Error 102 motherboard failure - Computers & Internet
Hi I haven't used my phone for a couple of years. when I switch it on now it say.. error 102 reload software... what do I do?
You need to do a Factory Reset, AKA a Hard Reset. This removes everything on the phone and reloads the operating system. Your phone is a Blackberry?
  • Error 102 Reload Software - BlackBerry Support Community ... https://supportforums.blackberry.com/t5/BlackBerry-Device-software/... Hello, I've just had a problem with my Blackberry 9930 phone. I already tried updating the Blackberry Desktop Software and I also tried the phone,
  • Error 102 - Reload Software - Blackberry Torch 981 ... https://supportforums.blackberry.com/t5/BlackBerry-OS-Smartphones/... Hi. I took the battery out of my phone and when the phone re-booted I now can only see a white screen with the error 102 and states reload software.
  • How to Reload Blackberry Mobile Software - Snapguide snapguide.com > Technology > Explore
    • 3.5/5
    • 10 RATINGS
    • BY TAHANI ALGHAREEB
    i will teach you how to reload your blackberry soft ware when its got error 102 and not working by this steps. all you ... How to Reload Blackberry Mobile Software
  • JVM Error 102 on your BlackBerry? Try this solution BEFORE ... crackberry.com > ... > Classic > Z30 > Z10 > Q10 > Leap > OS 10.3.2 Video embedded · JVM Error 102 on your BlackBerry? Try this solution ... JVM Error 102 on your BlackBerry? Try this solution BEFORE wiping! ... "Error 102. Reload Software ...
  • Terpecahkan: Curve 9360 Error 102 (Reload software ... forumdukungan.blackberry.com/...Error-102-Reload-software/td-p/258111 Terpecahkan: Dear all, Saya newbie disini, BB saya curve 9360, sudah mati 5 hari dengan error 102 (reload software). Sudah coba ikut instruksi dari
  • How to fix an error 102 reload software blackberry torch ... www.askmefast.com > ... > Error How to fix an error 102 reload software blackberry torch 9810? ... How can I fix reload error 102 on blackberry torch 9810? Comment. Reply. Report.
  • ERROR 102 www.blackberryos.com/general-blackberry-issues/38452-error-102-a.html
    • 2 POSTS
    • FIRST POST: 2013-08-12
    2013-08-12 · how do i reload software on a bb 9360?? ... Join Date Dec 2010 Location Gainesville, FL PIN Jarmeling Device Passport OS 10.3.2.2134
  • May 20, 2016 | Cell Phones
    Tip
    System Beep Code Error
    Beep Code Manual, Better Than Gold Techies, American Megatrends Int. & Phoenix
    BIOS Beep Codes
    When a computer is first turned on, or rebooted, its BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, or if there is a problem with the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected.
    Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
    The two most-used brands are AMI (American Megatrends International) and Phoenix.
    Below are listed the beep codes for AMI systems, and here are the beep codes for Phoenix systems.
    AMI Beep Codes
    Beep Code Meaning
    1 beep DRAM refresh failure. There is a problem in the system memory or the motherboard.
    2 beeps Memory parity error. The parity circuit is not working properly.
    3 beeps Base 64K RAM failure. There is a problem with the first 64K of system memory.
    4 beeps System timer not operational. There is problem with the timer(s) that control functions on the motherboard.
    5 beeps Processor failure. The system CPU has failed.
    6 beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode.
    7 beeps Virtual mode exception error.
    8 beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card.
    9 beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty.
    10 beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS.
    11 beeps Bad cache memory. An error in the level 2 cache memory.
    1 long beep, 2 short Failure in the video system.
    1 long beep, 3 short A failure has been detected in memory above 64K.
    1 long beep, 8 short Display test failure.
    Continuous beeping A problem with the memory or video.
    BIOS Beep Codes
    Phoenix Beep Codes
    Phoenix uses sequences of beeps to indicate problems. The "-" between each number below indicates a pause between each beep sequence. For example, 1-2-3 indicates one beep, followed by a pause and two beeps, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes. Click here for AMI BIOS beep codes.
    4-Beep Codes
    Beep Code Meaning
    1-1-1-3 Faulty CPU/motherboard. Verify real mode.
