Ilo no power
My monitor was working fine until i unpluged it now has no power. after setting for a while i plug it in and it came on then i turned it off and now no power again. can anyone help me please
  • clinton barnes Jan 07, 2008
    well pluged it back in and working for now.
Kimi
  • 277 Answers
SOURCE: Monitor goes to white at cpu shutdown
The problem is in the "soft switch" technology: On some of Sylvania's newer monitors they have incorporated what is called "soft switch" technology. This allows your ATX power supplied computer to turn your monitor on and off using it?s software controls. Therefore, your monitor?s light will always stay on blinking even when your computer is off. The monitor in normal operation consumes about 80W of power; in the "OFF" state it will be reduced below 8W. The "OFF" mode of the monitor can be controlled by the PC input signal or by pushing the soft-power button to disable the PC signal control for manually turning off the monitor screen. Thus, when the monitor is in soft-power "OFF" mode it still consumes a very small amount of power. For the purpose of making it noticeable to the user that the monitor is in soft-power "OFF" mode, we designed the power indicator to provide for a slow blinking signal (every 2 seconds). If you need to totally turn off the power, then the power cord would have to be unplugged. The same is true of the PC itself, but the PC does not provide for notification while in "OFF" mode. Your monitor looks like it may be in need of repair, contact info: PTI Technologies Inc. 7372 Doig Dr. Garden Grove, Ca 92841 Phone: 714-799-3899 Fax: 714-379-6290 Hours: Mon - Fri 8:00am to 6:00pm PST
Posted on Nov 20, 2005
MicrowaveSvc
  • 9125 Answers
SOURCE: Samtron 94v 19nch problem helpppppppppppppppppppppppppppppp
If it's still under warranty I would call for repair service. It sounds like typical internal power supply trouble that needs electrical troubleshooting.
Posted on Jan 12, 2007
  • 3 Answers
SOURCE: SVA 17" flat monitor screen color is pink.
It's not a "windows" problem. At the bottom of your monitor there should be a 'menu' button. Push the button and use the up and down, right and left arrows on your keyboard to scroll to color. Get the "red" color and adjust it down. You can also scroll through to 'contrast' and adjust that. You don't need to pay a bunch of bucks to have this fixed.
Posted on Jun 12, 2009
JaxPlanet
  • 922 Answers
SOURCE: Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Posted on Aug 08, 2009
  • 1684 Answers
SOURCE: Dell E173FPc monitor worked fine yesterday.
The power supply in the unit has died. This is a very common problem with this series of monitor after 2-3 years of use. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide posted on our site at: www.ccl-la.com Our guide gives parts values and location information as well as how to open the unit up. If you don't feel like doing the repair we also offer repair services, see our web site for details.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Dec 31, 2009
Testimonial: "Excellent site"
My soyo television is hooked up to cable . the 2 other televisions in the house work fine. I turned it on theis morning and got a message "no signal"
Turn off the monitor,Unplug the power cord.Unplug the cables at both ends. If is plug in to a PC ,turn off the PC.Plug the cables back and plug the power.Turn on the PC.
Dec 19, 2010 | Soyo DYLM2286 Monitor
Monitor times out and wont come back on.
Try this settings:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 03, 2009 | Acer AL1914 19" LCD Monitor
    Dell LCD TV won't turn on
    check the cable who comes from the cpu
    May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
    Computer does not turn on
    Check the switch of the power supply at the back (black button) First
    If the power supply fan doesn't work or cpu fan doesn't work
    Replace the power supply.
    Thank you for using FIXYA
    Please don't forget to rate my help
    Have a great day!
    Pablo :-)
    Oct 16, 2008 | Computers & Internet
    My ilo tv wont work wright
    I do have the same problem on my ILO 26HD It worked fine for about a year and sudenly it got freezed, can anyone please find what it is?? Thanks!!
    Aug 14, 2008 | iLO 2600 Television
    Green Flash power only on one computer
    It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
    Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
    Monitor Display Problem.
    The first Polyview has a power supply problem (a short) and locks out the power until it is unplugged. You need to check the voltages inside the Monitor to determine which component/s are faulty. I hope you know electronics if not leave it to the repair shop because you have neither the skills or equipment to repair it. By the way I am not a monitor repair man but I do have 30 plus years in the electronics field.
    The second monitor may have a broken wire in the cord that goes to your computer. Other internal components can cause the same simptoms your seeing. Good luck!
    Mar 28, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
    Ilo 42" plasma tv model#pdp4210ea1
    my 42" ilo plasma started going black on the outside to middle, now its totally black and no sound the power indicated lites for a min then the tv shuts off
    Jan 10, 2008 | iLO 3200 32 in. LCD Television
    Monitor flashes image for split second then goes blank but green LED flashes as well
    while the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
    Occasionally this will not work for me, but if I repeat it it normally works
    Hope this helps - my problem is intermitant so it may be different to what u guys have
    May 02, 2007 | ViewSonic VX924 19" LCD Monitor
    Won't do anything
    take out the plug and let the set stand for about 30 mins.if that does not work take it to a tech for repairs.the problem is in the power supply or the motor.good luck.
    Apr 04, 2007 | iLO DVDR04
    Computers & Internet Logo
    32 people viewed this question
    Alun Cox
    David Payne
    David Payne
