Broken spacers and damaged teeth
I have broken spacers and now several of the teeth are getting damaged, can this be fixed?
    Genius:
  • 1,218 Answers
Assuming this is a Royal shredder you can call Royal at 1-800-524-0799. for parts assistance.
Posted on Aug 29, 2010
What causes damage flywheel on bmw is it common fault
-you mean broken teeth...? If so possibly crank the engine while it's still running.
Good Luck
Mai
Jan 07, 2016 | BMW X3 Series Cars & Trucks
Starter disengage
The teeth on the flywheel or starter drive could be damaged enough to cause sticking and it does not release. Another reason could be the clearance between teeth on the flywheel and starter drive are too tight. The starter would need more metal tabs or spacers to increase the clearance distance between the teeth on each one.
Mar 16, 2014 | Pontiac Sunfire Cars & Trucks
I have a 1988 jeep wrangler 4wd when I put it in 4wd really bad grinding noises happen it feels like gear teeth are getting broken off it is badd pleas
You cant fix this ... dont use the 4 X 4 mode and have a professional look at this before you do more damage.
Nov 05, 2012 | Cars & Trucks
Are there spacers on the starter of a1984 2.8 ford bronco 2
Ford does not use shims like a GM, the midplate between the engine block and the transmission should act as a shim. I would take a good look at the flywheel for damaged teeth.
Oct 02, 2017 | 1984 Ford Bronco II
Have replaced starter several times, now a grinding sound occures when try to start van.
You probably have a damaged flywheel. Take the starter off and using a socket on the front pully bolt, rotate the engine and look in the hole where the starter goes to inspect the teeth on the flywheel. If the teeth are damaged, the transmission has to come out to fix it.
Jan 15, 2011 | 2004 GMC Safari
Chain keeps slipping off saw
Remove the bar and chain. Lay the chain out on a bench or table and examine for sideways bent/broken links, badly damaged cutting teeth, or damaged drive teeth. Inspect the bar chain-groove all the way around for any damage. Make sure the tip sprocket turns freely and is not damaged. Check the sprocket on the clutch drum for hooked teeth or other damage. Clean the small oil passages that feed oil out to the chain groove in the drive end of the bar. Start the engine and check the engine side port where the bar fits to--it should ooze out oil from the small port there. If everything checks ok, re-assemble the bar and chain leaving the cover fasteners finger tight. Adjust the chain until it pulls up to the bar, but not so tight that you can't turn turn it by hand. Tighten the bar fasteners and re-check the chain tension. Start the engine and hold the bar tip near some cardboard--it should throw off a thin line of oil after several moments of running at speed. Hope this helps!
Jul 17, 2010 | Craftsman sears 18" Chain Saw Chain (...
Starter spins but will not engage flywheel...
Check the flywheel for areas of damaged teeth also. Broken teeth on the starter drive gear may inticate damage to flywheel also.
May 20, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Heater does not work
The temperature actuator behind the dash thats attached to the heater case is broken. The clicking is from a broken gear in the actuator. Replace the actuator and that will fix your problem.Good luck.
Mar 16, 2010 | 2000 Ford Windstar
I need the large main drive gear for the Fellowes PS60C-2
200$ shredder or a 6$ replacment gear ,,,, great advice
takes about 10 min to replace the gear too
Apr 05, 2009 | Fellowes PS60C-2 Shredder
Table saw blade wabbles alot when cutting?
This could be caused by several problems. First unplug the saw. Put a known straight edge against the blade (making sure not to contact the teeth) turn the blade slowly and watch for runout. Second make sure the spacers and blade flanges are on correctly. I would just about think it would be the blade. If you provide the model and brand I can do some more research. Good Luck
Jan 03, 2009 | Black & Decker DEWALT 12 In. 80 Tooth Thin...
204 people viewed this question
jasbo
jasbo
