Question about Homelite Garden
My 18in homelite saw starts ok, cuts fine but, when you shut bdown to refuel or take a short break, (over 5 min) it will not restart till it cools down or about a half hour. Thanks
    President:
  • 2,220 Answers
Loosen the fuel cap when you shut it down tighten it before you restart. If this fixes it you have a plugged fuel vent. HTH
Lou
Posted on Oct 07, 2009
    Sergeant:
  • 302 Answers
This sounds as if you need a new spark plug or else pull and clean the one that's in it now
My chain saw starts just fine. It will work for about 30 minutes cutting well. After about 30 minutes the engine begins to miss and stall under load. Shortly thereafter the saw will not restart until it...
This sounds very much like a bad ignition unit, if they are going to break down they will do it when they are hot, the only answer here is to replace the unit.
Aug 27, 2011 | Poulan Garden
Husqvarna k750 runs for about 5 mins then shuts off. let it rest then restart 5 mins later same thing
Obevisley is over heating make sure all fins and vents are clear and blown out then the only other thing is to replace the ignition modual just trace the plug wire back to flywheel and ignition block
Oct 06, 2010 | Husqvarna Partner Gas Powered Cut Off Saw...
This homelite chainsaw is bran new
Remove the spark plug and check for blue and snappy spark. If weak or nothing, try another spark plug. If still improper spark, return the machine for replacement under warranty. Make sure you have followed all instructions for re-start. Good luck!
May 24, 2010 | Homelite ZR10926 16 Chain Saw
Need replacement Chain oil pump
Go to the Homelite web site, which will get you to HCPI Electronics Parts catalog. You will need the model number. The parts are illustrated as a break-away drawing for various portions of the saw. Hope this helps.
Aug 29, 2009 | Garden
Runs well untill it gets hot. then cuts out
If it's the little xl model, it's probably the ignition coil breaking down when it gets hot and therefore it can't and won't be able to handle a load. Also, scarred pistons skirt or rings could also be some of the problem here. Make sure your mix for a Homelite saw is 40:1 not 50:1 like most saws are. Homelite seems to run better with a heavier oil mixture. Good luck.
Aug 02, 2009 | Garden
Starts ok when cold. acts like it's out of fuel when hot.
Clean or change the sparkplug. Also make sure you have fresh gas and the proper fuel mix.
Jul 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Homelite chain saw difficult to restart after refueling.
Are you pumping the primer till it's full first?
Mar 09, 2009 | Homelite Garden
Garden Logo
88 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