    1-1-2-1 Faulty CPU/motherboard.
    1-1-2-3 Faulty motherboard or one of its components.
    1-1-3-1 Faulty motherboard or one of its components. Initialize chipset registers with initial POST values.
    1-1-3-2 Faulty motherboard or one of its components.
    1-1-3-3 Faulty motherboard or one of its components. Initialize CPU registers.
    1-1-3-2
    1-1-3-3
    1-1-3-4 Failure in the first 64K of memory.
    1-1-4-1 Level 2 cache error.
    1-1-4-3 I/O port error.
    1-2-1-1 Power management error.
    1-2-1-2
    1-2-1-3 Faulty motherboard or one of its components.
    1-2-2-1 Keyboard controller failure.
    1-2-2-3 BIOS ROM error.
    1-2-3-1 System timer error.
    1-2-3-3 DMA error.
    1-2-4-1 IRQ controller error.
    1-3-1-1 DRAM refresh error.
    1-3-1-3 A20 gate failure.
    1-3-2-1 Faulty motherboard or one of its components.
    1-3-3-1 Extended memory error.
    1-3-3-3
    1-3-4-1
    1-3-4-3 Error in first 1MB of system memory.
    1-4-1-3
    1-4-2-4 CPU error.
    1-4-3-1
    2-1-4-1 BIOS ROM shadow error.
    1-4-3-2
    1-4-3-3 Level 2 cache error.
    1-4-4-1
    1-4-4-2
    2-1-1-1 Faulty motherboard or one of its components.
    2-1-1-3
    2-1-2-1 IRQ failure.
    2-1-2-3 BIOS ROM error.
    2-1-2-4
    2-1-3-2 I/O port failure.
    2-1-3-1
    2-1-3-3 Video system failure.
    2-1-1-3
    2-1-2-4 I/O port failure.
    2-1-4-3
    2-2-1-1 Video card failure.
    2-2-1-3
    2-2-2-1
    2-2-2-3 Keyboard controller failure.
    2-2-3-1 IRQ error.
    2-2-4-1 Error in first 1MB of system memory.
    2-3-1-1
    2-3-3-3 Extended memory failure.
    2-3-2-1 Faulty motherboard or one of its components.
    2-3-2-3
    2-3-3-1 Level 2 cache error.
    2-3-4-1
    2-3-4-3 Motherboard or video card failure.
    2-3-4-1
    2-3-4-3
    2-4-1-1 Motherboard or video card failure.
    2-4-1-3 Faulty motherboard or one of its components.
    2-4-2-1 RTC error.
    2-4-2-3 Keyboard controller error.
    2-4-4-1 IRQ error.
    3-1-1-1
    3-1-1-3
    3-1-2-1
    3-1-2-3 I/O port error.
    3-1-3-1
    3-1-3-3 Faulty motherboard or one of its components.
    3-1-4-1
    3-2-1-1
    3-2-1-2 Floppy drive or hard drive failure.
    3-2-1-3 Faulty motherboard or one of its components.
    3-2-2-1 Keyboard controller error.
    3-2-2-3
    3-2-3-1
    3-2-4-1 Faulty motherboard or one of its components.
    3-2-4-3 IRQ error.
    3-3-1-1 RTC error.
    3-3-1-3 Key lock error.
    3-3-3-3 Faulty motherboard or one of its components.
    3-3-3-3
    3-3-4-1
    3-3-4-3
    3-4-1-1
    3-4-1-3
    3-4-2-1
    3-4-2-3
    3-4-3-1
    3-4-4-1
    3-4-4-4 Faulty motherboard or one of its components.
    4-1-1-1 Floppy drive or hard drive failure.
    4-2-1-1
    4-2-1-3
    4-2-2-1 IRQ failure.
    4-2-2-3
    4-2-3-1
    4-2-3-3
    4-2-4-1 Faulty motherboard or one of its components.
    4-2-4-3 Keyboard controller error.
    4-3-1-3
    4-3-1-4
    4-3-2-1
    4-3-2-2
    4-3-3-1
    4-3-4-1
    4-3-4-3 Faulty motherboard or one of its components.
    4-3-3-2
    4-3-3-4 IRQ failure.
