Question about IBM Infoprint 1532 Laser Printer
What is the maximun amount of memory i can install into the IBM 1532 Printers?
  • 5,603 Answers
The manual shows a SINGLE memory card slot.
The largest memory card I found offeered for the printer seems to be a 512Mb module.
The printers were delivered with only up to a 128Mb module.
Posted on Oct 06, 2009
Why is my infoprint 1532 saying load mp feeder?
Driver is telling the printer to print single sheet. Load a single sheet or fix your driver/software settings.
Jul 09, 2014 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 giving error code 922.14 -service fuser error
There is a heater control problem in the fuser.
The fuser is the assembly of heated rollers in the rear of the device.
The most likely cause is either a blown heater element, or perhaps a faulty temperature sensor.
Usually we fit an exchange fuser assemblt to fix this.
Feb 04, 2010 | IBM Infoprint 1532 Laser Printer
IBM 1532 2nd tray is installed but the printer isn';t seeing it
First of all, let's establish exactly what doesn't see the second tray - the printer or the computer?
Go to the printer's display, enter the menu and find a configuration sheet print option (or something to that effect). All printers can output a summary page with all relevant information, like memory, settings and also paper trays. If the second tray is not mentioned on the configuration sheet, then there must be some problem with electrical connection between the printer and the tray.
If however the printer sees the tray, only the computer doesn't let you print/select it, you must open the control panel, printers, properties for your printer and find an option like "installable accessories", "optional components" or something similar, where you will find an option to enable the second tray, thus informing the printer driver that the printer is equipped with 2nd tray.
Good luck
Nov 01, 2009 | IBM Infoprint 1352 Laser Printer
IBM 1532 makes a loud bang loading an envelope
That sound is actually the printer sucking the air out of the envelope to flatten it out. It is normal and there is no way to turn it off.
Aug 07, 2009 | IBM Infoprint 1532 Laser Printer
Refilled toner and now printer reads - 30 invalid refill
The toner used must be for a different printer. That error message is displayed when the chip on the toner is not the correct one for that printer. It may be a defective cartridge, or the incorrect model. Try to go back to the place you bought it and return or exchange for the correct one.
Jun 16, 2009 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Jun 03, 2009 | IBM Infoprint 1532 Laser Printer
Tray 1 Low
How many input trays does this printer have?
Trays can be renumbered to allow for larger capacity input trays.
Please print out the menu setting pages and verify the correct paper tray numbers.
Don
May 15, 2009 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 printer not working
count the beeps, the number of beeps detemines the error.
Nov 14, 2008 | IBM Infoprint 1532 Laser Printer
Lexmark 1532
If the Operator Panel is locked. (Menu's disabled) you need to enter Config Mode to enable the operator panel. Press and Hold the > right arrow and down arrow buttons while powering on the printer. Once in configuration mode scroll to Panel Menu where you can enable it. Exit Config Mode or just power the printer off and back on.
Mar 28, 2008 | IBM Infoprint 1532 Laser Printer
Infoprint 1532 ibm micr printer
This unit is the low voltage type 110v compared to Australia voltage which is 230v therefore you will have to buy a new printer
Dec 29, 2007 | IBM Infoprint 1532 Laser Printer
IBM Infoprint 1532 Laser Printer Logo
130 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
