Question about Samsung 4 Channel Dvr
SHR 1040 "Froze Up"
All 4 of the LED lights are on and I am unable use the recorder. "No Signal" appears on the screen and the manual lists no troubleshooting tips or fixes. I have tried unplugging the recorder for minutes and hours at a time and it makes no difference. Any ideas out there?
  • Anonymous Feb 24, 2008
    everything plugged in (RCA to TV, 1 camera, power) and all 4 LEDs are on and there is nothing on the screen
  • curtisalarm Jun 30, 2008
    Electricity cut off and when returned all four leds remain on.It froze up.i tried pressing mode and channel two for ten seconds but nothing happens
  • 174 Answers
Same issue here, all four lights on front panel remain lit. It seems to fail the CMOS start up test. Tried using the RESET button inside the unit on the mainboard, it blinks the lights but they remain on. Tried the white switch on the mainboard which made the Alarm and Record lights go out, but unit still does not function. Removed the CMOS battery and did the same RESET. No joy. All four lights come on immediately once plugged in. All three internal status LED's are on indicating working components. At a loss at this point and disappointed because this product has never worked quite right. At least now we know why it was half the cost of other DVR's.
Posted on Mar 17, 2010
Same problem here, too! All 4 LED's are lit. Turned off the unit for 1-week. Turned it back on. All 4 LED's are lit and no signal on my VGA monitor. Tried using the method of holding down the MODE button and Ch. 2 button both at the same time for 10 sec. No change. Also tried using the remote control holding down the MODE button abd Ch. 2 button both at the same time for 10 sec. Again - nothing. Still looking for a solution before having to send it into Samsung for repair (which I'd like to avoid if at all possible).
Posted on Nov 28, 2009
All lights on!!! same prob.. someone has got to know how to fix these. I have seen these models outt there anywhere between $225-400.00. I would rather fix the prob. Any genius out there.....
Posted on Aug 24, 2009
Same problem. all four lights lit. no display of vga or rca. holding mode and 1 or mode and 2 have no results?
is this baby fried???
Posted on Apr 17, 2008
  • 3 Answers
Unplug the DVR for 1 minute. Unplug from DVR from the video monitor. Plug back in, all four lights will come back on, then hold mode and channel two for ten seconds. If you just hold mode and channel 2 from the start it wont do anything. Hope this helps.
Posted on Oct 23, 2009
  • 4 Answers
You can try holding down mode and channel 2 at
the same time for 10 secs. This should reboot the recorder.
Posted on Jan 16, 2008
I changed the passwors of samsung shr-1040
•Factory Reset Hidden Key :
Mode Key + CH 2
•The Password and all setting
value will return to the initial
default value.
•Default Password is ‘4321’ .
mj
Apr 08, 2009 | Samsung 4 Channel Dvr
Samsung shr 1040 4 channel dvr
You have to hook it up to a tv monitor and change the settings through the menu. It will originally include a password just to get you on, then you will immediately have to change it. After you do that you can access the menu where you can change the output settings
Apr 05, 2009 | Samsung Home Security
I have a samsung home security shr-1040 and i tried to change my password and i must have put a different 4 digit code than i meant, i am now locked out and cannot access my settings.....please help
The manual says:
You cannot enter MENU by forgotten password.
- If you forget the password, you shall reset SHR-2160/2162/2080/2082 DVR to
the values set at the factory. Keep pressing both the "MODE" button and the
"PTZ" button on the left for 5 seconds, Keep pressing both the "MODE" button
and the "PTZ" button on the left for 5 seconds. The password default is "4321".
You can download the user manual here:
http://samsungsecurity.com/product/p_detail.asp?seq=94&sel_seq=64
Dec 25, 2008 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Trying to get hooked up
I made a hook up from the shr 1040 to a pc monitor using a VGA converter box. Cost less then 40 ( check amazon) and simple to use as well as still use your pc on your monitor,
Aug 27, 2008 | Samsung 4 Channel Dvr
Starts recording then stops
The manual says that it can be replaced with almost any standard IDE drive but mine has a Seagate 160GB drive in it so may want to stick with original equipment. Other than tha, any drive SHOULD work.
Jul 02, 2008 | Samsung 4 Channel Dvr
The samsung monitor ssc21web shows system initialize... the three periods blink
ssc21 web does not work, It was a cameras shut down it says LA and AL why
May 15, 2008 | Samsung 4 Channel Dvr
Samsung SMO 151QN need to purchase the proper recorder for this unit
We're using a Samsung SHR-1040 recorder with
a Samsung SMO 151 QN. It has more options than
needed ( has it's own camera ports) but it's cost
effective and records well. It has been in use since
July 2007.
Nov 26, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Playback on Samsung SHR-1040
you need a new hard drive.
Aug 27, 2007 | Samsung 4 Channel Dvr
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung 4 Channel Dvr Logo
654 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Colin Stickland
Colin Stickland
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
