Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Getting no current power cord is plugged in and have current at box
    President:
  • 3,197 Answers
Remove the cover and check for power at the other end of the cord. Also remove the logic board and check for burnt or missing traces on the printed circuit board especially around the small transformer.
Posted on Oct 06, 2009
What is power brick cord?
An AC adapter, sometimes called a power brick, is a little box that takes the Alternating Current (AC) line voltage from your house receptacle and converts it into a Direct Current (DC) voltage that is used by your electonic device (computer, hard drive, etc.). This power brick sometimes has a separate power cord that is removable from the brick. This cord usually connects to your house receptacle, and sometimes it is a standard cord with standard connectors on each end.
Nov 10, 2013 | Pacific Digital (U30274) DVD±RW...
Wont come on
Is the power cord plugged in correctly to the wall and the box? Are you sure that there is power at the wall outlet? Is the power cord broken or in any way not carrying the current to power the box? It could be in the switch. The worst would be the internal amp that is malfunctioning.
Sep 19, 2012 | Audio Players & Recorders
I don't see a power cord - does it need to be hard wired?
Many appliances do not come with a power cord. This leaves the option to the consumer to either hard wire to a terminal box, or purchase and install a power cord. You can purchase a three-prong power cord from any major hardware store. Power tool replacement cords work best, because they handle current well and have thick insulation to prevent chaffing. A good 15 to 20 amp cord is recommended. Whether you hard wire, or add a power cord that you can simply plug in, the wires as terminated as follows (U.S. Standard):
WHITE - NEUTRAL
BLACK - HOT (120VAC)
GREEN - Ground - terminate to ground lug
If you have any questions, please post back and let me know. I hope this helps you.
Apr 11, 2011 | Dishwashers
Dell a960 power cord
The Dell printer has a plug-in power supply, not just a power cord. It's a box that plugs in to the almost-rectangular opening on the bottom right back side of the printer. If you do a Google search for "a960 power supply" you'll find several sources for replacements. Here is an eBay auction currently running with a total price of under $20. Other sources are in the $30 to $40 range.
May 09, 2009 | Dell A960 All-In-One InkJet Printer
Burning smell
Hello benson131,
Based on your description, you already identified the problem as being a bad power cord. There is a high probability that the place where that cord is wired into the back of your dryer that the terminals worked themselves loose. Loose terminals become resistive and do not allow adequate current flow to maintain dryer temp so more current is required and that additional current will cause the insulation to melt on your power cord. I suggest you do the following. First off, unplug that cord from the wall recpetacle. Determine if you have a 3 prong or 4 prong plug. Go to a local home goods store like Home Depot or Lowes to get a replacement cord set that matches the one you have.. ( probably cost between $10 - $15 ) Once you have the right cord.. pull the dryer out and away from the wall.. Locate the feedthru on the back of the dryer rear panel.. ( that is where the cord goes into the dryer) and usually has some kind of cable clamp to keep the cord from being yanked out of the dryer.
Loosen the cable clamp and then look for an access panel where the wires physically get tied into the dryer. Once you have the cover removed, you should see a terminal block with 3 or 4 positions and color coded ( red/ white/ black and or green.. ) the Green is a ground wire and may be secured to a frame stud and not on the terminal block. Unscrew the wires from the old cord and reinstall the new cord in its place. Make sure you match the colors correctly ( red to red, white to white,black to black and green to green if it has a green position of green to a frame screw.) Make sure these wire terminations are reasonably tight. Once together, put the cover back over the terminal block and make sure the cable clamp is snug. Then plug it in and run it.. Your problem should be resolved.
Let me know if you have any questions with this...
Regards,
Rick
Nov 24, 2008 | Kenmore Elite HE4 Electric Dryer
HP printer
Try to unplug then plug in the power cords if not working im sure your current supply will be lost. due to the current supply in your area or lost connection of your power supply.
Jun 05, 2008 | HP LaserJet 3030 All-In-One Printer
POWER CORD
most notebook adapters i've seen have the light stay on as long as it's supplying power to the notebook. so your p/s maybe defective - my guess is that something's tripping it - are you sure the p/s is suitable for your particular notebook (based on voltage/current/power requirements)?
Nov 16, 2007 | Computers & Internet
Mx35 no power
Hi, can you use a multimeter? If so then check on the power suply what the voltage output should be for that unit. Then with the power turned on GREAT CAUTION MUST BE TAKEN AT THIS STAGE AS TESTING THE WRONG END COULD CAUSE ELECTROCUTION use the meter to test the laptop end plug only and see what power output you have. If you can not do this then take the power supply to a technician and have it tested. If ok = dead battery, if not replace power unit. Regards mistyman
Sep 01, 2007 | Toshiba PA2502U - Libretto 100, 110,...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
59 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
