Question about Maytag Neptune MDG5500AW Gas Dryer
All the LED ligths ON
My neptune tripped the circuit breaker and when I reset it all the lights on the panel started to blink and stayed on. Nothing seems to work please help.
In the back of the display panel. remove the metal cover with the dryer UNPLUGGED.There is a booklet that tells you how to access the service mode by pressing 2 certain buttons at a time certain dryer functions can be accessed. One of the tests were to check the led lights on your control panel, when you run the test all the lights would light up. it's a possibility if you acess the service mode and run the led light check it could possibly reset it and solve your problem. It's a shot but it can't hurt. Getting into the service mode to test certain modes on your dryer is easy enough.Just read the instructions. Good luck.
Posted on Jan 06, 2008
The control panel on my oven doesn't seem to be working. I pressing COOKING MODE for 5 seconds and nothing happens. The display just blinks once in a while.
In the power panel on your house. There are two circuit breakers with their handles joined.One of these breakers has tripped internally which will stop the heating elements but not the control panel or oven light since they work on 120 volts. Reset the breaker or replace it.
Feb 02, 2016 | Bosch Ovens
When I press the power on the on ligth does not come on,and the dryer does not come on,befor when i press the power on the ligth blink for a secon and go out, and now when i press the power on nothing
The first think you need to do is check the circuit breaker. If the breaker is off, turn it all the way off and then to the on position. If it trips off again, you have a short in the wire. DO NOT plug anything into the outlet. It is a 220 line and you can be seriously injured.
Another issue could be the circuit board is faulty and the machine will prevent itself from turning on. If the breaker is good and the machine still does not remain on, you will need to call a service technician for the dryer. Good Luck!!
Dec 13, 2014 | Dryers
What does the ambere (yellow) light on the breaker mean when you turn it on or it trips out and you reset it
If the Siemens 20Amp 1-pole arc-fault circuit breaker is wired correctly and there are no problems with the circuit that it is protecting, when first turning it to the ON position, the amber light will come on then go out after about 10 seconds or so.
If the breaker is wired incorrectly or there is a fault in the circuit the amber light will stay on.
Nov 07, 2010 | Siemens 20Amp 1-pole arc-fault circuit...
Switch stuck in trip mode
The reason why the breaker stays tripped is a result of a direct short. Unplug every electrical device plugged into an outlet in both rooms and try the breaker. If it stays on, individually start plugging in each device until the breaker trips, that is the defective device. If the breaker stays tripped, start checking wall outlets for short circuits with an ohm meter. If you did not find a short, check your hard wired lamps and appliances for shorts. If you did not find any shorts the only other problem is a shorted pair of wires in the wall or ceiling. You will need to disconnect any hard wired lamps and appliances and check for shorts between individual pairs of hot (black) and neutral (white) then hot and ground. I have a short circuit finder, but you do not need one because the technology is not perfect and you may have to manually check for shorts with a meter anyway which never lies.
Jun 25, 2010 | Square D Co. HOM130 Circuit Breaker
Good Morning. The downstairs lights are not working.I checked the fuse box[Hager]and the fuse swich was off for the lights,i flicked this back on thinking lights would come back on [apart from supposed...
I assume you mean circuit breaker when you say fuse. If you reset the breaker to "on" and the lights still don't work, look for a GFI outlet somewhere in the circuit. It could be tripped which will shut off the current downstream from it if it is set up to guard the downstream circuit.
May 26, 2010 | Electrical Supplies
20amp breaker tripped unexpectly tonight. tried resetting at panel but won't click all the way over and little red indicator also on the breaker
Hello, In order to reset circuit breakers that have tripped under load, you must first flip the breaker all the way OFF, before you can then turn the breaker back ON. This should reset the breaker to turn the power back on to the circuit supplied by this breaker.
The red indicator is just there to make it easier to find the tripped breaker. Typically, the red indicator flag is a special feature of Square D QD breakers and panels.
If the breaker immediately trips again and doesn't stay on, then the device it is providing power to, still has a fault and it needs to be looked at to determine what is causing the fault and the tripping of the breaker.
Be sure to turn the breaker OFF if you are going to check the device for potential problems.
I hope you find this Very Helpful and best regards!
Nov 13, 2009 | General Electric 20amp 2-pole GFI circuit...
Circuit breaker trips after 10 minutes
could be a weak breaker,or poor high resistance connection from panel to dryer plug, then have someone check the current draw on the dryer while operating and see if it's within specs of the machine tag, if it's higher than that you may have a defective motor or heating element to case causing a higher than normal current draw
Nov 09, 2009 | Maytag PYE2300AY Electric Dryer
We had a thunderstorm last night and power blinked for a second or two, but never went off for any amount of time. Later, I discovered that a couple of my breakers were tripped (sockets & lights) and I...
Hi There,
It certainly seems like you got a large power surge. Something may have been fried on your oven control panel. The trouble is circuit breakers are meant to trip when there is an overload or short circuit situation. Good ones will also detect an earth leakage problem to save us humans from being electrocuted.
Unfortunately in general they are not surge protectors. That is they will not trip quick enough to save your appliances if 10 zillion volts suddenly comes down the wire.
I think you are going to need a service technician for this one.
Good luck
Aug 06, 2009 | Kitchen Ranges
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Jul 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MDG5500AW Gas Dryer Logo
226 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
