Question about Kenmore Refrigerators
Frost building up in freezer - Kenmore Refrigerators
    President:
  • 1,304 Answers
Check all your door gaskets,
check to ensure you have good air flow into refer
Posted on Oct 06, 2009
Why haier freezer is beeping
Either way if you had the doors opened a lot, it should like you probably have frost build up preventing proper air flow. You'd need to pull everything out of the freezer and remove the lower back panel inside the freezer. If there is frost build up, you'll need to use a hair dryer to thaw all the frost out. The unit will continue to beep until the set temperature (0 and 38) are reached so that could take a while even after thawing out all the frost build up.
If removing panels sounds like more than you can handle, you can always unplug the unit for 24 hours and leave the doors open to allow the unit to defrost on it's own.
Oct 16, 2016 | Haier Freezers
How do you make a freezer frost free?
Frost free means that the evaporator coil will not accumulate a thick layer of frost. It will not prevent frost from accumulating on the walls of the freezer. To slow down the amount of frost build up inside the freezer, do not keep the freezer door open for any longer than necessary. The freezer door seal may be defective. This would allow moisture in that would freeze on the inside walls. A heater with timed intervals to come on is one way for a frost free feature. But this will not work for frost build up on the inside walls of the freezer. It would only melt the frost and then it would refreeze again.
Aug 31, 2015 | Frost Freezers
Why do I have frost build up in my bottom freezer compartment?
It could be the freezer is over-stocked and air cannot circulate but often it signals an excess of water vapour is getting into the freezer from overuse or a faulty or misaligned door seal or from unwise use of the freezer.
Frost build up in one part of a freezer could also mean a part of the insulation is failing.
Feb 20, 2015 | Frost Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Excessive frost- maybe door won't close well Builds up on to shelves the worst--could it be the rubber seal
First you must fully defrost your freezer. Frost simply attracts more frost. A build up of frost large enough to prevent the door closing properly will grow very rapidly indeed and waste a lot of electricity; it will also overload the compressor and can cause it to fail prematurely.
If the seal is damaged then it will allow moist air in and cause frost. If the seal has simply become unseated, then refitting it will prevent a recurrence.
Unless you have a frost-free model, then all freezers eventually need defrosting. You can slow the process by never opening the freezer door unnecessarily and also by never leaving it open any longer than necessary. Frost free models rely on air circulation via a fan to prevent frost build up. If the fan fails, or if the freezer is overloaded and so preventing air circulation then it will still frost up.
Please take a brief moment to rate my answer.
Sep 12, 2010 | Canon PowerShot S1 IS Digital Camera
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Freezer builds up with frost about every 60-75 days. have to empty the freezer and allow to thaw for a few hours
I think I can assume the freezer isn't a "frost-free".
A short physics lesson; hot air holds more moisture than cold air; hot air will flow from a warm area to a colder area, and the colder area will cause the moisture to condensate and freeze(if colder area below freezing, as a freezer should be), causing frost build up.The more often the freezer is opened, the more frost will build up.
Now for 3 possibilities:1) If it is a self-defrosting type, check your defrost timer control...not working, or not working often enough.2) Door seals damaged and need replacement.3)Make the kids stay out of freezer.
Mar 07, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
Jun 20, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Sep 22, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
