Question about IBM eserver xSeries 220 8646
Installed RAM not Recognised
I just went from 4 - 512 MB sticks of RAM to 2 - 1 GB and 2 - 512 MB and the server is saying it still only has 2 GB of RAM
  • 922 Answers
It may not be a valid combination of sizes or speeds.
Look up your server at www.crucial.com using their memory finder.
They should have detailed information.
You can always call them or start a chat session if you need more details.
If this helps please vote for my solution.
Posted on Oct 07, 2009
System requirement to run crystal report v9 professional
System Requirements
  • PC with AMD or Intel based processors, Dual Core CPU, 2 GB RAM.
  • 3.5GB available hard drive space (for English only, 7.5 GB for all languages)
  • DVD drive (for DVD install only)
  • Microsoft Windows 7 SP1, Windows 8, Windows Server 2008 SP2, Windows Server 2008 R2 SP1, Windows Server 2012
  • Languages: Chinese simplified, Chinese traditional, Czech, Danish, Dutch, English, Finnish, French, German, Hungarian, Italian, Japanese, Korean, Norwegian, Polish, Portuguese, Romanian, Russian, Slovakian, Slovenian, Spanish, Swedish, Thai, Turkish
Technical Specs
  • Hardware Requirements: Intel Pentium III or equivalent processor, 256 MB RAM, 512 MB Recommended
  • Disk Space: 2 GB for default installation with English language, 4 GB for default installation with all languages installed
Dec 23, 2013 | Crystal Decisions Crystal Reports V9...
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Dell XPS 400 PC Desktop
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Tried installing 4gb memory on to acer aspire 5720z notebook running vista 32bit, they would not be recognised. Have now installed vista business 64 bit & the 2 x 2GB new memory is still not...
  • CPU Section:
  • Microprocessor Full Name:Intel Core 2 Duo processor T5250
  • Microprocessor Manufacturer:Intel
  • Microprocessor Speed (GHz):1.5
  • L2 Cache (KB):2 Mb
  • Frontside Bus (MHz):667
  • Memory:
  • Memory Speed (MHz):667
  • Memory Type:DDR2
  • Memory Size (MB):2048 Mb
  • Max Memory Size:2Gb
  • Hard Disk Drive:
  • Hard Drive Capacity (GB):80 Gb
  • Hard Drive Type:S-ATA
As you can see from my printout from the web site, this laptop doesn't appear to support more than 2Gb of RAM.
Sorry.
Oct 18, 2010 | Acer Aspire 5720 Notebook
I have problem about ram
If the manual says this motherboard support up to 1 GB RAM, you cannot put 2 GB. You can put 2x 512 GB RAM or 1GB RAM
Also try to upgrade your bios, maybe a better bios version supports more than 1 GB RAM.
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
Windows doesn't see my 6 GB of RAM but BIOS does
You have the same machine as i. To the best of my knowledge it does not support 2 gig sticks. Thats why the say it only supports 4 gig of ram. I hope that is correct still. I also do not have a12 Bios so it could have changed.
Mar 21, 2009 | Dell PowerEdge 1600SC Server
No display after upgrading RAM
Are you saying that there are only 2 slots for ram or 4, if 4 then you may have a dual channel lap top, in which case you need all of the ram to match, they all have to be the same exact ram.you cant mix and match, also is the bios recent, it sounds like you may need a bios flash if the laptop isn't recent.And there may be a limitation on the amount of ram it takes, I just setup a brand new acer and it only two gig max, see if they offer a bios update
Dec 23, 2008 | Gateway M-6866 15.4" Widescreen Laptop...
Windows won't see all of my 4GB of RAM but BIOS does! Why?
Windows xp will usually only see 3.5 gbs of ram even in your motherboard can support more. WIndowns vista does recognize more RAM or i also believe windows xp 64bit recognizes more ram. Nothing wrong with ram or your computer its just your operating system.
Dec 18, 2008 | Dell PowerEdge 1600SC Server
1 gb pc2100 recognised only as 512 mb
The only other thing I can think of is to go into the BIOS and see if there is any option about enabling both RAM slots. Other than that, I can only think that the 2 have to be the same size. All the specs say it should hold up to 2GB. Good luck.
Oct 15, 2008 | PC Chips M789CG (M789CGVIA2000)...
IBM eserver xSeries 220 8646 Logo
232 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
