Question about Amana ABB1927DE Bottom Freezer Refrigerator
Moved The Fridge, Not cooling
I recently got this fridge from my mother in law and it was on its side for the whole ride to my house(10 miles) and now the fridge will blow "cool" but not cold....i know for a fact that the fridge worked perfectly before the move. I opened the back of the fridge and compressor and everything are running like they should be, one line is warm and one line is cool coming off of the compressor.....Anything i can do to fix this??? Thanks
  • stl1219 Dec 23, 2007
    I did give the fridge 24 hours before turning it on as well
  • stl1219 Dec 24, 2007
    I checked the fans and they work properly, like i said the freezer and fridge area get cool but not cold..
Oil from the compressor gravitated into the evaporator coils and is restricting the flow of refrigerant. Oil may drain back to compressor after standing upright for a few days; if not the evaporator will have to be purdged with refrigerant and system recharged.
Posted on Nov 16, 2011
    Sergeant:
  • 288 Answers
Check the evaporator fan inside the freezer compartment.
Posted on Dec 24, 2007
  • Rob Luna
    Rob Luna Dec 24, 2007
    Lying the a refer on its side is a big no no but its a bit overrated. However in your case, it may be the problem. First make sure the compressor is not kicking out on the overload, thus short cycling the system. Also check the thermostat to make sure its not cutting out prematurely. You may need to add some access valves to the copper lines to connect the gauges if the thermostat checks out and you still think it may compressor.
My fridge has stoped cooling frezzer stoped last week dumped the ice out move frome wall started working agin for a week than stoped working yesterday WTF is was made in 06 is the compressure out or what...
you moved the fridge out from the wall and it started running again?try opening the fridge door and tap on the fridge control and see if it starts up.i,ve gone into houses and then the woman tells me when the fridge shuts down she hits the side and it runs again.it's the control,this could be your problem also,when you moved the fridge the control could have kicked back on.let me know what you find
Jan 13, 2011 | Frigidaire FRS-26DR7D Side by Side...
My fridge quit cooling when i moved it to my new house
Did you lay it down? if so trun it off and leave it for 24 hours(minimum) try again, if still no good you will need a professional to fix it.
Apr 17, 2010 | Whirlpool ED5VHGXM Side by Side...
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Fridge not cooling! But the Fan and light is working! HELP!!
Sounds like you have caused a leak in the sealed system and the coolant is no longer inside it. You will need a professional to fix this.
Apr 13, 2009 | Jason Natural Cosmetics Jason Forma...
Freezer in my kenmore refrigerator isn't cold
Make sure the freezer fan motor is running. The wires may have come off when it fell.
Mar 08, 2009 | Kenmore Refrigerators
Model #10657058791 freezer and fridge not cooling
Check your connections in the back make sure no wires are lose or rattled lose off of the compressor or anything like that
Feb 09, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
JENN-AIR Freezer and refrigerator not cooling
good day,
hope this link below will solve your problem.
ref
Jan 10, 2009 | Jenn-Air JCD2389G Side by Side...
Fridge not cooling
Hello.
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore Fridge not working
may i suggest you Purchase A premium repair Solution. @ $19.99 or £10.00 G.B.P
One of our technical assistants, will usually have the Answer to your Problem, within the hour.
Mike @ Compurepair.
Mar 02, 2008 | Kenmore 44109 / 44102 Side by Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
598 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
