Question about Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point
Dropping wireless connection to laptops
Howdy! I have the SBG900 and use it wireless to a HP and Toshiba laptop, which are generally located not more than 30 straight line feet from the modem. Multiple times during the day or night, with my wife sitting side by side on the sofa, we'll lose wireless network connectivity, with a "red X" on the network icon. Some times when this has happened, I have gone to the office to look at the modem and all the lights will be correctly lit. It seems we're either connected "excellent at 54mbps or its gone and searching, no in-between. In an hour,this may occur 25 or 30 times. The unit is about 5 years old. This occurs even after doing a reset on the unit.
I have a Comcast tech coming out today to check their end of it. Is it possible that the modem is losing connectivity with the ISP and this is causing the problem, or is this a modem problem?
Many times, I'll have an excellent wireless connection, and Explorer will churn away trying to make a connection, say to my remote work network (which should not be overloaded) or to open, say a CNN page. This can take up to 5 minutes!
We're at the end of about 250 feet of upgraded, larger coax cable that COMCAST put in.
Any helpful hints appreciated. Don't understand why my wireless connection drops in and out like this inside the house. If I should upgrade to a newer model router/modem, what would you advise? Are two separate units better than a combo unit? We do not hard-wire an ethernet connection, only wireless due to the room configurations.
Thanks a bunch!
"Fig" Newton
  • 22 Answers
You should be able to log into your modem using the IP address
192.168.100.1
to check the levels coming to the modem from your cable provider. Typically the downstream level should be in between -12 to +12dB with an SNR of 33 or higher. Upstream level should be in between 35 and 50. 35 being good and 50 being less desirable. SNR on upstream should be 23 or higher.
If the levels are anywhere within these specs you should have no problems with the modem.
My suggestion would be to log into your router and change the channel # that your router is broadcasting. This should be in between Ch. 1 to Ch. 11 Most routers are default to 6 9 or 11 so if I'm having any issues I will use Ch 7 or 4. (I've seen some 900MHz cordless phones mess with some channels.)
If that doesn't work try another ethernet cable between the modem and router.
Good Luck
Posted on Oct 09, 2009
What is the function key to turn wireless on
How to turn on/off Wireless in various Laptop Models ------------------------------------------------------------------------------------
Vendor/Model-----------Type----------Location
Dell D600 & D610-----KeyBoard-----Fn+F2
HP nc4000 & nc4010-----Button-----Above Keyboard
HP nc4220-----Button-----Left Side of Laptop Near USB Port
HP nc6000 & nc6220-----Button-----Above Keyboard
HP nx9010-----Button-----Front side of laptop
HP Omnibook 6200-----Button-----Left side of laptop
IBM T43-----Keyboard combination-----Fn + F5-----Click "Turn On"
IBM X32-----Keyboard combination-----Fn + F5-----Click "Turn On"
Toshiba M1 & M2-----Switch-----Left side of laptop-----Towards
front
Toshiba R100-----Switch-----Right side of laptop
Toshiba TE2000-----Switch-----Left side of laptop-----By Vol ctrl
Toshiba Tecra 2100-----Switch-----Left side of laptop-----By Vol ctrl
Sep 09, 2011 | Computers & Internet
Internet drops
Compare all your internet connection settings to the laptops that work well. Mirror your settings to match a laptop's that is working properly.
You might also want to re-install your internet drivers. Go to your Toshiba site. They should have all the drivers for your model.
Sep 28, 2008 | Toshiba Satellite P105-S6104 Notebook
Tip
How to turn on Wireless Switch on your Laptop or Notebook PC
How to turn on the wireless switch on the laptop or notebook
If you have issues in finding the wireless switch on the laptop to turn the wireless on you can refer the below list
1. Dell D600 & D610-Key Board-Fn+F2
2. HP NC4000 & NC4010-Button-Above Keyboard
3. HP NC4220-Button Left Side of Laptop Near USB Port
4. HP NC6000 & NC6220-Button above Keyboard
5. HP NX9010-Button in front side of laptop
6. HP Omni book 6200 Button on Left side of laptop
7. IBM T43 & X32 Keyboard combination Fn + F5 then Click "Turn On"
8. Toshiba M1 & M2 Switch Left side of laptop towards
front
9. Toshiba R100 Switch on the Right side of laptop
10. Toshiba TE2000 Switch on the left side of laptop by Volume ctrl
11. Toshiba Tecra 2100 Switch Left side of laptop by Volume ctrl
12. Sony Vaio - switch on front left
13. Dell - FN,F2 or FN,F8 or FN,F12
14. Acer - FN,F5
15. IBM / LENOVO
IBM General - Some models have the wireless slide button on the side of the laptop.
IBM DV series - use the antenna-like button found on the upper section of your keyboard.
IBM R40 - Use the FN+F5 key-combo.
IBM ThinkPad (General) - Most have software switch or button on Left hand side.
Lenovo T-61 - Slide button on the front of the laptop
16. MEDION
General - Fn+F1 or Fn+F2
17. MSI
General - Antenna-like button close to the power switch
U100 - Fn+F11
18. PACKARD BELL
Easy note B3600 use the Fn+F1
Easy Note E2/MV46/008 - Fn+F1
Easy note W7730, Antenna-like wireless button on the side of the laptop.
MZ36-U024 - Fn+F2
19. PHILIPS
General - Fn+F2 key combo
X54 - Antenna-like button close to the power switch.
20. SAMSUNG
General - Blue button found in the middle section of the keyboard
on Dec 03, 2009 | Computers & Internet
How do i turn my wireless on my laptop
front
Hope it helps !
Jul 14, 2010 | Advent Netbook
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
We just tried to secure our wireless motorola sbg900 and now the wireless portion doesn't work. We have to use an ethernet cable. How do we reverse this and still make it secure?
To change any wireless settings on the router, you will need to make wired connections to the router.
If you change the wireless settings on the wireless laptop it will drop the connection because you are changing a wireless setting.
Click Here for more info about networking
Oct 17, 2009 | Arris SURFboard SBG900 Wireless Router...
Motorola SBG900 Assign network address to computer
I guess your modem router was already configured well since it worked already previously. It seems that your motorola router is set to broadcast dynamic IPs (DHCP enabled) and your last connected Pc and laptop were configured with static IP. Please check your "network connection" setting and make sure it is set to "Obtain IP automatically"
Reagrds!
Jun 30, 2009 | Arris SURFboard SBG900 Wireless Router...
WEP security setup on SBG900
If you set a WEP security connection, of course you will be kicked out of your connection. You have to re configure your laptop to gain access to your WiFi, inserting the new password you set the WEP with... Hope this helps
Jun 02, 2009 | Arris SURFboard SBG900 802.11g/b...
Internet connection keeps dropping
That may sound like a "roaming tendency" issue, with your laptop wireless card or settings, and/or general radio interference. try checking and tweaking the advanced settings of your wireless card, and maybe check for outside interference between your computer and router. Many cards have roam settings that dictate how often they roam between APs. I too live in an apartment complex, where other neighbors have their own WiFi router and there can be interference, and "intrusion issues" :? if your equipment is not properly set and secured.
Jan 23, 2009 | Linksys Wireless-G WRT54G Router
Arris SURFboard SBG900 802.11g/b (motosbg900) Wireless Access Point Logo
277 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
