Question about Honeywell Surround HZ2200 / HZ2204 / HZ2205 Compact Heater
Honeywell heater turns off after 3 min. Never comes back on
My honeywell fan and heater turns off after 3 min. And never comes back on , the orange light glows with a false sence of warmth. My room was freezing. Now I have a head cold. And I blame honeywell overheat protection thingy in the heater. I just want a little warmth, now I have a stupid heater that never works past 3 minutes. I guess you can un plug it and restart it but , it would be nice to have the heater come on a few times a night by it self. Oh well my heater sucks. Im going to take it apart and try and rig it
    Scholar:
  • 102 Answers
It sounds like the temperature sensor has either failed or come loose and is sitting too close to the heating coil. Alternatively, the level-sensor, which shuts off the heater when it is tilted, may be malfunctioning.
If the heater is not sitting level, it will also shut itself off.
In any case, if it is under warranty, return to the manufacturer. If it isn't, a local appliance repair shop should be able to isolate the problem.
Posted on Oct 06, 2009
Testimonial: "THanks for the quick feed back. Im going to take it apart and try and rig the thermo coilly thing. "
Installing a Honeywell RTH2310B thermostat, only 4 wires but the unit will not turn on the fan or the air condition (heat pump). Orange wire, (O) blue wire (C), black wire (E) were not used. Jumper put in...
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace take off the lower blower door and locate the circuit board turn the power off to the furnace. In the circuit board there should ba a small car like fuse usually 3 or 5 amps check the fuse it is probably blown replace the fuse with the same amperage fuse and then turn the power back on on the furnace and check the operation of the furnace.
Sep 05, 2011 | Honeywell Programmable Thermostat Heater
Gas furnace cycles on and off every 2-3 mins. then the gas cuts off and the fan keeps blowing until the power is cut off. The led light blinks twice.Any ideas?
check out your fan control could be dusty at the back remove it and clean it also check air fiter is clean , or tthe fan conrtol could need replacing
Dec 03, 2010 | Honeywell Programmable Thermostat Heater
How to wire Honeywell thermostat RTH7500 from old Weathertron GE
You have a control board on your furnace, there is a 3 amp fuse there, that 3 amp fuse needs to be replaced. You most likely touched a wire even by accident and blew the fuse. You will have to remove the door \panels to get at it. It looks like a normal car fuse
May 31, 2010 | Honeywell Electronic Programmable...
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
Honeywell RTH 7500d is not working.
If nothing is happening then I am wondering about tje power... If you have access to a digital meter, you should have 24v a/c across the R wire and the C wire...
Did you make sure to turn off the power at the air handler or furnace before unhooking the wires at the t-stat??? If not then you have blow a fuse in the control board or burnt out the transformer...
If you have power on R then jumper to G and the fan shoudl come on... if it does then the t-stat is bad...
This should give you a few things to try and is what I would be doing if it were my service call...
heatman101
Apr 29, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
Trying to connect kenmore heat pump thermostat to honeywell therm
reversing valve orange wire goes to o or b terminal depending if energized in heating or cooling
May 11, 2009 | Honeywell Programmable Thermostat Heater
Heat will not shut off
Take white off of Aux, and attach it to L
Feb 16, 2009 | Honeywell Programmable Thermostat Heater
Inside tem. can not reach the set tem. during the cool days
check the presure switch jump it out and see if it fires all the time
Jan 17, 2009 | Honeywell Programmable Thermostat Heater
My heating/cooling blower (not the outside unit but the fan in the garage) does not turn off, even when my Honeywell TH8000 is set on automatic. What can I do to have the fan motor shut off?
try hard wiring your 24 volt that goes to the outside unit to the yellow wire coming back from your thermostat make sure the yellow wire is on the yellow terminal on the thermostat (honeywell) i have run into situations when this seemed to be the only thing that worked
Jan 13, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Surround HZ2200 / HZ2204 / HZ2205 Compact Heater Logo
555 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
