Question about Dryers
Drive belt broke - Dryers
  • Dryers Master
  • 7,482 Answers
If you have to replace your drive belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, and also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Posted on Oct 06, 2009
Testimonial: "thank you for ur help hopefully i can fix this myself"
2001 eclipse serpetine belt broke put new ones on now car turns over but won't start.
2001 GT Eclipse Spyder..cranked this morning, both drive belts broke, harmonic balancer came apart..replaced balancer, belts, now it won't fire. I did find a piece of one of the drive belts intertwined in the timing belt. Thing is absolutely not getting any fire.
Sep 23, 2015 | Cars & Trucks
Johndeere gx75 drive belt diagram
I broke a drive belt on my gx75 and need to know proper routing and installation for new one AmanStino Ultra Slim Lightweight Smart shell Stand Cover with Auto Wake...
Jun 15, 2012 | Cars & Trucks
Driving my 92 525i bmw on freeway when it all broke loose my Power Steering and then all the lights on dash when on. Also the car over heated. What could have happen?
Serpentine belt broke. A serpentine belt drive runs everything: power steering, ac, alternator (electrical power), and the water pump (explains the overheating). I'd bet anything that your belt broke.
Jun 13, 2011 | 2007 BMW 525xi Sedan
My belt broke and now my car wont start why not?
Ok. If your car was running and then the belt broke and you continued to drive it. The case may be that you drained the battery because the alternator runs on the belt and the alternator keeps battery charged and if belt broke and you continued to drive then you may need to jump start vehicle. I guess I shouldve asked earlier but have you replaced belt yet?
Jan 30, 2011 | 1995 Mercury Cougar
Driving and the timing belt broke can i just replace the belt? 2003 chrysler 300m
If the timing belt broke, than you heard a big banging noise from your engine and that is it, your valves met with pistons and they are more than likely to be bend, unfortunately this situation calls for engine recondition. But are you sure the belt broke as some of these 300M's were on a chain drive.
Dec 15, 2010 | 2003 Chrysler 300M
2002 kia spectra belt broke. Trying to figure which belt broke
Welcome to FIxYa.com
See which of the two drive belts broke ? and look at diagram and belt name is in diagram.
Thank you for using FixYa.com
Regards, Lee Davidian
Dec 14, 2010 | 2002 Kia Spectra
My wife has a 1994 chevy suburban,she was driving along and the serpentine belt broke, what do you think caused that to happen?
WELL I WOULD SAY BELT WORN HAD A BAD PLACE BROKE OR FAULTY DRIVE BELT TENSIONER CAUSING LOT OF SLACK IN BELT TO BREAK.
Aug 27, 2010 | Chevrolet Suburban 1500 Cars & Trucks
Is a 91 tercel 1500 engine a interference engine - Timing belt broke while driving
what do want to find out, , the timing belt broke like that when the are damaged or aged. that why maintaince is neccesary to avoid that
Aug 10, 2010 | 1991 Toyota Tercel
Drive belt broke murray riding mower how do i put one in?
yes the drive belt is the bottom one it looks hard but is really simple the main thing is you have to look rite above the left back tire and remove two 5/16 bolts with an 1/2 in wrench to in stall drive belt the you install other belts
Aug 08, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Dryers Logo
61 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
