When i start my laptop a black screen comes up and says windows can not start up because of a corupt file
  • 3,940 Answers
First thing I'd do is run diagnostics on the hard drive. Often a failing hard drive will cause software errors and there is no point in troubleshooting a software error on a failing drive.
If diagnostics pass, then you can try booting to Recovery console from the Windows CD (Press R at the 1st prompt in the windows setup) and run the command CHKDSK /R
Posted on Oct 06, 2009
    President:
  • 2,600 Answers
Windows Start-up Errors
Step one, you need a Windows XP CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work. You can order a boot up floppy disk from here: http://support.microsoft.com/kb/310994 with this file, if you know how, you can use “ImageBurn” to burn the file into an ISO file which can be burned to a disk. Now make sure your computer boots to the cd rom first. If you know how to do this skip on down, if you don’t, while the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
WHERE CAN I GET A ORIGINAL WINDOWS 2000 START UP AND REPAIR DISC FOR MY Toshiba TECRA8000
When booting up select the F4 key. When the system menu comes up use the up and down arrows to select "LAST KNOW GOOD CONFIGURATION". Hit enter and you should be good.
Sep 12, 2014 | Computers & Internet
Start up
First I will suggest you to Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen
After that restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in safe mode then update your graphic drivers from the manufacture site of your laptop
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files , fix registry and windows errors which causing black screen
Jul 04, 2013 | HP Pavilion DV2910US Laptop
Dell laptop latitude e4300 - screen goes blank after starting Windows
Windows files are corupt or the hard drive has issues, try and reload operational system if disc is available, have the hardware checked if unable to load.
Oct 26, 2012 | Miscellaneous
Laptop cannot run windows ,keeps trying to run but keeps returning to start windows or goto safe mode or start from most recent workable point. says some file missing or corupt and cannot load hive file?
This means that your laptop operating system is corrupt you will need to restore it using the recovery console on your laptop. You should be able to access this by pressing the F11 key when you power on your laptop from the post screen. Some laptops use the ALT and F10 together ie. acer and packard bell. But most use F11. If you laptop will not recover using the recovery console you will need to replace your HDD (Hard Disk Drive).
Hope this helps if you need more help just ask.
Feb 22, 2011 | Computers & Internet
Error select r at the first screen to start repair
try booting from your windows installation DVD and go on with system repair option, if problem not solved, you have to reinstall your windows.
Jan 06, 2010 | ASUS Eee 4G Notebook
Ive deleted some important files on my windows 2000 laptop and now it turned off and comes up with a black screen sayin corupted and missing how do i repair it step by step plaese
I boot menu insert the OS disk
Click repair comuter
follow instuctions on screen
windows 2000 is a bit old bu yourself a new laptop with Vista or 7
Sep 24, 2009 | Microsoft Windows 2000 Professional for PC
Blue screen on my laptop, circle cursor just keeps spinning.
Try to reinstall you OS it might have corupted file or virus
May 11, 2009 | Toshiba Satellite P105-S6177 Notebook
Open Questions:
Cloud storage and file storage - DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
Jul 20, 2018 | Quantum Computers & Internet
Computers & Internet Logo
250 people viewed this question
David Payne
David Payne
