Question about Maytag Neptune MDE5500AY Electric Dryer
Very loud metal vibration coming from the dryer.
  • Maytag Master
  • 7,482 Answers
Your problem could be your drum rollers.
If you plan on trying to do the repair yourself, then you will need to unplug the dryer from the electric.
If you have a front loading machine
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
Check the idler arm with the pulley, sometimes wear will cause the noise you describe.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy.
Check your drum rollers for flat spots, if they have flat spots on them this will cause noise like a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Posted on Oct 06, 2009
Testimonial: "Thank you"
Dryer occasionally makes a loud vibrating sound
Under warranty - contact retailer or manufacturer - check user manual or receipt for procedure.
May 30, 2016 | Blomberg DV17540 NBL00 Vented Dryer with...
What is cause of loud vibration noise
In most cases, vibration sounds come from which ever helps the drum to spin with no resistance, In most cases those would be drum support wheels or bearings depending on the model.
In some rare cases, blower or belt pulley could also cause similar symptoms.
Feb 11, 2015 | Dryers
Why does my gas dryer make a loud vibration noise?
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
Jul 21, 2014 | Electrolux Dryers
Loud vibration
Lot of these dryer had a split or defect in the drum. They will give a free drum but ya gotta pay labor to replace it.
MY LG dryer service manuals and repair videos
Nov 16, 2012 | LG Home Applaince LG DLE2301W 7.3 Cu. Ft....
Loud vibrating noise after warming up
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
May 10, 2010 | GE Profile Harmony DPGT750EC Electric...
Loud vibrating noise. Sounds like its coming from
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 18, 2010 | Dryers
Beko DRCS68 condensor dryer is making loud vibration noises
hi there......when you replaced the drive belt you most likley disturbed the drum on its bearing seats (small plastic curved units) or indeed knocked 1 out altogeathrer...this would account for the loud bearing or metallic sound...it may also be the rear bearing these tend to eventually rund dry and fail..
regards Sir GalAHAD
Apr 17, 2009 | Frigidaire GLER331A Electric Dryer
Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Dec 20, 2007 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
192 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
