Question about Technics SL-1200 Turntable
My spindel barring tightend up. do i need to replace the barring or can i oil it? what kind of oil should i use?
  • 135 Answers
Damaged spindel
lock has been forced and will need to be opened and replaced
Feb 25, 2014 | Kwikset Locks & Locksmithing
Error code H03.
To my knowledge Panasoni Error Code H03 indicates mechanical failure, more specifically, the traverse servo motor. Simply stated, the eye cradle could no longer slide back and forth along the slider bar. Corrective measure requires cleaning and application of appropriate light lubricant. Vaseline oil would do for the time bieng. Pls refer to the diagram below.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 09, 2008 | Panasonic DVD-LS850
What kind of bar oil do i need what's called so i get the right one
Most Husqvarna chainsaws recommend using their brand of oil, which is a vegetable based oil product. If you do not have access to it, use standard bar/chain oil which can be found at any local hardware store.
Jun 02, 2012 | Husqvarna Garden
I need a manual for a new Poulan 3.5 electric chainsaw, or, failing that, I need instructions on what kind of oil to use on it, and whether I need separate oil for the chain.
You shouldn't need any other oil than the oil to keep the chain and bar guide oiled (pressing down on the button adds more oil to the chain/bar). You can use standard Bar and Chain Oil, or probably pay a little more and use the Poulan brand oil, but in my experience, any bar oil for chainsaws will work, and the larger the container you buy, the less per ounce you will pay. Remember this is NOT an automatic oiling system, so it will be cheaper in the long run to remember to press that button than to replace the chain/saw if it overheats.
Aug 29, 2011 | Poulan 14" Electric Chainsaw
What kind of oil goes in the bar oil hole?
Use CHAIN oil. Any oil will do but chain oil is thicker and sticky and will stay on the chain much longer. The price is much the same. Stephen.
Apr 23, 2010 | Homelite ZR10926 16 Chain Saw
On my 16in craftsman saw the oiler quit working
some times this can be something easy sometimes not just follow a few simple steps:
Have you replaced the bar and chain recently?
#1 Remove bar and chain and blow out all sawdust esp around your bar studs dont get to close with the air as you can sometimes pop seals...
Start your saw see if oil comes out around bar studs if so the oil holes in your cutter bar may be blocked...
#2 If that doesnt work remove your oil filler cap and use a piece of wire with a bend on the end to remove your oil filter remove it from oil line and clean in fuel and blow out with compressed air replace on hose and place back into tank and try start chain saw again...
if that doesnt work then take it in to small engine repair shop as the pump may be blocked or unservicable and need replacing
Hope this Helps
Kind regards
Brad
Jan 02, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
What kind of chain oil to use for a 10in remington electric
According to the manufacturer... "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." So, I suggest for any Remington electric chains saw not to use bar and chain oil. I hope this helps...
Jun 25, 2009 | Remington Electric Pole Saw
1994 sl1 saturn burning oil
Sound like you solver that problem...your the champ.
Jun 07, 2009 | 1994 Saturn Sl
Husqvarna chainsaw bar bolt loose and leaking oil
had same! was set to release the max amount of oil to bar, but the thread is only so long and will drop out of seat, send it for service and note the bar feeder srew, its faster and cheaper! good luck p.s great saw!
May 06, 2009 | Garden
Technics SL-1200 Turntable Logo
148 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
