Question about Panasonic Lumix DMC-FZ18 Digital Camera
Hi I have the problem with the charger Whenever we put the battery in the charger for charging the indicator on the charger turns on green but after few seconds turn off. It is stated in the manual when the indicator is off it means the battery is fully charged but when we put the battery in the camera it shows low battery the battery and the charger are new can you please suggest the solution
3 Suggested Answers
Delphi51
  • 33 Answers
SOURCE: Battery Wont charge
I have the DMC-TZ1. The charger is labelled "Panasonic DE-A25 battery charger". It has 3 contacts where the battery fits in. With no battery in place, the voltage between the top and middle pins is 2.61 V. The voltage between the middle and bottom pins is 2.19 V. Check those voltages. If they are very different from mine, I rather think the charger is not working. You can buy the batteries for very low prices on ebay from Hong Kong and other asian sources, but I've been told by someone who tried them that they do not work. Perhaps you have run into one of those. If you can find someone else with the same battery, a quick swap will tell you if your camera is okay. I got my camera on ebay and it works perfectly.
Posted on Sep 10, 2007
  • 300 Answers
SOURCE: My battery charger stopped charging the battery.
How long do you have the camera?
Rechargeable batteries don't last forever, and when they are too weak to take a charge, the little light just blinks.
They could also be shorted out.
This flasing is a problem code. "The book" should also tell you what these flashes mean, although it usually means: replace the battery.
Posted on Jun 25, 2011
Testimonial: "I've only owned it for 6 months but will try replacing the battery as suggested. Thanks."
My galaxy 4x battery was like down to 2%. I plugged the charger in and it looked lik the little charging symbol was on. Then i powered it off and left the charger in and no green battery indicator cam
Hi, leave your phone down with the charger plugged in for about 15 mins, don't try to turn it on...only after 15 mins. I hope this helps :)
Jan 30, 2015 | Symbol Cell Phones
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
Does power switch have to be on when charging with on board charger?
Laptops that I have worked on do not need the laptop to be switched on to charge the battery. There maybe a LED indicator on the laptop to indicate that the battery is charging when the power adapter is connected.
Feb 19, 2012 | Computers & Internet
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
CHARGING A COOL BATTERY PACK
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
Compaq nx 9020 battery charging problem
Damaged battery or internal circuit problem it is hard to to say. Bring your laptop to a repair shop. They can check the battery and tell you what the problem is.
Dec 04, 2008 | HP Compaq nx9020 Notebook
Battery pack or charger
Hi!
When you insert the battery , plug the power into the charger and the light turns ON (red or green) - the charger is OK. One indication that the battery is dead is when you charge it, after just a few minutes the full charge indicator will turn ON ( with Canon chargers the light for full charge is green). If that's the case, purchasing a new battery is the only option.
Have a nice day!
Oct 02, 2008 | Canon PowerShot SD600 Digital Camera
Rechargable Batteries Battery Charger
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Apr 24, 2008 | Universal Battery Charger Charges Multiple...
Problem with battery,
Sounds like your battery isn't taking a charge so I would say your battery is the problem
Jun 19, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Battery indicator/charging defect
Do you have a Treo desktop charger/sync cradle where you can drop the battery into the charger?
Jun 14, 2007 | Palm Treo 650 Handheld
Panasonic Lumix DMC-FZ18 Digital Camera Logo
19 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
