Question about Kenmore 62982 Electric Dryer
My kenmore dryer model 62982 keeps shutting off what part do you think I need
  • Kenmore Master
  • 7,482 Answers
Sounds to me like you have a faulty timer switch.
If you decide to replace it yourself, First unplug the dryer from the electric and be sure to get the same switch, and I will also recommend that you remove and replace one wire at a time on the switch as this can be a real problem if you mix up your wires.
Good luck,
I hope this helps
Posted on Oct 06, 2009
What is the capacity of whirlpool gas dryer lg7801xm
Hi, Consumer. We're sorry to hear about the difficulty with your Dryer. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
Jun 18, 2014 | Kenmore 62982 Electric Dryer
After dryer shuts off, timer continues to run. Kenmore model #110.86181810, part # I think is 692032 and sears says it is no longer in stock. Anyone still have one?
I assume you're talking about the buzzer. Many high end dryers do that until you remove the clothes. heated clothes can set wrinkles if kept in the same position for a long time. it's a feature, not a problem, unless it keeps buzzing after you remove the dried clothes!
Apr 15, 2013 | Kenmore Dryers
When you push the "push to start" button, the
I would say change your Start button should take care of the problem.
FIRST Always unplug the Dryer before doing any work on it.
Good Luck
Dec 26, 2010 | Kenmore 62982 Electric Dryer
My Kenmore Elite Dryer (Model 110 6095299) keeps turning off even though the clothes are not dry. I have to keep turning the dryer back on, only to have it turn off again. This can happen anywhere...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There a few other things that can shut it off also...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Kenmore 63942 Dryer
How do you get the bottom panel under the door of the dryer off? It looks like there are clips of some sort there, but can't remove or move the clips enough to remove the door? please give step by step...
Unplug the dryer before attempting any repair works.
The bottom front panel is secured to bottom of the top front panel by two securing clips. Insert a flat-bladed screwdriver between the top front panel and the bottom front panel as shown then pry the panel out then lift it off the cabinet.
Install the bottom of the bottom front panel first when reinstalling then push the top back into position until the clips engage.
Aug 21, 2010 | Kenmore 62982 Electric Dryer
My kenmore 81492500 manual suggests if the drum is turning, but not heat, there are 1 of 2 house fuses are blown. Where are the fuses located in the dryer circuit?
the fuses are in your house fuse box,with a meter check to see if you have 220 to 240 volts or 110 to 120 to the black and white wire and 110 to 120 to the red and white wire where the cord connects to the dryer,if you do you'll have to check the heater,the high limit thermostat on the heater box,the thermal fuse on the blower wheel housing,you have to unplug the dryer to do this and pull at least one of the wires off the part you're checking.next time send the first three small black numbers on the model number with the 81492500,
Apr 22, 2010 | Kenmore 62982 Electric Dryer
My Kenmore ELITE keeps shutting off before the
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
Aug 18, 2009 | Dryers
My kenmore dryer keeps shutting off mid cycle.
sounds like your motor is over heating and shutting off.once it is cooled it starts.listen next time and see if their is a humm or pause when restarting the dryer.solution is replace motor.
Mar 11, 2009 | Kenmore 65924 Electric Dryer
Kenmore dryer timer never shuts off.
REPL/ YOU BROKEN LID SWITCH ,, IS ON OPEN POSITION REASON FOR NO T SHUTTING DOWN////
Nov 28, 2008 | Kenmore 27032
Timer doesn't shut down dryer machine
the timer is easy to change, check how much it is first, mine was around $100.
Apr 28, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62982 Electric Dryer Logo
116 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
