Question about Philips 23PF9945-37 23" Flat Panel LCD Monitor
Vertical portion pixelats then forms solid vertical lines. Problem intermitent but persistant. The tv is 2 years old, if its the lcd panel is it worth repairing?
  • 13 Answers
SOURCE: the screen has shrinked in horizontally and 2 vertical lines
Try repairing your monitors cable.
Posted on Dec 31, 2009
0 characters
1 Points
Vertical lines on screen looks very bad
maybe your TV have a deffective LCD PANEL,cause those are the systoms of the deffective lcd panel..better to put your unit the nearest service cnter or well trained technician to do the job,,goodluck
Feb 25, 2012 | Samsung SyncMaster 740N (Silver) 17 inch...
LN32A450 Flat screen has a shadow line about 10" long on the Screen The TV was purchased about a year and a half ago
if the line is vertical it means the LCD panel is defective or a contact to it is loose.
May 25, 2010 | Samsung LN32A450 LCD Monitor
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Vertical lines on left half of screen
The problem is the driver tabs that go from the panel controller board to the panel itself.
This is normally a fatal failure since having it repaired is extremely expensive.
Mar 17, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Screen has 1 solid bright vertical line
a mylar capacitor 0.22mf 100v may be shorted besides the flyback transfomer.
Sep 30, 2006 | ViewSonic G810 21" CRT Monitor
Philips 23PF9945-37 23" Flat Panel LCD Monitor Logo
42 people viewed this question
Top Philips Computer Monitors Experts
 Mike M
Mike M
Lawrence Oravetz
olayoju victor
Are you a Philips Computer Monitor Expert? Answer questions, earn points and help others
