Dlink router setup, no internet connection?
I got this router today, followed the setup instruction, got the DSL modem and router connected. but I just cannot reach any website, please help!
  • 2,260 Answers
You will need to check the settings of your router.
or you will need to set up your router with th DSL connection.
It is very simple.
Click Here for More info
Posted on Oct 07, 2009
  • Prashant M
    Prashant M Dec 05, 2009
    Click Here for Easy Set up Guide for step by step instructions.
    It will guide you with simple steps to resolve the problem in your network.
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
I have Dlink 2750u modem *** router. I am switching on Hathway ISP. They give DSL connection modem. How to use Dlink 2750?
Use an Ethernet cable to connect from the port on the DSL modem to the WAN/Internet port on the D-Link modem.
Apr 23, 2014 | D-Link Computers & Internet
I have configured my d link router and able to connect it with my win xp laptop and after i connect internet cable to the wireless router i am unable to access the internet through my win xp and win 7...
If initially the Win XP laptop was connected to internet at the cable/dsl modem, its MAC address would have been registered on service setup. If the router is now in place between the Win XP laptop and the cable/dsl modem, you would need to go on the Win XP laptop and log into the router as admin to clone the Win XP laptop's MAC address to the dlink router's WAN interface (internet facing side) so that the cable/dsl modem will see the previously registered MAC address and will enable the internet access.
Mar 23, 2011 | IBM Computers & Internet
Setting up a small network using DSL and a DLink router
1.) The setup needs changing
2.) first off the dss-24 is a network switch not a router
3.) all of your pc equipment should be pluged into that device.
4.) chose one port as an uplink to your att modem
I think your problem is that the new modem is only giving out one ip address. So what ever first pc is turned on that is the one that grabs the address.
5.) you will most likly need a router to take the one ip address assigned via att then dole out additional ones. Remember the dss-24 is not a router. It simply connects everyone together. Each device still needs an ip address given from somewhere. Your old cable modem probibly did that but your new att dsl most likly does not.hence the new router will do that.....
to set it up do the following
2.) Find out the ip setup needed for your dsl service
A.) gateway ip
B.) primary & secondary dns server ip`s
C.) subnet mask
3.) get into the setup of your new router and then plugg in
all of these values using a fixed if address in the router
4.) connect routers wan port to one of the modems port. u may have to use a cross cable or straight look at the link lites to find out if they are talking to each other
5.) make sure that the routers lan side is setup for DHCP
6.) connect one lan port off the router to an uplink
of the dss-24. Then reboot everything
7.) viola it should all work internet on evey machine and file sharring.
Apr 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
D-Link DSL-2640-T. After power outage, I have a good wireless connection BUT no internet access. LAN line does not work either. Please suggest possible solutions.
chack your DSL settings may your not conacted with your sevice provider
chack your locale settings in modem try folowing setups
1. If you have a modem, connect the modem to the router(make sure modem should be connected to the port on which LAN, Internet, WAN is mentioned. It would be a separate one port on the router) and router to the computer.
2. Insert the disk that came with the router, inside the computer.
3. Follow the on screen instructions.
4.No, connect to the wireless
Apr 22, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I need to change the modulation type on my modem to select g.dmt to make my internet connection more stable HELPPPPP!! i have NO clue how to do it. it's an ADSL 2+router DSL 504T.i am computer...
To configure the modem You will need to use the cd provided.
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_C3_QIG_v2.00.pdf
Or to configure without the cd follow the steps below:
  1. Connect the Adsl router with your computer.
  2. Use the network cable provided with the router.
  3. Connect the power cable to the modem, it will light on firmly with a green button on.
  4. Open your web browser and type the ip address: http://10.1.1.1
  5. Default username and password is:
  6. User-name: admin
  7. Password: admin
  8. Use the quick setup wizard.
  9. It will be more easy for you to configure it.
  10. Be sure to have the username and password from the ISP for the internet access, you may need to reconfigure it from start. or if you may need to reset the modem
  11. At times to access your modem you will need to set the ip of your network card to the same range.
  12. To set the ip go in control panel then open network connection
  13. Doulbe click the local area connection.
  14. open Internet Protocol Open Tcp/ip
  15. then set your ip Like: 10.1.1.5
  16. ok
  17. ftp://files.dlink.com.au/Products/DSL-504T-GenII_NZ/Manuals/
I am enclosing a manual for you.
If you Need further help do not hesitate to revert back
Ok cheers
Uttam
Feb 13, 2010 | Computers & Internet
The modem's been changed and cannot locate the CD to the driver to connect to the internet. The model is DSL-G604T/AU V.A3.
Hi! your dlink dsl-604T is adsl router modem, you can access the setup page of your modem router by connecting your computer directly to the port1 of the modem router and the cable from your isp should be connected to the WAN port. u need to pull up the browser and type in at the url:192.168.1.1 and it will ask the username and password, by default the username is admin and the password is 1234 or leave it blank, but i suggest before u do this steps. u need to reset your modem/router. there is a reset button on the back of the router and press it for 20secs and then unplug and replug it after 10secs. after that u can pull up the setup page of the router.. to check the default gateway of the router, right click the network icon on the lower right of the task bar and select status and it will show the ip address, subnet and default gateway..
u need to know what internet settings u have with your internet provider, bcoz once u access the setup wizard it will ask u the type like auto-dhcp, pppoe, static etc.. if your isp gives u a username and pass to connect to internet u have to select pppoe or if u are given a static ip address setting u need to select static ip... just follow the setup wizard..
Aug 17, 2009 | D-Link DSL-G604T Wireless Router
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
Computers & Internet Logo
208 people viewed this question
David Payne
David Payne
