Question about Canon i950 InkJet Photo Printer
Printer head alignment
When I print out the test pattern the first column of gray lines are all the same. You can see lines in them all. I cleaned the heads twice. It didn't solve the problem. The pictures are off color in reds and greens. Any suggestions?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm...sounds like either new ink in order, or the base for print cartridges is gummed up.
Posted on Aug 20, 2008
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
Printing problem
  1. Open the Printers folder.
    • For Windows XP Select 'Start', 'Control Panel', 'Printers and Other Hardware', and 'Printers and Faxes'.
    • For Windows versions other than Windows XP select 'Start', 'Settings', and 'Printers'.
  2. Right-click the printer icon to open Properties.
  3. Click the 'Maintenance' tab and click the 'Print Head Alignment' icon.
  4. The message below is displayed. After confirming the two points below, click 'Print Head Alignment'.
  5. The following message is displayed. Click 'OK'. Print head cleaning starts. The power lamp flashes during cleaning operation. Do not perform other operations. After cleaning has finished, the first head alignment pattern will be printed.
  6. The following message is displayed. After printing has finished, click 'Yes'.
  7. Refer to the printed sheet, and select the pattern with the fewest visible vertical stripes in column A.
    <1> Example of highly visible vertical stripes in the pattern.
    <2> Example of the fewest visible vertical stripes in the pattern.
  8. Enter the selected pattern's number in the Column A box.
  9. Similarly, enter the selected numbers in the boxes for column B to F.
  10. After all numbers have been entered, click 'OK'.
Apr 09, 2008 | Office Equipment & Supplies
MP970 Photo All-In-One InkJet Printer: The printer head alignment is off. I have tried to...
  1. Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Rear Tray or Cassette.
  2. Open the Paper Output Tray, and then open the Output Tray Extension. (1) Put your finger in the center of the top of the Paper Output Tray and open it gently. (2) Open the Output Tray Extension.
  3. Press the Paper Feed Switch to select the paper source where you have loaded paper.
  4. Print the print head alignment pattern. (A) Press the HOME button. (B) Select Settings , then press the OK button. (C) Select Maintenance , then press the OK button. (D) Select Manual head align , then press the OK button. (E) Select Yes , then press the OK button. (F) When " Did the patterns print correctly? " is displayed, confirm that the pattern is printed correctly, select Yes , then press the OK button.The input screen for the head position adjustment values is displayed.
  5. Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
  6. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
  7. Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
  8. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
  9. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
May 16, 2010 | Canon MP970 Photo All-In-One InkJet...
The 3eBK head stopped printing.
Try below some steps which might help you resolve the problem.
Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
    Handle ink tanks carefully to avoid staining clothing or the surrounding area.
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
    IMPORTANT:
    a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
    b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
  9. Close the Inner Cover 2.
  10. Close the Inner Cover 1.
  11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
Automatically Aligning The Print Head Position:
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
Manually Aligning The Print Head Position:
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (1): Bad example (Least solid box)
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
    (0): Select pattern number with most solid image
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
White bands on color photo prints
I hope it helps!!!
Nov 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Will not print 6BK
Please see the Canon link below, and as Canon links return generic pages, type in "missing black print" (without quotes) or something of that nature. The results will include Reseat/remove printhead, among others. I have reproduced that content for you below, but I would also add that a number of folks have issues with black print cartridges, and it seems this is an issue that is fairly widespread, as one of the results is that your printer may need repair. If you have tried more than one cartridge with the same result, suggest consulting support if you don't think your usage justifies a new print head - especially if you are still under warranty. Page link is:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444
---------------------From Canon-----------------------
Issue: How do I reseat / remove the print head?
Solution: Reseat MP750 / MP780 print head
    CAUTION:
    IMPORTANT:
IMPORTANT:
  1. Close the Inner Cover 2.
  2. Close the Inner Cover 1.
  3. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  4. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
    (A): Column
  8. Press <OK>.
  13. Press <OK>.
Please post back if you need additional help. Otherwise, thanks for rating FixYa!
May 15, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Colour printing
If the test patterns are not matching what your printer tells you is normal and your photos are banded horizontally, you may have clogged nozzles and printhead. Do a maintenace clean under your printers direction, and see if it now prints ok. Also, you may be low or out of one particular colour, but still have enough of the others and the printer will try to compensate by using available colours, hence colour banding and distortion. A manual clean with cotton buds and cleansing solution is recommended if the first clean does not help.
Dec 12, 2006 | Canon BubbleJet i560 InkJet Printer
Canon i950 InkJet Photo Printer Logo
44 people viewed this question
old marine
old marine
