Question about Kodak EasyShare C180 Digital Camera
Won't turn on. (I am using brand new Rayovac AA batteries and they are inserted correctly). It seems that possibly the "on/off" button is stuck in the down position, i.e., slightly recessed.
  • 17 Answers
Flip the batteries around.
Posted on Nov 29, 2009
Robopanada wont turn on
hi i bot robopanda sec hand and he was working fine untill i put new batterys 4 rayovac 4.0 aa batterys it worked just two seconds the everything whent dead and i,m unable to start him agine i even pushes the reset button im so un happy about this please please help me martin.
Dec 28, 2011 | Wowwee Robopanda Robot
Polaroid A500 digital camera pressed ON button, nothing happened with new AA batteries and SD card
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 25, 2011 | Polaroid Cameras
Camera will not turn on,tried new batteries still nothing.camera is kodak c813
1. Remove the batteries from the camera and then clean the battery contacts
2. Remove the memory card
3. Verify the batteries your using
Recomended batteries are
- oxy-alkaline digital camera batteries AA
- Ni-MH rechargeable digital camera batteries AA
- alkaline batteries AA
- lithium batteries AA
4. Make sure to use a brand new batteries or fully charge batteries
5. inserted the battery correctly
6. Place the camera in Auto Mode [it's the green camera on the dial mode.]
7. Turn on the camera
if issue was not resolved contact Kodak support line at 1 800 235 6325 (23KODAK) or visit the website www.kodak.com/go/stepbystep
Nov 17, 2009 | Kodak Easyshare C813 Digital Camera
My vivitar 283 flash won't turn on. I checked the
Check the contacts for the battery to make sure they are clean and shiny. Then insert 4 brand new AA batteries observing the correct polarity and try again. Also check your users manual to be sure all of your setting and connection to your camera is correct.
I hope this was a help to you and good luck!
Nov 13, 2009 | Vivitar 283 Flash
Cannot find batteries that work. I have replaced the batteries with different brands and it still wont turn on. What is the problem.... Its not reliable.
It is possible that there is a small amount of corrosion on the contacts in the camera. Use the eraser end of a common pencil to clean these contacts. Also, make sure you are using the correct batteries. It shows here that you have the polaroid i830. this camera uses two AA batteries: Open the battery door, located on the underside of the camera (use your thumb to slide the door outwards). Install the two AA batteries into the battery bay. Install the SD card into the slot located next to the battery bay. Close the battery door.
  1. Step2Press the power button located on top of the camera. Locate the "Playback" button on the rear of the camera, under the "W" button; this button switches the camera between "Capture" and "Playback" modes. Set the camera to "Capture" mode.
  2. Step3Press the button on the bottom right of the rear of the camera to open the mode selection window. Use the navigation buttons to select "Still Image" mode. Press the button labeled "Set Disp" to confirm your selection.
Nov 02, 2009 | Polaroid i830 Digital Camera
I don't know how to turn it on, insert the card properly, use the DV disc that came with the product all basic insturctions!
The battery has to be charged for a couple of hours, first.
If you camera uses AA batteries, use new alkaline batteries (not Li-Ion or "Heavy Duty").... be certain of the correct polarity when inserting batteries into camera.
What kind of camera is it? brand & model, please ...
Sep 20, 2009 | Cameras
Camera shuts itself immediately after starting it
Did you try using the coolpix batteries that came along with the camera? check the ratings on coolpix batteries and compare them to the batteries that you are using now.
Mar 23, 2009 | Nikon COOLPIX L10 Digital Camera
Camera keeps shutting off.
Please use Sony Cyber-shot batteries for DSC-H2 model camera.
Nov 18, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
The camera we purchased won't take more than 4 0r5 pictures before it says low battery and won't take more pictures. recentlu when we put in new batteries it says low battery.
You did not say what kind of batteries you are using. If they are AA rechargeables they need to be recharged if they havenot neen used for a while. Say if you took 4 or 5 pictures, the batteries died, you charged them but did on use the camera again for several weeks. When you do they will be dead again, that in the nature of rechargables, they lose charge just sitting there. Solution find the Sanyo Enteloop or Rayovac Hybrid brands, these next generation rechargables have a shelf life similar to NiCads.
Jul 23, 2008 | Samsung Cameras
Batteries
Are you using alkaline batteries? If so, consider rechargeable NiMH AA batteries instead. Digital cameras are notorious alkaline battery eaters. By comparison, modern NiMH rechargeable batteries will last much longer per use/charge than ANY alkaline battery (up to 5 times longer). If you don't have them, get them, you won't regret it. Look for a power rating on the package of at least 2,500 mah.
Jan 01, 2008 | Canon PowerShot A560 Digital Camera
Kodak EasyShare C180 Digital Camera Logo
114 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
