Acer aspire one mouse pad clicks not working stuck on right click
I have purchased an acer aspire one netbook, it came with the linux operating system but i have put xp pro onto it, it works fine aprt from the touch pad.
in the bottom right tray it shows the touch pad and the right click constantly down and the clicks on the touchpad are not working. the actual touchpad works fin but its the buttons ive tried reinstalling the driver and it still doesnt solve the problem.
it works fine with an external mouse
    President:
  • 2,600 Answers
If you are saying the right button is down and is not coming back up, then either the plastic lip on the button is jambed against the palmrest, or the actual mechanical part of the mouse button underneath has collapsed and has become non-functional. If the right button clicks but does not do anything like bring up the selection window in windows then that may be a hardware issue related to XP, try this, go to the control panel > system > hardware > device manager> scroll down the Mice and pointing devices. Highlight the touchpad and click on uninstall. Make sure you are connected to the internet when you reboot and have your usb mouse hooked up so it is easy to work around this. When windows reboots it will be forced to reinstall the touchpad because it will recognize it as a new device and want to install drivers for it. If it asks to search windows update for a fresh driver, allow it and let it finish the install. See if that corrects the problem. If it is mechanical in nature, then the palmrest is going to have to be taken off and the touchpad button assembly underneath replaced.
Posted on Oct 06, 2009
A bit later in the game I know. However I had the same problem and i fixed it. I think you will find that the ribbon cable which joins the touch pad to the motherboard (under the keyboard) has a connection which is not connecting.
How to fix -
1a. Turn off computer, remove power supply, remove battery and discharge computer by pressing the power button.
1b. Remove keyboard and its ribbon cable (search YouTube if you are unsure). The ribbon cables can be removed by flicking up the black stopper on the motherboard connector.
2. Remove the small ribbon cable closest to the touchpad.
3. Inspect the silver contacts on the underside of the cable, you should find the contact that ends up being on the right-hand side when inserted into the connector, is slightly rolled back over itself.
4. Using something non-abrasive (something that won't cut the contact, my finger nail in my case) roll the contact towards the end of the ribbon cable where the contact should be (like the rest of the contacts).
5. Insert the ribbon cable back into the connector on the motherboard gently. If you feel as thought you have hit something when you re-insert the cable you should probably pull it back out again inspect and try to re-insert it holding it to the top of the connector as you push it in.
6. Install the keyboard, then turn on.
7. If it doesn't work, try repeating the process, if it still doesn't work... get someone to fix you computer for you.
Posted on Apr 08, 2011
I've got the same problem. I'm still running Linux on my aspire one, and synclient shows that the right mouse button is depressed. If I restart X (i.e. logout/login again) then it "lifts" the mouse button, which is then stuck "off" instead of on.
I checked with a multimeter and the switch on the motherboard is working fine, so if it's a hardware problem it's with the electronics rather than the switch. (however the fact that people are seeing this with both windows and Linux seems to indicate that it's either BIOS or hardware)
Posted on Mar 15, 2010
Starts up, can scroll around with mouse but cannot click on anything
if you use an external usb mouse...try to install the driver for it ...ot change the mouse cause it may be corrupted...if you use the pad..go to the manufacturer's support site (Google for Acer support ..and will be there )and in there select support ..than select your model and your operation system ..and after that locate the driver for the mouse-pad..and download and install ...If this operation will not make it functional again ..the reason is the pad is faulty and you have to order and replace it with a new one ..or ..just use a usb external mouse..it will be easier and more comfortable ..
Nov 03, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have a built in web cam on my Acer Aspire One netbook that is not working. If the mouse pad works, the camera can't work. how can i have this fixed?
do this Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files. and download registry cleaner reg in out may help u
Sep 13, 2010 | Acer Aspire One PC Notebook
My touch pad stopped working on my brand new Acer Aspire laptop model 5532. I have tried turning it on and off and it only works with a mouse. Any solutions?
“Hi,
I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
III. You may need to “Update Drivers2_bing.gif?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver2_bing.gif”, click (OK), this will ensure that the application take effect.
Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
If the solution helped, rating it is appreciated, thanks
Mar 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
Acer erratic and uncontrollable mouse clicking
use a external mouse preferably a PS2 mouse...after frequent use the mouse touch pad gets worn out and it does this joker work...even my 10 yr old DELL laptop had this issue after 4 yrs....
Feb 26, 2010 | Computers & Internet
Acer Aspire One Netbook Touch pad mouse not working
There is a small ribbon cable that connects the touchpad to the motherboard. If there was any dramatic jostling of the system or it was disassembled for any reason it may have come undone. I have heard of this happening in the past.
If your lucky, someone just turned it off. The toggle for the mouse pad is Fn+F7 simultaneously.
Good Luck,
NOLA Tech
Feb 06, 2010 | Acer Aspire One Netbook
Left mouse key does not click since i bought it but does work . I thought this was ok but my it friend said he reckons it is stuck . the right mouse key clicks. Is this normal?
It must be stuck, try left clicking a few times, and increase the force as well, careful, or it might break, this really is the way, my mouse gets stuck all the time ...
Nov 22, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire Netbook..Can't use keys or right/left click.
go to control panel then mouse properties you will see the buttons the left & right then click the task that you want to do.
Aug 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer d150 left trackpad button not clicking/working
go to control panel click on mouse and set for right handed
Jul 29, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one touchpad right button not working
you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
Mar 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Computers & Internet Logo
3,036 people viewed this question
David Payne
David Payne
