Question about Ricoh Office Equipment & Supplies
When i photocopy something itcomes out black - Ricoh Office Equipment & Supplies
  • quennie732 May 11, 2010
    Does the scan lamp come on??? -Carl
  • 541 Answers
Make sure the lamp for exposure comes on. open th copier lid and make a copy. there should be a light that moves under the glass. if the light comes on and you still have black copies when the lid is closed you have a short. it can be a charge or a bias short. you would then need a tech
Posted on Oct 13, 2009
How do you make something bigger using this photocopier?
Use the zoom feature or enlargement , it will be on the control panel.
grab the manual from http://www.eserviceinfo.com/
Sep 30, 2010 | Panasonic DP-8020E Black and White Copier
When I photocopy I get a black line down the page, I am using a C
check the drum unit maybe the drum or the cleaning blade is the problem
Jan 04, 2010 | Canon PC-950 Black and White Copier
I have a problem with our HP3030 in that when I try to photocopy using the document feeder, the pages all come out with a double black line running down the centre of each page. The same problem comes with...
You're right. There is probably debris on the glass where the paper passes through. It's a common problem. You'll have to raise up the scanner so that you can see the glass. Then clean it off and you're back on business.
Apr 30, 2009 | HP LaserJet 3030 All-In-One Printer
Black ink not working on Brother Intellifax 1860C
All i needed to do, after messing with it non stop, was turn it off and reboot the machine. Simple solution! Thank god!
Apr 28, 2009 | Brother IntelliFax-1860C Plain Paper...
Photocopy has black band at end of the page
well ithink tou are using the ADF to copy something...you will have to clean the scanner glass(not the scan bed but when you lift the ADF cover you will see a scanner glass about inch wide)...it should resove your concern...
Mar 27, 2009 | HP Photosmart C7280 Printer
Jammed Photocopier
you need to remove the drum unit out of the machine,and take cotton rag use achohol ..rotate the drum clock wise until you see the label that stuck on it..
good lock
Feb 28, 2009 | Lanier Office Equipment & Supplies
Canon NP 1215s photocopier error code E0
did you check thermistor, I think that you have a problem with thermistor, not only thermoswitch! what about black copy - did you check is expo lamp (under the original glass) is lighting or not, if not - it's normal to have a black copy!
Success!
Jan 03, 2009 | Canon NP 6551 Black and White Copier
We have a Canon iR2200 photocopier in our office but unfortunately everytime it photocopies something thick black lines appear on the copy. Can you please tell me how to solve this without calling out an...
You may want to check your drum unit.and your developer unit
your drum may cost about 60.00 or above
and your developer unit may cost about 250.00 or above
you can also check for white-out left on the scanner.This can also cost problem on printing effect.
Good luck
Jul 25, 2008 | Canon Office Equipment & Supplies
Photocopier prints red
You might be running low on black ink and it's not an item when you print from your computer because the settings you are calling for are different. The computer asks you if you want to print normal...to best, etc.
Apr 25, 2008 | Dell 924 All-in-One InkJet Printer
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