    4-3-3-3
    4-3-4-2 Floppy drive or hard drive failure.
    3-Beep Codes
    Beep Code Meaning
    1-1-2 Faulty CPU/motherboard.
    1-1-3 Faulty motherboard/CMOS read-write failure.
    1-1-4 Faulty BIOS/BIOS ROM checksum error.
    1-2-1 System timer not operational. There is a problem with the timer(s) that control functions on the motherboard.
    1-2-2
    1-2-3 Faulty motherboard/DMA failure.
    1-3-1 Memory refresh failure.
    1-3-2
    1-3-3
    1-4-1 Address line failure.
    1-4-2 Parity RAM failure.
    1-4-3 Timer failure.
    1-4-4 NMI port failure.
    2-_-_ Any combination of beeps after 2 indicates a failure in the first 64K of memory.
    3-1-1 Master DMA failure.
    3-1-2 Slave DMA failure.
    3-1-3
    3-1-4 Interrupt controller failure.
    3-2-4 Keyboard controller failure.
    3-3-1
    3-3-2 CMOS error.
    3-3-4 Video card failure.
    3-4-1 Video card failure.
    4-2-1 Timer failure.
    4-2-2 CMOS shutdown failure.
    4-2-3 Gate A20 failure.
    4-2-4 Unexpected interrupt in protected mode.
    4-3-1 RAM test failure.
    4-3-3 Timer failure.
    4-3-4 Time of day clock failure.
    4-4-1 Serial port failure.
    4-4-2 Parallel port failure.
    4-4-3 Math coprocessor.
    on Feb 02, 2010 | Computers & Internet
    Tip
    Beep Code Manual
    (I'm Computer Technician, I use these codes to trouble shoot hardware issues at my job. Enjoy.)
    BIOS Beep Codes
    When a computer is first turned on, or rebooted, it's BIOS performs a power-on self test (POST) to test the system's hardware, checking to make sure that all of the system's hardware components are working properly. Under normal circumstances, the POST will display an error message; however, if the BIOS detects an error before it can access the video card, it will produce a series of beeps, and the pattern of the beeps indicates what kind of problem the BIOS has detected. Because there are many brands of BIOS, there are no standard beep codes for every BIOS.
    AMI Beep Codes
    Beep Code Meaning
    1. beep DRAM refresh failure. There is a problem in the system memory or the motherboard.
    2. beeps Memory parity error. The parity circuit is not working properly.
    3. beeps Base 64K RAM failure. There is a problem with the first 64K of system memory.
    4. beeps system timer not operational. There is problem with the timer(s) that control functions on the motherboard.
    5. beeps Processor failure. The system CPU has failed.
    6. beeps Gate A20/keyboard controller failure. The keyboard IC controller has failed, preventing gate A20 from switching the processor to protect mode.
    7. beeps Virtual mode exception error.
    8. beeps Video memory error. The BIOS cannot write to the frame buffer memory on the video card.
    9. beeps ROM checksum error. The BIOS ROM chip on the motherboard is likely faulty.
    10. beeps CMOS checksum error. Something on the motherboard is causing an error when trying to interact with the CMOS.
    11. beeps Bad cache memory. An error in the level 2 cache memory.
    1 long beep, 3 short A failure in the video system.
    1 long beep, 8 short display test failure.
    BIOS Beep Codes
    Phoenix Beep Codes
    For example, 1-2-3 indicates one beep, followed by a pause and three beeps. Phoenix version before 4.x use 3-beep codes, while Phoenix versions starting with 4.x use 4-beep codes.
    4-Beep Codes
    Beep Code Meaning
    1-1-3-2
    1-1-3-3
    1-2-1-2
    1-2-3-3 DMA error.
    1-3-3-3
    1-3-4-1
    1-4-1-3
    1-4-2-4 CPU error.
    1-4-3-1
    1-4-3-2
    1-4-4-1
    1-4-4-2
    2-1-1-3
    2-1-2-4
    2-1-3-1
    2-1-1-3
    2-1-4-3
    2-2-1-3
    2-2-2-1
    2-2-3-1 IRQ error.
    2-3-1-1
    2-3-2-3
    2-3-4-1
    2-3-4-1
    2-3-4-3
    2-4-2-1 RTC error.
