Question about Kitchen Ranges
Kenmore Elite Range door locked error message
I have a Kenmore elite gas range, model 790.3670 or 3671. After self cleaning yesterday, the door would not unlock. We were told by sears today to turn power off for 5 minutes then hold stop/clear button when we turn power back on. The screen now displays a blinking "door locked" light and "dr" above that and is audio beeping every few seconds. The sears people said they need to send a repairman out here and they can't get out here until Jan 7 and it's Christmas! This stove is only one month old! Please help! :)
Hold down the number three button until the LOC message disappears and then the door will open.
Posted on May 13, 2009
We just had a similar problem for the same gas range. The oven started a self clean on its own (we could have hit the clean and start buttons together without realizing or maybe it malfunctioned). Anyway, we turned off the power to stop it from cleaning, however this was not until the door had locked. Two hours later and the door was still locked, even though the manual says it will open after the oven has cooled down. A few days and $125 later the Sears repairman had used a metal coat hanger, provided by us, to slide between the top of the oven door and the oven to pull the latch back. Once the door was open he hit the clear button and it's all working again!
Posted on Jan 02, 2009
I held down the 3, which didn't seem to work for me. Then I held down stop/clear for about 10 seconds and there was a beep and the red LOC message went away. I let go of the stop/clear button. The door was still locked and the yellow DOOR LOCKED sign started flashing. There was another beep about 3 seconds later, and now the door opens. Hooray.
Posted on Nov 19, 2010
Kenmore elite oven door shows door locked how to unlock it
https://www.hunker.com/12438447/how-to-unlock-a-locked-oven-door-on-a-kenmore-range
How to Unlock Locked Oven Door on Kenmore Range Hunker
Quoting from the link shown:
Step 1 Read the display on the electronic oven controls, where the clock and timer normally appear. If the display reads "CLN" while the "Door Locked" light is on, the Kenmore range is in self-clean mode. When the Kenmore range is in self-clean mode, you must stop the cleaning process before the door will unlock.
Step 2 Stop the self-cleaning process by pressing and holding the "Stop/Clear" button for three seconds. The oven lock should disengage after three seconds. In some cases, a malfunction between the control panel and the locking mechanism prevents the door from unlocking.
Step 3 Hold the light switch for several seconds if the "Stop/Clear" button fails to unlock the range door. Engaging the light switch for several seconds resets the entire locking mechanism and overrides the "Stop/Clear" button.
Jun 15, 2018 | Kitchen Ranges
I have a Kenmore Elite double oven, model 790.48123801.(4 years old). My wife attempted to operate the self-cleaning feature and 29 seconds later an F90 error message appeared, the oven began to beep
Oven door latch error code. The oven door latched but the control board did not receive a signal that the door was latched.
The only time that the latch is used is during the cleaning cycle.
KENMORE ELITE Walloven Parts Model 79048123801
How to unlock Kenmore oven
Oct 18, 2014 | Kenmore Kitchen Ranges
Beeping sound with a message dr
I have a kenmore elite range model#790.9802. the walls of the oven expanded after a self cleaning cycle that the rake fall. i want to take the oven cavity out and reshape it. the problem / anyone know how the oven cavity comes out? I don't want to break the oven by trying to remove it the wrong way.
Sep 23, 2013 | Kenmore 75844 / 75849 Gas Kitchen Range
I have a sears kenmore elite slide in range model number 790.46613500 that has a f13 err can anyone help with this
Unfortunately, the F13 error indicates that the oven control has failed. First unplug your range and wait 30 seconds or more to reset the code.
If the error recurs, this part will need to be replaced. See http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79046613500/0583/0124160/R0507023/00001?blt=06&prst=0&shdMod=79046613500 for the parts list.
I'm not exactly sure if your unit needs part 97 or 97A.
I hope this helps.
Dec 08, 2012 | Kenmore Elite Sears & Other Brands...
My Kenmore Elite gas range is beeping and flashing F90, the door is locked. What can I do to clear this?
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^#$%
Aug 28, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
We used the self cleaning option on our Kenmore Gas Range (model number 665.72004101 or 665.75004101) and now the oven door remains locked and the error message on the screen is e1 - f5. How do we unlock...
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 27, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore elite oven lock
None of above worked for me. But, gave me a clue. I pressed the Stop/Clear button for apprx 10 sceonds. the "door locked" flashed for 5 seconds and then cleared and the door unlocked. Panel worked fine after that.
Mar 10, 2008 | Tappan TGF320 Gas Kitchen Range
Kenmore Elite Range/Oven problem.
My kenmore glass top stainless steel slide in range has an error message code F93. I was attempting to allow my range to self clean when this err message appeared. Now I can't get the door unlocked. Help?? We've had a lot of problems with this range. We've had the service tech come out probably 4-5 times for different things. I think I got a lemon. It just turn a year old-we extended the warranty . I've called to complain but I got no help. They said it had to be for the same problem each time. Even the tech said the oven was a lemon but he couldn't help us. Any suggestions?
Jan 29, 2008 | Kenmore 46123 Stainless Steel Electric...
Kitchen Ranges Logo
1,188 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
