Question about Kodak EasyShare M863 Digital Camera
Think There Is A Problem With The Lense
Everytime I Turn On My Camera It Goes Straight Back Off I It Has A Ful Battery. The Lends Seems 2 Be Jammed Is There Any Way Of Fixing It ?
    Genius:
  • Kodak Master
  • 1,099 Answers
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 20, 2009
I dropped my camera whilst the lense was out and everytime i turn it back on the lense doesn't move it just says 'turn power off and on' and i turn it off, turn it back on and it still says the...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Aug 28, 2011 | Sony Cyber-shot DSC-N1 Digital Camera
My camera lense won't go in. Everytime I switch it
Your batteries are too low.
When you switch on the camera, the lense go in. Then lense comes out fully. Then, if the batteries are low, lense goes in and camera turns off.
But if the batteries are too low, camera turns off before the lense retracts or even before the lense comes out fully.
Aug 27, 2011 | Sony Cameras
Samsung pl50 lense jammed?
Hi
Thanks for using FixYa. Please check the battery is fully charged.
If you are able to access the Menu, please select Initialize under Settings and Main Settings 1 Menu and press OK. If still the issue persists, perform the power reset by removing the Battery and pressing the power button continuously for one minute. Then, leave the power button and reinsert the Battery.
To reset the Digital Camera by using a RESET button follow these steps---
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
To perform a manual power reset follows these steps---
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If still the issue persists then it means that the cabinet is opened or LCD cable is touched which is caused by connection defect or poor contact between connector and LCD cable due to the pressure by the rib in the front cabinet to the connector. If still its not resolved then as its a new one so you should use its warranty and get it replaced just to avoid future issues.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 05, 2010 | Samsung L100 Digital Camera
Hello I have a canon IXUS 960 IS. Yesterday when I was using the camera it only closed half way when powering the camera off. Now the camera doesn't open fully and when pusing the "play" button the power...
If the outside of the lense get dirty, those small particles may prevent the lense from opening and closing 100% as nomal times. I had the same problem with my Sony. Here is what I did.
1- I cleaned the outside(sides not the lense itself) of the lense.
2- While turning the camera off, I press on the lense (up and down motion) NOT too hard for a few times untill it either retracted all the way inn or most of the way in. If most of the way in, press the lense a little harder untill it retracts 100%. If you turn it back on, it should work as normal unless some mechanical part of the lense is broken or dislocated. When it fully opens, clean up the outside of the lense and keep it always clean for normal operation.
Good Luck!!!!!!!!
Jun 11, 2009 | Canon IXUS 960 IS Digital Camera
OLYMPUS DIGITAL ALL WEATHER
1) Make sure that the batteries are in good condition
2) Check and clean any dirt or corrosion from the battery terminals.
If the power supply voltage suddenly drops during initialization,
or when the lens is trying to extend itself, it could produce this
kind of error.
3) Make sure that the lens extension tubes are not mechanically
jammed.
4) Remove the batteries, turn the unit ON and wait for it to fully
discharge any internal capacitors, then put the batteries back
and try to turn the unit back on. This should fully RESET the
internal CPU.
Generally this kind of error means that the camera's internal
computer is trying to activate the lens zooming motors, but
the motors fail to move as expected.
Other causes could be:
a) burned out ZOOM motors
b) burned out motor drive circuitry
c) bad motor positioning sensor
d) defective computer components
e) failed internal firm-ware.
none of these cause are user fixable.
Hope this helps
Martin
Nov 10, 2008 | Olympus Stylus 700 / 700 Digital Camera
Nikon coolpix s1
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 18, 2008 | Nikon Coolpix S1 Digital Camera
Jammed Lense)
Make sure the lense is not bent. If so, gently straighten it. This worked with mine.
Nov 28, 2007 | HP Photosmart R717 Digital Camera
Kodak EasyShare M863 Digital Camera Logo
61 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
