Question about Stoves 1100ESIDLa Electric Kitchen Range
Kelvinator Stove Power Cable Connection
Hi, I just bought a stove and a 4pin cable to connect it to the power, but my problem is that this cable has a silver metal coming out next to the 4 pins ( I was told that this silver metal is earth) and now I do not know how to screw it in in the main port on the wall. Also on the other end this cable has 5 wires which are 3 red, 1 black and 1 green/yellow, and these have to go directly into the stove and I am not sure as to which wire should go where.
Can I atleast get the photo of the connected stove, Just to see the back view and wich wire should go where.
You should unscrew the small back panel, on the undercover should be a scetch of the wiring.
If not the three red are live, black is neutral and the g/y is earth, from number 5 to 1 connect as follows: 5 and 4-black,3,2,1 red and look for a screw type fitting or green wires to connect earth.
Its important to connect earth before operating the stove as it cuold lead to serious injury if not connected.
Hope this helps
Posted on Nov 23, 2008
I have a SONY HandyCam DCR-SX44. I want to transfer video/audio directly from the camcorder to Windows Movie Maker. I have a cable with USB connection on one end and 5 pin connection on the other, but...
I had similar problem with my Sony Digital8 (also called HI8 ) handycam. My vista system was not able to detect my Handycam with a very very cheap FIREWIRE PCI Card I bought in local market for only $4, yes four dollars. It came with 6pin to 4pin Firewire cable(Sony calls it i.Link). I was trying to connect with same cable 4pin at camera end and 6pin on PCI Card, with no luck. It was even showing DV-IN on camera LCD with this 6pin to 4pin cable. I tried everything an expert would do, but got only frustration. Even tried a lot on Internet for the solution but it seems no one knew.
Then I started from scratch, TO DECIDED TO READ MANUAL. While reading the PDF manual found on Sony Support site, trust me, I found those golden words "USE ONLY 4PIN TO 4PIN i.Link Cable for Firewire connection."
I ran back to market and bought 4PIN TO 4PIN Firewire Cable for $1.5
At first trial, trust me, it detected "SONY DV Camcorder" and installed drivers automatically. I confirmed by going into Device Manager and found same entry in Imaging Device section. Then what in every possible software existed on my system, DV Capture was available, which was found always disabled.
Now the funny part it, technically there is no difference in 6pin to 4pin Firewire cable as two pins are used for Voltage which is discarded at 4 pin end. But it seems SONY Handycam does not wants itself to connect it to 6pin socket at PCI card end.
So these are the final things to remember.
1) Use only 4pin to 4pin Firewire cable (any cheaper make. $1.5 will do)
2) Use any cheaper FIREWIRE PCI card with at least one 4pin firewire socket. When installed XP or Vista will install driver automatically just confirm that "IEEE 1394 bus host controller" entry is shown in Device manager or not.
3) No matter you use cheaper or costlier PCI card or cable the quality will always be same coz D8 Handycams directly transfer encoded Video Data in Digital format thru Firewire cable. Firewire cable does not transfer RF video input. I get default video with 720x576 with 25 Frames/s in PAL mode.
4) No additional codecs are required to install in pc like others suggested. Required codecs are always there in XP and VISTA with windows movie maker.
5) No additional software is required, as you can directly capture with Windows Movie Maker in high quality. My choice is Adobe Premier CS3. If you want to make directly MPG file you may use ULEAD VIDEOSTUDIO 8 or later.
6) Do not blame non.gif SONY as they already told you which exact cable to use.
7) Do not blame non.gif Vista. Its nothing to do with it. Sony's PicturePackage for XP does not work on vista. For vista they offered PICTURE MOTION BROWSER which also have easy VIDEO Capture utlity with same high quality capture. Some people falsely claim that "VISTA DOES NOT WORK WELL WITH FIREWIRE" That is completely wrong. See, one or few people may have problem and they always keep shouting for thier fate. But it actually it could be thier local hardware or software problem or anything. There could be many reasons at the same time too. Many people even do not care to change to new cable and keep trying on same thing. Actually cables are very delicate rubber material. Many a times you get faulty cable in new petty pack box of devices. Or it could be some firewire chipset problem too. Last is driver problem. Many firewire card manufacturers have not yet made stable drivers for vista. Most problems are solved if newest drivers are downloaded and installed.
7) In handycam mode, you can control PLAY/STOP/PAUSE of Handycam from PC itself from all the video software you use, which is high convinience for capturing.
8) My sureshot capture sequence is as follows.....
a) Remove BATTERY from camera and switch on with AC Adaptor
b) Put it on PLAY/EDIT mode (also called VCR mode).
c) Connect 4pin to 4pin firewire cable on camera side and in firewire PCI Card. Now you see the words DV-IN on LCD of camera, if LCD is open.
d) Now start any Video Capture Software of your choice. You will find CAPTURE command in FILE menu in almost all softwares.
e) Enjoy.....
