Question about GE GSS25SGMBS Side by Side Refrigerator
THE REFRIGERATOR IS NOT WORKING AND HR SIGN BLINKS ON TOP OF CONTROL PANEL
  • GE Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorTHE REFRIGERATOR IS NOT WORKING AND HR SIGN BLINKS - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
The fault warning sign is beeping when i open the fridge door
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 19, 2017 | Refrigerators
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
Both controls are at warmer setting but refer and freezer side still get`s to cold and coils ice up after couple days and have to hand de-frost
the A D C adapitve defrost control has failed and will have to be replaced . . the coil frost over when a defrost cycle doesn't happen every 8 hr of run time.. this control is located in top of fresh food side at the top in the back two screws hold it to the top cover . about 1/2 hr job / a d c is a pc type board in a plastic case . **** hope this helped ..
Jan 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Wont turn on, LED just blinking
Couldent find any help, pushed the small switch until display reacted then touched the touch fields one by one in order from top left until the display showed nine. Then beep it all worked again !
Gggenau offered a rep at 400-500 eur for this ! Shame on them !
S:DOlberg
Jan 15, 2009 | Gaggenau 28 in. CK 171 Electric Cooktop
The control panel light blinking and ice trap door will not close
Sounds like you need a new display pwb. The flapper for the ice works on a solenoid which is on a little board that is behind the display board. When the power is cut the flapper should close as it is on a spring. I don't believe that there is any worries of it catching fire. Have a tech come and replace the board for you.
Sgt 48
Jun 03, 2008 | LG LFX25960ST Stainless Steel French Door...
Maytag MF12568AEB refrigerator
the high voltage control board is bad. located on rear of machine.
Feb 15, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Control Panel going crazy
the motherboard likely needs to be replaced. this is a major issue with maytag side-by-sides and its likely that maytag makes that model for kenmore. Cross your fingers, call sears repair, and hopefully they can have it working again within the next month.
Sep 01, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
GE GSS25SGMBS Side by Side Refrigerator Logo
50 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
