Question about Dryers
Not getting hot - Dryers
  • 82 Answers
If your dryer is gas-dryer:
1-thermal fuse is broken.
2-ignitor is broken.
3-sensor flame is broken.
4- gas valve is broken.
if is electric dryer:
2-heat element is broken.
Posted on Oct 06, 2009
Hot water not running to machine just the cold water
Try switching the hot and cold hoses. See if the hot water works. Sometimes the gate gets frozen, other times the hot is so slow it seems to not be working, similar to when it takes a long time to get hot water in the sink.
Apr 19, 2017 | Washing Machines
Water does not get hot on a hot wash
Shut off the water. Disconnect & check the BOTH water supply hoses at the MACHINE to check for obstructions / kinks / etc: Check for and clean any strainer / filter on the hoses and inlet to the washer. Direct the hoses into a tub or other container and turn water ON. make sure you have water flow from BOTH hoses and that one is HOT and the other is COLD. If OK, reconnect to machine. Turn water back ON. Choose a WARM wash.
If you get COLD only, you probably have a bad HOT solenoid - if HOT only you have a bad COLD solenoid. Be sure by:
Shut water off and swap hose connections (hot to cold & cold to hot) and try again.
If you get COLD only, you probably have a bad COLD solenoid - if HOT only you have a bad HOT solenoid. If you get HOT only, you probably have a bad COLD faucet / hose - if HOT only you have a bad COLD faucet / hose.
Replace the bad solenoid as needed. Good luck!
Sep 28, 2015 | Hotpoint WMA48 Front Load Washer
Honeywell technical support
This boiler, from memory, has an electric diverter valve.
If the system has dirty (sludge/scale laden) water then the diverter valve may not return under spring pressure, and therefore not divert all of the hot boiler water to the hot water heat exchanger, leaving some going to the rads.
If I am right then the rads will not get fully hot.
If the valve has failed completely, or electrically, then the rads will get fully hot and there will be no hot water output (hot water will be cold).
Aug 19, 2014 | Heating & Cooling
How do I get the hot water work for my Fisher & Paykel Eco Smart washer?
How hot is the water temp in the house that you are in? If the inlet hose to the washer is not hot, then it is not the washing machine.
Jul 31, 2014 | Fisher Paykel EcoSmart GWL15
Is the top heating element inside the oven supposed to get hot even if not set on broil?
Yes the top element does get hot even on bake but it does not get red hot just hot. It will get hot enough to burn you so be very carful.
Apr 06, 2011 | Kenmore Ovens
I just bought a repo house which has a grundfos circulation pump u p 15 installed at the water heater. House built 2005 4260 sq. Feet. House has 4 showers only one of them gets hot water. All sinks get hot...
that pump is likely to be a hot water return pump not a booster pump. it sound like a large property so its likely the hot water system requires balancing to get the hot water to the extreme areas. If all the hot outlets have some form of isolation valve try closing all but the affected areas and see if hot water comes out. If so only open the closed outlets enough to give you reasonable flow. This hopefully will force the hot water to the affected areas.
May 20, 2010 | Home
Ipod 4 GB not charging and gets very Hot when I try to charg
my nano 4gb ipod gets hot when i try and charge it on conputor ac ports it gets hot
Mar 18, 2009 | Apple iPod nano
Car radio gets hot
There is a lot of heat generated and not a lot of ventilation so the answer to your question is yes, they all get hot. Now the question is what is too hot? Certainly we don't want it so hot as to roast marshmallows on or to melt anything or even WITHOUT TOUCHING IT too hot to touch. If it truly gets that hot there may be some trouble with the speaker or power wiring that is making it work too hard.
Feb 27, 2009 | Car Audio & Video
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
KENMORE HE5T NO Hot Water
Check the hot water line going to washer have hot water?If donot have trace the line from Hot water tank going to washer if yuo rfound it open the valve. hold the pipe you can feel the hotness.attache to machine.
Dec 27, 2007 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
121 people viewed this question
Top Dryers Experts
