Question about GE GSL25JFPBS Side by Side Refrigerator
Water reservoir is frozen, how do I defrost? - GE GSL25JFPBS Side by Side Refrigerator
    President:
  • 1,304 Answers
Hair dyer
and then turn down your frezer by one setting and refer up by one
this should balance things out after 24 hours
Posted on Oct 06, 2009
My water stopped dispensing but I can feel air like it's trying
Sometimes the plastic tube is the door freezes. If you remove the front grill at the base of the refrigerator you should see a tubing disconnect.
these are fairly easy to disconnect either by unscrewing the plastic nut or pushing in on a ring around the tubing. if you disconnect this. just hit the water dispenser actuator for a very short time. if water comes out the tubing is frozen in the door and you will have to shut down the refrigerator for a while and let it defrost. if you don't get water there then perhaps the water reservoir in the refrigerator is frozen. It is located behind the crisper drawers.
Jul 24, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Water dispenser on fridge not working - water pressure fine, could the line be frozen and why would that start happening all of a sudden?
Check to see if the water reservoir in the bottom of the frig is frozen. If it is, you will need to turn the frig temp down.
Dec 04, 2012 | Refrigerators
Frozen water on the bottom of frezzer
Hi there, it sounds like the freezer needs to be unplugged and defrosted, now if it does this automatically which some do and the ice water that was frozen goes through a pipe and out through waste water outlet, after it is completely defrosted you should turn down the freezer dial by at least one digit and keep a check on this to make sure that its not over freezing and causing this problem, on some models the automatic defrost does not work as it should , and even when they do work it is not defrosted enough , so do it manually for a perfect job, note that any food that is in the freezer can be wrapped in news papers while the work is been done , they will be well frozen for the time it takes to defrost , you can speedup the defrosting with a bowl or pot of boiling water placed in the bottom of freezer, make sure that the water outlet is not blocked with food debris..
hope this will be of some help to you.
cassyjoe.
Nov 07, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Windscreen washer pump is frozen, cannot locate it to defrost, Also is there a winter setting on the engine?
If the washer reservoir is frozen, it must have been filled with plain water. It should be filled with washer fluid. Washer fluid contains alcohol to prevent freeze up. To locate the washer reservoir, look for the filler cap, it will say washer fluid on the cap.
Dec 22, 2010 | 1997 Toyota RAV4
On a GE side by side where is the water reservoir
I had the same problem. The line is frozen. GE will not admit there is a problem. I read a suggestion on line & followed up on it. I placed styro foam insulation on door inside the freezer compartment & no more frozen line & water flows freely.
Jul 14, 2010 | GE Profile PSW26P Stainless Steel Side by...
In-door water dispenser not working. tried lowering temp in frig to thaw line. Worked, but now line seems frozen again. ice in icemaker holder seems to be thawing and freezer is accumulating frost/frozen...
Defrost the freezer completely. Make sure the doors are sealed completely when shut. After defrosting plug back in and make sure the fan and the self defroster is functioning (your owner's manual should tell you how to reset the defrost timer). the problem may lay within the defrost system, and/or door seals and/or interior circulating fan.
Apr 30, 2010 | Refrigerators
Easiest way to thaw out a possible frozen water reservoir in my GE side by side fridge?
Hair dryer is the easiest way to thaw. To find cause: Remove lower grill and disconnect the water line going through the freezer2_bing.gif door hinge. Usually it is a push lock fitting, which requires you to push the ring2_bing.gif on the end of the fitting toward the center of the fitting while pulling (not hard) on the plastic tube. Now place a pan under the separated plastic hose and try the water dispenser. If water comes out, your problem is a frozen water line in the freezer door. A warmer freezer temp may help, or you can order and install a WR49X10173 water tube heater2_bing.gif. (the heater may take 24 hours to thaw the line, but I have used it successfully several times. Cost about $50) If no water comes out the separated tube when you try to dispense water, reconnect the tube at the hinge by pushing the plastic line back into the fitting. Now, at the back of the refrig., disconnect the water line going from the water valve to the fresh foods compartment. Try to dispense water. No water at valve outlet = bad valve. Water dispensed from valve now = frozen water filter2_bing.gif or water line at back bottom of fresh foods compartment. (make sure you disconnect the right tube. If in doubt, disconnect them both, just get them back correctly so your icemaker continues to work) Send me additional comments if needed. Don't rate before you try all the steps.
If water filter or water line/ reservoir is frozen, thaw with a hair dryer. If reservoir is frozen, check to make sure there is no frost on back wall of inside freezer, preventing normal air flow, allowing cold air to enter fresh foods compartment through return air vent at lower back of fresh foods compartment, resulting in freezing of water line / reservoir and possibly food in bottom bin.
Nov 18, 2009 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Water filter is not dispensing water
Plugged filter maybe, or frozen reservoir behind the crisper. Or a bad water valve. If the frig was very cold recently check the reservoir first...
Eric
Oct 10, 2009 | Whirlpool Refrigerators
Water dispenser not working ice maker is fine
The refrigerator has a dual water valve. The water dispenser side of the valve may be defective, but, my experience has shown the problem to be in the water reservoir, located in the bottom of the fresh food section, which, might be frozen or the water line through the freezer door is frozen. Scenario #1: Remove the kick panel, disconnect the water line from the fitting. Have someone depress the water actuator, while, holding a cup to collect any water which may come through the line. If water comes through the tube. The problem is a frozen water line in the door. My best advice for this problem is to remove any frozen goods from the door. Take a piece of cardboard and seal the freezer section of the refrigerator with any kind of tape. Make sure you tape the door switch in the closed position, so, the refrigerator will continue it's normal operation. The frozen goods will remain frozen and the fresh food section will be okay. Leave the freezer door open. You might want to put a towel under the door. The water line will thaw. It might take 15 minutes. It might take 3 hours. Periodically check the water dispenser operation. When the water flows remove the cardboard. Scenario # 2:if, after disconnecting the water line and depressing the water actuator there is not water. The reservoir is frozen. Use a hair dryer to that the reservoir. You will have to remove at least a couple of crisper drawers to perform this action. The cause of a reservoir freeze is too little stuff in the drawers or too low a temp in the crisper drawer area.
Jun 17, 2009 | Refrigerators
Ice maker line frozen
Use a hair dryer to defrost the tube. It is probably frozen because a leaking water valve. There is also a kit to to add a heater kit to some models. FOr more information call the factory at 800-222-7820.
Oct 02, 2008 | Sub-Zero 632 / S
GE GSL25JFPBS Side by Side Refrigerator Logo
467 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