    2-4-4-1 IRQ error.
    3-1-1-1
    3-1-1-3
    3-1-2-1
    3-1-3-1
    3-1-4-1
    3-2-1-1
    3-2-2-3
    3-2-3-1
    3-2-4-3 IRQ error.
    3-3-1-1 RTC error.
    3-3-3-3
    3-3-4-1
    3-3-4-3
    3-4-1-1
    3-4-1-3
    3-4-2-1
    3-4-2-3
    3-4-3-1
    3-4-4-1
    4-2-1-1
    4-2-1-3
    4-2-2-3
    4-2-3-1
    4-2-3-3
    4-3-1-3
    4-3-1-4
    4-3-2-1
    4-3-2-2
    4-3-3-1
    4-3-4-1
    4-3-3-2
    4-3-3-3
    3-Beep Codes
    Beep Code Meaning
    1-2-2
    1-3-2
    1-3-3
    3-1-3
    3-3-1
    3-3-2 CMOS error.
    on Dec 31, 2009 | Computers & Internet
    How can I translate the motherboard beeps on startup
    AMI Beep Codes
    Beep Code Meaning
    BIOS Beep Codes
    Phoenix Beep Codes
    4-Beep Codes
    Beep Code Meaning
    1-1-3-2
    1-1-3-3
    1-2-1-2
    1-2-3-3 DMA error.
    1-3-3-3
    1-3-4-1
    1-4-1-3
    1-4-2-4 CPU error.
    1-4-3-1
    1-4-3-2
    1-4-4-1
    1-4-4-2
    2-1-1-3
    2-1-2-4
    2-1-3-1
    2-1-1-3
    2-1-4-3
    2-2-1-3
    2-2-2-1
    2-2-3-1 IRQ error.
    2-3-1-1
    2-3-2-3
    2-3-4-1
    2-3-4-1
    2-3-4-3
    2-4-2-1 RTC error.
    2-4-4-1 IRQ error.
    3-1-1-1
    3-1-1-3
    3-1-2-1
    3-1-3-1
    3-1-4-1
    3-2-1-1
    3-2-2-3
    3-2-3-1
    3-2-4-3 IRQ error.
    3-3-1-1 RTC error.
    3-3-3-3
    3-3-4-1
    3-3-4-3
    3-4-1-1
    3-4-1-3
    3-4-2-1
    3-4-2-3
    3-4-3-1
    3-4-4-1
    4-2-1-1
    4-2-1-3
    4-2-2-3
    4-2-3-1
    4-2-3-3
    4-3-1-3
    4-3-1-4
    4-3-2-1
    4-3-2-2
    4-3-3-1
    4-3-4-1
    4-3-3-2
    4-3-3-3
    3-Beep Codes
    Beep Code Meaning
    1-2-2
    1-3-2
    1-3-3
    3-1-3
    3-3-1
    3-3-2 CMOS error.
    Jul 26, 2012 | Sony VAIO PCV-RX850 (T99861067) PC Desktop
    What does 102 error code mean?
    If you are referring to a POST error.. one that appears when you first turn on your PC
    Error 102 indicates a system board timer failure
    You can try turning it off let it sit for 5 minutes then back on again... if it comes back you need a new system/motherboard
    Nov 17, 2010 | Computers & Internet
    What is the beep code asus p5ntws
    AMI (American Megatrends International) BIOS Beep Codes.
    AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
    BEEP CODE MEANING POSSIBLE CAUSE
    1 Beep (No video) Memory refresh failure Bad memory
    2 Beeps Memory parity error Bad memory
    3 Beeps Base 64K mem failure Bad memory
    4 Beeps Timer not operational Bad motherboard
    5 Beeps Processor error Bad processor
    6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
    7 Beeps Processor exception Bad processor
    8 Beeps Video memory error Bad video card or memory
    9 Beeps ROM checksum error Bad BIOS
    10 Beeps CMOS checksum error Bad motherboard
    11 Beeps Cache memory bad Bad CPU or motherboard
    Award BIOS Beep Codes
    Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
    1 Long, 2 Short Video adapter failure Bad video adapter
    Repeating (Endless loop) Memory error Bad memory or bad connection
    1 Long, 3 Short Video adapter failure Bad video adapter or memory
    High freq. beeps (while running) CPU is overheating CPU fan failure
    Repeating High, Low beeps CPU failure Bad processor
    Phoenix BIOS Beep Codes
    Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
    Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
    1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
    1 - 1 - 3 CMOS read/write failure Bad motherboard
    1 - 1 - 4 BIOS ROM failure Bad BIOS chip
    1 - 2 - 1 Timer failure Bad motherboard
    1 - 2 - 2 DMA failure Bad motherboard
    1 - 2 - 3 DMA failure Bad motherboard
    1 - 3 - 1 Memory refresh failure Bad memory
    1 - 3 - 2 64K memory failure Bad memory
    1 - 3 - 3 64K memory failure Bad memory
    1 - 3 - 4 64K memory failure Bad memory
    1 - 4 - 1 Address line failure Bad memory
    1 - 4 - 2 Parity error Bad memory
    1 - 4 - 3 Timer failure Bad motherboard
    1 - 4 - 4 NMI port failure Bad motherboard
    2 - 1 - 1 64K memory failure Bad memory
    2 - 1 - 2 64K memory failure Bad memory
    2 - 1 - 3 64K memory failure Bad memory
    2 - 1 - 4 64K memory failure Bad memory
    2 - 2 - 1 64K memory failure Bad memory
    2 - 2 - 2 64K memory failure Bad memory
    2 - 2 - 3 64K memory failure Bad memory
    2 - 2 - 4 64K memory failure Bad memory
    2 - 3 - 1 64K memory failure Bad memory
    2 - 3 - 2 64K memory failure Bad memory
    2 - 3 - 3 64K memory failure Bad memory
    2 - 3 - 4 64K memory failure Bad memory
    2 - 4 - 1 64K memory failure Bad memory
    2 - 4 - 2 64K memory failure Bad memory
    2 - 4 - 4 64K memory failure Bad memory
    3 - 1 - 1 Slave DMA failure Bad motherboard
    3 - 1 - 2 Master DMA failure Bad motherboard
    3 - 1 - 3 Interrupt controller failure Bad motherboard
    3 - 1 -4 Slave IC failure Bad motherboard
    3 - 2 -2 Interrupt Controller failure Bad motherboard
    3 - 2 - 3 <RESERVED>
    3 - 2 - 4 Keyboard control failure Bad motherboard
    3 - 3 - 1 CMOS batter failure Bad CMOS battery
    3 - 3 - 2 CMOS configuration error Incorrect setting
    3 - 3 - 3 <RESERVED>
    3 - 3 - 4 Video memory failure Bad video card or memory
    3 - 4 - 1 Video init failure Bad video card or memory
    4 - 2 - 1 Timer failure Bad motherboard
    4 - 2 - 2 CMOS shutdown failure Bad motherboard
    4 - 2 - 3 Gate A20 failure Bad motherboard
    4 - 2 - 4 Unexpected interrupt Bad processor
    4 - 3 - 1 RAM test failure Bad memory
    4 - 3 - 3 Timer failure Bad motherboard
    4 - 3 - 4 RTC failure Bad motherboard
    4 - 4 - 1 Serial port failure Bad motherboard
    4 - 4 - 2 Parallel port failure Bad motherboard
    4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
    9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
    Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
    Xerox 3535 error code 102 372
    have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
    Oct 15, 2009 | Xerox DocuColor 3535 Copier
    Continuous beeping sound
    Do you get video? If so then it could be a stuck key on the keyboard.
    Do you get no video? If so then reseat the RAM.
    Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
    Cant' restore my computere error 102:4
    if you are restoring it then their is one solution for you
    1. RAM is short for your system upgrade it really this can help you
    this is happeneto also keep smiling like that6cde56a.jpgd to me also
    Nov 14, 2007 | Mercury P4VM800M7 Motherboard
    102 error
    As you probably already know this is a check that happens during the POST process and will halt the boot process. This is a system board failure, not typically user repairable.
    Nov 13, 2007 | Compaq ProLiant 1600 (315570-001) Server
    Computers & Internet Logo
    56 people viewed this question
    David Payne
    David Payne