Jun 26, 2011 | Sony Video Cameras
I'm not able to install drivers for my sony mini DV DCR-TRV22E handycam on mac os.
The DCR-TRV22E Camcorder can be connected to the Macintosh Computer with the i.LINK (Firewire) cable. The Software supplied with the Camcorder is not compatible with the Macintosh Computer. Instead you've to use the Firewire cable for connecting the Camcorder to the Computer. You can use the iMovie Software for transferring the videos. You do not require any drivers from Sony, to transfer the video via i.LINK.
You require to purchase either a 4 - pin to 4 - pin or a 4 - pin to 6 - pin i.LINK / Firewire cable depending on the number of pins on the i.LINK / Firewire port of your computer (since Camcorder will have only 4PIN i-LINK, while the Computer may have a 4PIN or 6 PIN i.LINK port).
Thanks for using FixYa.
We wish you a happy Christmas and NewYear!!
Dec 23, 2010 | Sony Handycam DCR-TRV22E Mini DV Digital...
Cpu fan stop few second after starting pc
Hello,have you installed new motherboard or CPU?
Follow these steps again
1) Disconnect the power cord from the back of the computer & open up the case.
2) Wear an anti-static glove or at very least discharge your static by touching a metal surface or power supply
3) Disconnect the main 20pin ATX power connector from the motherboard & the square 4pin ATX2 power connector
4) Remove any PCI cards you have & disconnect ALL drive cabling from the MOTHERBOARD. Also disconnect any internal USB fly leads from the motherboard.
5) You should now have ONLY the cpu+heatsink/fan, memory & video card installed. Locate the round silver battery in the bottom right corner of the board. Just below it, you'll see a plastic jumper cap. This cap should be covering 2 pins (pins 1 + 2) with pin 3 bare. It will be marked JP1. Move the jumper to cover pins 2-3 instead. Leave in this position for about 30 seconds, then return the jumper to its original position (pins 1-2).
6) Reconnect the square 4pin ATX2 power connector & the main 20 pin ATX power connector. Make sure that the case speaker or buzzer is connected also.
7) Make sure the only external devices connected are the keyboard/mouse & monitor. Reconnect the power lead & power on the system
Let me know what happens
Feb 06, 2010 | ASUS M2N68-AM SE2 Motherboard
How to connect power supply to intel desktop board of d845wn
hmm strange question but you cant really get it wrong you plug the 20 pin conector from the power supply into the board then plug the little 4pin block which is on a diffrent cable into the little 4 pin block on the motherboard there all shaped to fit the conections so you cant get them wrong
Sep 24, 2009 | Intel Desktop Board D845WN Motherboard
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Need2 know wiring diagram 4 power supply 4 a emachine T2642
Hi there
The power supply should be ATX 20pin connection and also a 4pin connector, look at this picture below so you know you have the power connections in the right places>>ba37bd3.jpg
On the top left of the picture, the big cream 20pin socket is where the 20 pin connector goes.
In the middle to the left you will see another cream 4pin socket is where the 4pin connector goes.
If your power supply does not have the 4pin connector the pc won't boot up, you will have to go out and buy one.
If you have all the connections right and the on/off button is connected to the front panel properly, take out the system memory, clean it with a clean, dry, soft pain brush and also clean the slots too, re-seat the memory and reboot the machine to see if it boots up.
Good luck and thanks for using Fixya!!!
Feb 19, 2009 | E-Machines eMachines Desktop PC
Do I need a 4pin-4pin DV cable or a 4pin - 6p -with Canon MV 850i
The camera has a 4-pin slot. If the slot on your computer has a slot the same size as your camera, it is 4-pin. If it is larger, it is a 6 pin slot.
Dec 31, 2008 | Canon ZR850 Mini DV Digital Camcorder
How to connect JVC GR-D820E camcorder to PC
Hi, connect the cam and PC using 4 pin firewire cable. Switch on the cam. Open Windows Movie Maker and import the video from device.
Dec 28, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Panasonic NVGS60 mini dv camcorder
I have had the same experience with the same laptop. In my case, I went to Add New Hardware in Control Panel, and had my laptop automatically search for the connected camera. From there, it was automatic.
If this doesn't work, try restarting your laptop with the connections in place. Then repeat the above described procedure.
Hope this helps!
Nov 10, 2008 | Video Cameras
Firewire problem
It should work. Laptops have a 4pin connection. There is a video on how to specifically connect digital cameras to laptops using 4pin to 4 pin IEEE 1394 cable. So it should work... The video is on under Electronics category. It doesn't cover the software because all softwares would be different, but you can see that it uses 4 pin to 4 pin. You can double check on this site though.
Sep 06, 2008 | JVC GR-D20EK Camcorder
Stoves 1100ESIDLa Electric Kitchen Range Logo
763 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
