Question about Philips Magnavox 9P6034C 60" Rear Projection Television
White halos and foggy screen.White is very bright
  • Philips Master
  • 3,459 Answers
This is a very common problem with Projection sets. The CRT fluid has clouded over. Typical symptoms are...
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
white halos and foggy screen.White is very bright - bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Oct 18, 2009
  • Philips Master
  • 8,457 Answers
U need CRT Coolant liquid,replacement,tries this website for it.Tv Repair World.com,Ebay.com
Posted on Oct 06, 2009
Colour fading bright halo type around white
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 20, 2010 | Philips 60PP9202 60" Rear Projection...
My tv ,whites glow way too bright,dark colors way to dark,what is wrong
These sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 08, 2010 | Philips 60P8342 60" Rear Projection...
My tv picture seems foggy, what do I do. I pressed the flash focus, little help. The convergence button, didn't really see any issue with the crosses
U needed CRT coolant,U have a halo white screen too?Try this wbsite.Tv repair World.com check it out buy and replace the coolant or convergence kit,must know how do soldering to change convergence parts.Or if u have any colors lines mismatch at all than it the convergence.
Nov 06, 2009 | Sony KP-51WS500 51" Rear Projection...
My 60PP93 5217 The white is very bright and the
You can carefully remove the rear top cover ( make sure it's unplugged) and carefully wipe the dust off the projection lenses and mirror and inside screen and stay away from the electronics and capacitors.Years of dust build up can blur the picture and give it a glarey picture.
Oct 17, 2009 | Philips Magnavox 9P6034C 60" Rear...
Excessively bright whites...has a haze around any white items. all other colors are fine.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look white,dull, red/orange, etc. You may even see white halos around images.
Here is a photo of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution
What you will need to do is replace the coolant and clean the crt lens. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos, step by step instructions, etc.
May 12, 2009 | Televison & Video
White halo fuzzes the picture on TV
Had the same problem with white glows. Followed the directions in this link and the white glows and color brilliance was fixed.
http://www.avsforum.com/avs-vb/showthread.php?t=1148792
Apr 07, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Convergence toshiba 50a62
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Nov 20, 2008 | Apex Digital GB5108 51" Rear Projection...
Green "halo" around the bright white images
I have a Samsung HCM5535W rear projection TV that had pretty much the exact same problem-- a green halo around bright white images. I researched it on the net, and determined the most likely problem was with the convergence STK-ICs, or the convergence board. I bought a replacement board with the STK ICs and installed it, but no luck, the problem persisted. I decided to mess with the manual focus adjustment on the green crt (i was seeing a green halo), and that fixed it. As it turns out, no replacement parts were necessary to fix the problem in the first place. Hope this helps somebody out there.
Nov 14, 2007 | Mitsubishi VS-50703 50" Rear Projection...
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
172 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
