Question about Dryers
GE dryer model # DDE7200RALWH will not start. Will initially begin to run when start switch(button) is depressed but stops after the switch is released. Timer appears to be working, you can hear it ticking.
    President:
  • 1,922 Answers
Check your motor terminals for tightness and good connection otherwise its the motor run windings itself are defective
Posted on Oct 09, 2009
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
My GE dryer DDE7200RALWH. Just quit working after 20 seconds. I double check to make sure the door was closed the settings were correct yet that was not the problem. I did smell as if something had been...
You may encounter an overheating situation . One thing that may cause the problem...LINT... your wire mesh air filter you should be cleaned frequently. First remove your filter and clean it with dishwasher soap and hot water...this will remove the invisible film deposit by the Fabric Softener Sheet also called Feecy sheet and this will allow air to freely escape thru the filter . Make sure your exhaus hose is free from lint and also the escape channel scoop where your air filter is located. Now we have cleared one situation. The overheating is protection is controlled by a thermal switch located on the top of the door, you may gain access to it by removing the top panel with a kitchen knife depressing the panel holding clips.
Hope this was helpful.
Aug 19, 2017 | GE Dryers
Door seems slightly out of alignment and machine wont start.
manufacturer & model number? seems like the door switch (push button) if there is, is not totally depressed when door is closed. if the door hinge mounting screws are accessible you might be able to realign the door. loosen the screws, temporarily put a spacer to help line up (aligned) before tightening screws. (or tape a thin spacer on door to totally depress the switch)
Oct 08, 2015 | Washing Machines
Why does dryer only runs as long as start switch is depressed?
You give no information regarding make or model, but I believe you will find that the "run switch" on the motor is not working. This is a centrifugal switch located in or attached to the motor. With make and model, one could track down the part and replace it.
May 08, 2014 | GE GTDP300EMWS Dryer
Ge cycle electric dryer model number dde7200ralwh
take a neddle and put it in your reset button now you will lose your games but it worth it
Jan 02, 2014 | General Electric Dryers
GE commercial coin op dryer only runs when start button is depressed. The second you let off the buton the dryer stops.
hows the timer unit on doing when you push on it the timer is suppose to start..
Apr 15, 2011 | GE Dryers
GE Model DDE7200RALWH squeaks like a metal on metal sound.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 24, 2010 | GE DBSR453EBWW Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryers Logo
267 people viewed this question
Top Dryers Experts
