Question about Microwave Ovens
It just stop working. when I push any buttons
It just stop working. when I push any buttons they just are frozen and I can't close the microwave door because it will just keep running.
    President:
  • 1,124 Answers
A component is failing perhaps..
To try and clear it - unplug it for several minuets and plug it back in..
IF that does not work - it would need to be looked at by a service tech,, test components,, diagnose and repair..
Have a great day !
Posted on Oct 06, 2009
Just today, the turntable won't stop turning when the door is closed.
have you pressed the stop button twice when the door is closed to exit the program set for cooking
Dec 17, 2015 | Microwave Ovens
MWG91155L Emerson microwave starts when the door is closed
One of the door switches is malfunctioning and must be replaced to resolve the issue.
Apr 08, 2012 | Emerson Microwave Ovens
My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwwave is not heating,
Hello
Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
Oct 05, 2011 | Sanyo Microwave Microwave Oven
My oven is not heating anything although everything else seems to be working fine. Your site said i may need a multi tester, what is this and where might i find one cheap.
Oct 04, 2011 | Microwave Ovens
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Sep 13, 2009 | Sharp Microwave Ovens
Self start when door closes
if electronic control, one of two things come to mind. 1)your toutch pad is defective.replace it. 2)you electronic board has a leaky component.not very likly though. believe it or not, ive seen it start before by itself then i noticed a large quantity of bugs inside the glass which i realised triggered the microwave 0ff.
Jul 23, 2007 | GE JVM1460SA Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
