SOURCE: reset DLink router to factory default
All you need is your ISP log-in name and password.
Connect the router to your computer with an ethernet cable, log into its web server (generally 192.168.0.1) Get past the gatekeeper (admin and admin) and then navigate to the set-up page and re-enter your ISP info. That normally is all there is to it.
SOURCE: HOW TO ACCESS DLINK WIFI ROUTER BECAUSE OF FORGOTEN PASSWORD
We have a Dlink 615 Wifi Router,I couldn't set a username and password to prevent it from illegal usage.We have a cisco 1700 router. Can any one help us in installing a username and pass word for our router.
SOURCE: dir-300 dlink router asking to reset to factory after installatio
there's an easy way to reset your router back to its factory setting... inspect the physical appearance of your router... there should be s small hole.... inside that small hole is a reset button
How to reset? ..... while the router is on...Using a small pointing object, much better if you use a paper clip..... insert the paper clip to the hole... press and hold the reset button for 10 seconds...
That's it your router will restart itself and the settings is back to its factory settings...
Hope that help you..
Much appreciated if you rate this help... thanks
SOURCE: how to reset my password in my dlink router
If the default password has been changed then -
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ONuntil the LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now configure the wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Get online
and got to www.google.com In the google search box type: "Dlink
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for Manuals.
The IP address to put in your browser to get into the router is: 192.168.0.1
The default userid is: admin
There is not default password, so leave it blank.
