Question about Napa DTS-751 5.1 Channel Speaker System
Zoostorm subwoofer speaker system for zoostorm computer
Hi
I am a novice with computers so my son put everything together and everything works fine except for the zoostorm subwoofer speaker system. When playing music or a DVD the people speaking sound muffled as it they were in a room far away. When trying to listen to a music cd the singers sound as if they are in an empty room as if they echo.
Can any one please help me with this problem.
Thanks
Carolyn
Zoostorm
plz go to device manager in control panel and reinstall the sound card....just delete the sound card and refresh may be it will ask for driver so put the cd in the drive which comes with the computer..hope solve ur problem
May 15, 2014 | Computers & Internet
Bose acoustimass 15 no sound out of left and right speaker
The left and right front speakers may have been blown
Jan 28, 2013 | Bose Acoustimass 15 System
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
My logitech z 2300 subwoofer is not producing sound
Since this set is hardwired together and the other speakers are working, the only easy fix would be the subwoofer got turned down on the remote volume control. Anything more would mean its broken. If its under warranty take it back. If its not and you know somebody capable, you might have them check for the obvious,bad solder connections on speaker, or and open voice coil on the speaker it self.
Aug 26, 2009 | Logitech Z-2300 Computer Speakers
Strange problems with Z-2300's
I'm having this same problem and have sort of solved it with a really wierd technique I found at Logitech. Evidently this problem is related to the control pod rather then the RCA jack. Try this:
Unplug the control pod from the subwoofer Turn off the main switch Turn the volume knob one full turn, tap the knob Repeat again (2 times) Replug the control pod Turn on the main switch and the control pod See what happens
I found that this got the speaker working finicky after it was almost totally useless. It seems to be cutting out randomly, but fidgeting with the control pod or it's connector jack fixes it. No clue what the deal is here, but your problem is identical to mine so take some time to screw around with these components with music running so you can hear if it suddenly works.
Nov 12, 2008 | Logitech Z-2300 Computer Speakers
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Z5300e Subwoofer Problem.
in my view, it is due to any of the following
1. its fuse burnout or wire breaked, check fuse and cordwire
2. its subwoofer coil is damaged to loud volume, replace it
3. its amplifier IC is damaged, replace IC
Dec 31, 2007 | Logitech Z-5300 Computer Speakers
AVS500 altec lansing computer speaker system powered subwoofer
Its due to your speaker power supply failure or switch! get them checked your speakers will be ready!
Nov 02, 2007 | Altec Lansing 621 Computer Speakers
Not all speakers working
Suggest that you download the latest Logitech drivers for your sound system.
Jun 10, 2007 | Logitech X-530 Computer Speakers
Napa DTS-751 5.1 Channel Speaker System Logo
112 people viewed this question
Top Napa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Napa Audio Player and Recorder Expert? Answer questions, earn points and help others
