Question about Miele Novotronic Premier 500 Front Load Washer
Not working washing machine
After being told by Miele to push the start and on/off button together to try to sort out spinning problem, now when we switch machine on to do wash we push on/off button and start it just runs though all the lights but doesnt actually start. The water is connected and the valve is on.
  • Anonymous Mar 16, 2014
    When I switch on the machine, all buttons lights on and it is not working. Only OFF button and ON button is working.
  • Anonymous Mar 23, 2014
    Start/Stop button is not working and is not lighting up and I can not start Washing. Machine door does not open.
  • 16 Answers
Sounds like it's either in demo mode or you changed something when you went into programe mode. Handbook should tell you about how to get in and out of demo mode.
Posted on Feb 08, 2008
Out of balance when spin starts
Hi dear. Your machine needs new shock absorbers and drum tension springs replacement. I can advise to contact your local Miele center. Thanks.
Apr 01, 2016 | Miele Washing Machines
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
How to reset beko wm5120w washing machine
You need to get the dial to 90 degree program then push the start and on button together. Keep hold the start button then a light will flash. Then move the dial to spin/drain option and press start to start the reset test mode. Hope this helps.
Aug 17, 2012 | Beko Wm & Wma Models Washing Machine Motor...
Unable to find an english operating manual for a miele w822 washing m/c
Hi Dear. I assume this machine made for Nederlands - Dutch market. You can not obtain English manual for it. You may contact your local Miele center. They may able to supply you translated copy of user manual. Thanks.
Note: What I can understand from control panel, buttons from left to right : Door Button - On/Off - Pre -wash - Water Plus (adds more water)- Gentle wash and Short wash then Final spin speed selector.
Right hand side Program & wash temperature selector (Clock wise): Cottons - Minimum Iron - Delicate - Wool - Starch - Spin only - Pump only & Mini Program (Quick Wash)
Mar 07, 2012 | Miele Washing Machines
Miele fault F63
F63 on certain washers is an indication of too much soap is being used. If you live in an area where the water is hard and your not using too much soap you have a clog in one of the hoses used for air. Try to do a hot cycle with white vinegar. On other models the F63 is indicating that the water intake valve didn't find it's position. If this is the case just run an additional cycle.
Jan 21, 2012 | Miele Washing Machines
How do I fix a F53 fault ona Miele W1712 Washing Machine
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore.
The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models.
May 01, 2011 | Miele W1926A Front Load Washer
Cannot get my miele washing machine off demo mode
Press and hold down the start and the on/off buttons together until the display says ' d off ' then release them.
If this works pl giv me a "very helpful" rating.
Oct 24, 2010 | Miele S318 Bagged Canister Vacuum
Won't spin and drain
check the switch for the lid. the machine will not spin or drain if it thinks the lid is open. use a screwdriver or ink pen to push on the little lever. the lid has a small stick of some sort sticking out. the lever is in the hole that the stick normally goes into. the lever should click each time. if not, replace it. good luck
Nov 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
the applionce is in demmo mode and running a test cycle so you need to cancle the cycle first by holding the start reset button until all the screen iluminates(88:88) now you need to disable the demo mode by holding the start cancle and the on off buttons together until you see D OFF in some cases you may need to hold the button to the top left of the screen and the start and on off buttons but this will sort it
Feb 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Miele Novotronic Premier 500 Front Load Washer Logo
803 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
