Question about Kitchen Appliances - Others
How can i get the tamper light to go out, so i can reset my alarm on the cooper menvier 9448+ alarm control panel
  • 37 Answers
Find out where the tamper fault is. This panel has tamper monitoring for external bell remote keypad zones and cover. Check all devices for loose covers ,wiring for breaks (especially if new carpets fitted) and bell box.You can check for continuety with a multimeter inside the panel you should have a short between A/T terminals and between 0v and TR if not check the wiring.
HTH
Posted on Nov 08, 2009
15 year old micromark intruder alarm need to switch off
Not really enough info to give you an answer, but I can generalise...
You say Knocked alarm box with ladder alarm started"
If the fault is there permanently from when this happened there's a good chance that you have disturbed the tamper spring/switch on the cover of the alarm unit. when the front of the panel is removed you should be able to see the Sping/switch which is automatically depressed by this front panel, you may find the spring has fallen off the switch or gone out of alignment, refitting / realigning it should remove the tamper fault once the lid has been refitted properly. As for "bleeps when doors, windows opened"
This sounds like the "Chime" feature has been switched on and without the manual I cannot tell you for sure how to switch it off.
Chime is a feature which "Chimes" when a door is opened (Not often used on windows), if this started when the ladder fell on the panel it is most likely just a single key press to switch it off, Once the tamper fault is sorted you should be easily able to find the correct key press to turn the chime feature off.
Sorry for being a bit general but I don't have that particular manual. Hope the info helps you :o)
Mar 20, 2017 | Home Security
Hi, my house alarm ready light is not on since I opened the anti tamper box, when the box opened the alarm went off, I put in the entrance code number, the alarm went quiet, since then the ready light
Hi Terry,
Most alarm systems require you to reset the tamper alarm.
Most systems will reset the tamper simply by arming the system and then immediately disarming the system. However, you MUST make sure that the Tamper circuit you tripped is closed. If you removed the cover on the panel, make sure the tamper switch for the cover is in the correct position and that the cover is pressing the switch and closing its contacts. If you are trying to arm the panel with a cover off, the tamper circuit will not reset unless you defeat the tamper switch. Just make sure you remove the defeat when you replace the cover. You may also wish to try a google search on the type and model of panel you have so you can download a copy of the manual to check on the reset procedure. We also need to know what brand and model the panel is so we can help you further..
Nov 26, 2014 | Cars & Trucks
Turn off tamper on gardtec 350 so I can fix socket
If you are disarmed, you should only get a trouble signal when you remove AC power, This should clear when power is re-established. The tamper is a switch inside the panel that trips when the door is opened. This too should be only a trouble if the panel is not armed. (Unless the tamper is programmed for instant alarm like a panic or fire alarm input.) Check your manual for the programming instructions for bypassing or disabling the tamper. Another thing you can do is disconnect the backup battery before removing the AC power, this will stop any alarms, but you should notify your monitoring company first.
http://www.innovatealarms.co.uk/pdfs/GARDTEC350+ENGINEER.pdf
Nov 08, 2014 | Home Security
Gardtec 370 repetitive bb tamper alarm
Yes any bell box will do. Just note your terminals.
you can link out the bellbox tamper from the control panel as a temporary measure until you replace the bellbox, assuming its faulty
Apr 12, 2014 | Home Security
Menvier mf 400 cooper
Try re-seating the CPU, CMOS battery and memory. Not sure if you have a signal light on that board ? If you still have the same problem, check the power supply for correct voltages.
Hope this helps
Keep in mind, if you are not receiving the 3.3, 5 and 12 volts you will run into problems.
Also, when trying the above.. disconnect any external devices and internal cards, such as Video, USB, fire wire, modem ect.
Apr 04, 2014 | Computers & Internet
Skylink sc-100 goes off when i input pin
The question is unclear. There are several possible cause for the control panel to go off after entering the PIN.
The control panel gives user four chances to enter the correct password. After the forth wrong password entry, the control panel will go off.
There is a silent alert command in which the control panel will activate the dialer and/or external siren alarm but the control panel remains silent. This is useful under duress condition.
The control panel has a tamper switch. If the control panel is disarmed, it will be ignored. If the control panel clamshell is opened and then the system is armed, the alarm will go off. The tamper switch prevents the burglar's attempt to remove the internal backup battery to shut down the system.
Oct 09, 2013 | Skylink Group Skylink Sc-100 Security...
I have a customer with an older Vista 100-12 Combo Burg / Fire Panel and he wantes to tie three tamper switches for PIV and OS&Y to zone 2 of this panel. Is this legal?
negative all os&y should be on their own zone. they are programmed differently. A panel tamper is just a tamper alarm supervisory alarm.
Apr 09, 2013 | Honeywell Ademco Vista-100 Fire And...
Airbag light has come up
Did you check the fuse panel? I see you've reset it, seems like its a fuse or short in your wiring somewhere. Check all the wiring or have someone look into if for you.
Mar 06, 2013 | 2002 Mini Cooper
I have a mini cooper & cannot find the book - round dashboard control has 7 circular lights above speed controls - the 2nd one in from the right just turned orange and fashing when I was on my way home...
Check your tire pressure. One of your tires has lost enough tire pressure to trigger this alarm. It could also be a puncture by nail or something. Once you've checked your tire pressures and set them all to desired pressure (30psi - depending on tire model and passenger occupancy) you can reset this alarm by pressing and holding down the button (apprx. 10 sec) located on the front of base of the emergency brake (same symbol on button as alarm). Blinking yellow light will stop blinking and stay on (this is when you can stop pressing the button), but eventually, shortly dissappear. I think the alarm is triggered by a difference of 4-6 psi which can aso be affected by climate change (warmer to colder season or visa versa).
Oct 19, 2010 | 2007 Mini Cooper Convertible
Kitchen Appliances - Others Logo
439 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
