Question about Bose Lifestyle 28 System
Image quality on tv
I have just purchased the lifestyle v 20 system and installed it correctly however it now seems as if the tv image is not as clear as it was before. Could this be caused from running the cables through the bose system?
    Scholar:
  • 70 Answers
This is always a possibility. Check specs for all devices involved. Things like impedance, frequency respnses (not audio), and reactances affect picture quality. Another thing people don't realize is plugging a cable with gold contacts on a receiver that uses normal metal contacts is the absolute wrong thing to do. (forget about what the "experts" say). When two different metals are connected to each other there is what is called capacitive reactance between them. This is Mother Nature and and not a darn thing we can do about.
Another to consider ( and again I disagree with the "experts") is anyt time you add another piece of electronics into the chain, additional noise is introduced. Every device produces noise, just look at the specs. The better (and more expensive) a device is the less noise it introduces (better conponents are uses, and tolerances are smaller).
FYI-why can I go agains the "experts". Because I was an analog technician long before I became a digital tek back in the 60's. Usually the only part of a device that is analog anymore is the power supply and in some cases the DAC-ADC device (digital to analog, anaolg to digital).
Hope this helps at little.
Jeff
Posted on Jan 01, 2008
Bose Lifestyle V35, sound but no image.
Thank you so much the unplug the power from the system worked after hours of trying other stuff
Huge thank you
Aug 14, 2012 | Bose Lifestyle V35 Theater System
Tip
Bose Lifestyle 20 Manual Download
Download Bose Lifestyle 20 Audio System Manual
Would you like to review the features of the Bose Lifestyle 20 Audio System?
Have you lost your Bose Lifestyle 20 Audio System Owners Manual?
Would you like a digital, searchable, pdf version of the Bose Lifestyle 20 Audio System Users Guide?
Follow this link (& click FREE) to download a pdf version of the Bose Lifestyle 20 Audio System documentation.
I hope that helps.
___________________________________________
on Jul 03, 2010 | Bose Lifestyle 20 System
How to connect pc to bose lifestyle 38
Method 1 (easy): you'll need to get a 3.5mm to RCA audio cable pictured here: http://www.daydeal.com/files/images3/blk_rca_cable.jpg plug the 3.5mm end into the computer's speaker/headphone jack and the RCA (red&white) end into the lifestyle 38.
Method 2 (harder): You can purchase and install a PC sound card that has an optical out option and also an optical cable. Then you can use the lifestyle optical out jack. This is a digital connection so the sound quality is better and better suited for the 5.1 channel that the Lifestyle 38 has.
Mar 01, 2011 | Televison & Video
I try to plug apple TV to my Bose sytem lifestyle 20. The apple TV is plugged by hdmi on my TV (hdmi2). The apple tv image is good but the sound is coming from my tv not from my bose system. i decided to...
You might want to try connecting the Apple TV to your TV using HDMI, then using the optical cable from your TV to your Bose system. In your TV's settings, there should be an Audio Output option. You'll want to turn off the TV speakers. Optical audio can be a little strange compared to traditional analog. If your cord is going bad, it could result in behavior like you described.
Jan 24, 2011 | Bose Lifestyle 30 System
Hi, I have a Bose Lifestyle 8 systesm, a Sony PS3 and a Sony KDL46HX800 3D LED LCD TV. I want to run the sound through the Bose speakers. What is the best way to connect the devices this? Also,...
Use this cable http://www.amazon.com/PlayStation-3-Component-AV-Cable/dp/B000MIXFWA
the 3 connectors for the video will go to the tv (you will not see any difference in the quality of the image compared to an HDMI, it's a very good quality cable) and the 2 audio ones to the Bose. You will probably need a audio RCA extension cable to reach the Bose - a $15 cable, thick enough, will be just fine.
No , there is no difference, unless of course you buy the absolute cheapest $5 cable. A $15 to 20 cable will give you the exact same image as a $150 to 200 one.
Dec 19, 2010 | Televison & Video
Image quality problem
Check the power supply part no. matching. If there is adjustment potentiometer for the supply voltages try adjusting to the required level of the voltage.
Apr 30, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
Pink and green colours seem to be too vibrant when watching dvd's on lifestyle 48
I have a Lifestyle 48 which suddenly started producing a pink and green image when playing DVDs (regular TV was fine.) After speaking with Bose support, I did the following which resolved the problem:
1. Removed power from the video switcher. (or from the bose itself if you don't use the switcher.)
2. Reattach all the video cables on the back of the bose and ensure all connections to the TV and switcher (if applicable) are tight.
After performing these steps, my DVD image went back to normal. I suspect it was a loose cable in the end, but no harm in performing the power disconnect.
Apr 11, 2010 | Bose Lifestyle 35 System
PS3 to Bose Lifestyle 28
hey, this is how i have mine set up.
Bose to PS3 via Digital Audio Optical
PS3 to TV via HDMI
This way you can get Full 5.1 surround sound, and good picture quality, also, go to the bose menu and set the optical source to your PS3.
Jan 29, 2010 | Bose Lifestyle 28 System
I have v 20 Bose system all HDMI connections I
Did you find a solution ? I have latest Sharp LCD and Sharp BluRay and separate Video&DVD player - would you recommend purchasing the V20 ? Is the quality good ?
Dec 08, 2009 | Bose Lifestyle V20 System - black Theater...
Bose Lifestyle 20 very Dim display
There are instructions available at www.AnyoneCanFixIt.com that has detailed pictures of this repair, step by step.
Jun 23, 2009 | Bose Lifestyle 20 System
Bose Lifestyle 28 System Logo
57 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
