Question about Amana ALG331RAW Gas Dryer
Keeps spinning and dont dry - Amana ALG331RAW Gas Dryer
  • Amana Master
  • 7,482 Answers
Your first problem sounds like you have a faulty timer switch, you will have to replace the timer switch because normally they are not repairable.
Sounds like your 2nd problem is with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with a continuity meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
Good Luck,
Hope this helps
Posted on Oct 06, 2009
Washing spins but dont take all the water out of the clothes
If like you said its spinning just not drying your clothes, then I would check the transmission plate and clutch. When the transmission leaks oil it goes into the transmissions plate wich has this break pad inside which hooks up to the clutch during the spin cycle in order to make the tub spin. If it is worn out or if it has oil it won't spin fast and will not dry your clothes.
Hope this video helps!
http://youtu.be/TB_W6sPdzkM
Oct 11, 2014 | Kenmore 24032\24036 Top Load Washer
Disc spins but will not play
This sounds like the laser cant focus right on the disc so it keep searching. try to clean the eye of the laser with a Qtip and rubbing alcohol. Usually i make sure the the tip if fluffy with a brand name qtip, then i take another one and do it again, then i used the dry one to dry it out and i make sure that there is no forget area and no hair or dust remaining. IT gotta be PERFECTLY clean. If it still dont work, repeat the process if it does not work and you try cpl other disk without result, throw it away. We yall know electronics is dispose after use by now, thats what it is...
Aug 15, 2009 | RCA DRC629N Portable DVD Player
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
Aug 09, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
When the dryer is open the dryer keeps spining and wont stop you have to unplug it
Check the door switch. If the plunger is stuck, the dryer keeps running.
May 14, 2009 | Dryers
Washer squeals in rinse or spin
When the washer is in the final spin cycle and starts to sqeal, just pour a little water through the drawer about half of a glass full usually does the trick. What apparantly happens is that the connection/seal between the big grey rubber seal and the stainless steel drum has dried out due to the centrifugal effect of the spin cycle and it needs to be wetted to keep the sealed area lubricated and cool. The squealing is a result of the dry rubbing of these parts during the spin cycle.
Apr 17, 2009 | Washing Machines
Wash cycle,spin dry, water level
I WOULD CHECK FOR A PLUGGED AIR PRESSURE HOSE OR THE PRESSURE SWITCH ITSELF.
Jan 26, 2009 | Hoover Washing Machines
Wet gamecube
maybe it broke because you wet it
Aug 01, 2008 | Nintendo GameCube Console
Kenmore 80 series washer not completly spinning clothes dry
Belt going..
A bit of a pain to replace, but doable..
Belt dressing will keep it going for a while..
Dont get your fingers caught in it..
Serious injury is possible, unplug the machine
and stand on the plug while moving the
belt to goop it..
(why? that way it cant get plugged in!)
Feb 07, 2008 | Washing Machines
Amana ALG331RAW Gas Dryer Logo
349 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
