Question about Canon PowerShot A590 IS Digital Camera
I keep getting a warning to change the AA batteries, which i have done several times. That doesn't make a difference. I have given up. Is there another reason I get the warning.
  • 3 Answers
Use Duracell or another high quality battery. The cheaper ones (ie Sunbeam) are not powerful enough to drive the camera.
Posted on Oct 16, 2009
My SB 700 shows temperature after few shuts and when it's twisted
From the SB 700 manual page b8:
v Notes on continuous fl ash photography • To prevent the SB-700 from overheating, allow it to cool down for at least 10 minutes after 15 times of continuous firing. • When continuous flash firing is repeated in quick succession, the internal safety function adjusts the recycling time by up to 15 seconds. If flash firing continues, the thermal cut-out indicator appears on the LCD and all operations are suspended. (0E-31) Allow it to cool down for several minutes to disable this function. • The conditions under which the internal safety function is activated differ depending on the temperature and the SB-700 flash output level. Operation B B-8 Slide the battery chamber cover open while pressing the battery chamber cover lock release. Insert the batteries following the [+] and [-] marks. Close the battery chamber cover. STEP 1 Inserting the batteries Operation B B-9 1.5 V alkaline AA battery 1.5 V lithium AA battery Rechargeable 1.2 V NiMH AA battery Suitable batteries When replacing batteries, use four fresh AA-type batteries of the same brand from any of the following types: • For minimum recycling time and number of flashes for each battery type, refer to "Specifications." (0H-27) • Alkaline battery performance may vary greatly depending on the manufacturer. • 1.5 V carbon-zinc AA batteries are not recommended. v Additional precautions regarding batteries • Read and follow battery warnings and cautions (0A-19 - A-22). • Be sure to read and follow the warnings for the battery on the section, "Notes on Batteries" (0H-9), before using the battery. • The recycling time can be longer when lithium AA batteries are used because they incorporate a function that suppresses the output current when heat is generated in the batteries.
Nov 26, 2015 | Cameras
What type battery for powershotA480
Your camera uses 2 AA batteries, but if you use Alkaline batteries they will drain very fast. You are better off buying rechargeable batteries as you can recharge them several hundred times, cheaper than Duracell or Energizer Alkaline batteries in the long run. If you buy rechargeable batteries make sure you get a high mA capacity the higher the mA which stands for Milliamp Per Hour the longer the battery will last in terms of a charge.
Jun 20, 2014 | Canon PowerShot A480 Digital Camera
My fujifilm instax 200 doesnt turn on eventhough i changed the batteries several times
Did you chaco if the contacts in the battery holder are clean and shiny?
Doy you have some rechargeable NiMH batteries. Try them, because they have more capacity then the alkaline ones.
Never use AA manganese (Zinc-Carbon) batteries or NiCd rechargeable, because the voltage is too low.
Dec 03, 2013 | FUJIFILM Instax 210 Film Camera
Xbox 360 controller not powering up
If the control is wireless, try changing the battery device out, use a different type. for ex; AA batteries to a re-chargable one. If the control is wired, try changing out the cord or get a new control. If it doesn't work, try here . Hope it helps.
Dec 08, 2011 | Microsoft Xbox 360 Controller
What batteries fit vp-440
This tester requires AAA batteries.
Please rate my reply. thanks.
May 31, 2011 | Amprobe Non-Contact Volt Probe Product ID:...
Canon A470 The date and time menu keeps popping up every time I switch on the camera despite setting the date and time.
There is another battery next the the AA battery under a little cover marked CR1220. That is the battery size. If that battery is dead, or has never been installed then every time you change the AA batteries the camera will forget the time and date. Try to get one from a specialty store that turns over its inventory quickly and you may find that you will only change this battery every 2 or 3 years.
Oct 31, 2009 | Canon PowerShot A470 Digital Camera
Energizer +AA NIMH Batteries consumed quickly
There are many grades of batteries under the same manufacturers name. They have a different Ah rating. The lower the Ah the shorter the time they will last.
Mar 02, 2017 | Energizer Duo Battery Charger for AA and...
PLEASE HELP
well I have had similar problems with this camera model. I tried several types of batteries and changed the battery type settings from the menue too... the problem changed a little bit but it did not solve the issue. I send the camera to Samsung service but got it back with "no fault found".
as I am working in this business I could not believe that a camera like this is not able to make less than 10 pictures with one set of batteries....I gave not up.
here is what I found:
when you open the camera by releasing the little screws from the buddy you will find several connector clips holding flatcables. this clips have not been closed correctly. just close them carefully!!! with a forceps and you will have a nice camera! this work can't be done in hurry...so take your time.
Jul 02, 2008 | Samsung Digimax D53 Digital Camera
Warning: receiver channel changed - wireless keyboard and mouse
I contacted Gaeway Support. They quickly answered and suggested that I change the batteries in my wireless mouse and/or keyboard. I did. It was the mouse. As soon as the new batteries were in, the popup went away and stayed away.
Jan 07, 2007 | Gateway 2520915 Keyboard
Canon PowerShot A590 IS Digital Camera Logo
137 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
