when turned on you should get a curcuit when on.
Jan 27, 2012 | 2006 Kymco Agility 50
Century wire feed welder 83105 manual wire won't feed
check to ensure you have the right wire size.
check the tension adjuster.
replace liner
Oct 04, 2011 | Century Welding Tools
The battery has tested fine, the alternator is fine. But it won't start or hold a charge.
REPLACE POSITIVE BATTERY CABLE.CHECK ALTERNATOR FUSE AND CHECK ALTERNATOR VOLTAGE REGULATOR WIRES FOR DAMAGE.HOOK VOLT METER TO BATTERY FEED WIRE MAKE SURE 12 VOLTS GETTING TO ALTERNATOR FEED WIRE TO ALTERNATOR POSITIVE HOOK UP IF NOT YOU HAVE BLOWED FUSE TO WIRE FEEDING ALTERNATOR COULD HAVE FAULTY BATTERY POSITIVE CABLE OR CABLES CORRODED NEED CLEANING.
Aug 27, 2011 | 2005 Ford Ranger
Electrolux induction cooktop -power is on- comes up woth E8 message -elements won't go
Hi
You will most likely find this is an electrical installation wiring problem. The cooktop is designed to accept either single phase or 2-phase supply
If single phase the two feed wires must be linked.
The two feed wires are brown and black
The neutral is blue and earth is green
Most likely the electrician has got this wrong and assumed black is neutral
good luck
Jul 09, 2011 | Kitchen Ranges
Hello, I have a Hobart 180 and the wire feeder motor won't run. I replaced the wire feed motor and it still won't run. any ideas?
Sound like you have a bad trigger on the gun. Does gas spray when you pull the trigger? Check the wire plug that goes from the pistol to the unit. It should be under the liner hose where it connects to the machine. Then use a voltage meter on the wires going to the drive feed motor, and see if you get current when you pull the trigger. If gas doesn't spray neither, sounds like you got a bad trigger switch
Jun 27, 2011 | Hobart Welding Tools
Need to hook 230 volts to car lift
this is 2 ---110 volt power feed lines & a neutral ( ground ) 3 wires all together , a second redundent ground won't hurt -----the same power feed as a stove or dryer .make sure to use at least 10 -- 8 gauge stranded wire / check the product requirements ---thicker wire ( smaller gauge number ) for more amprage or loner distance...will also need two 15--30 amp circuit breakers///// check specs......
May 26, 2011 | Air Tools & Compressors
Campbell Hausfeld MIG / Flux Core Wire Feed Welder Logo
344 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
rjivaro
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
