Question about Magnum OmegaForce S45 CB Radio
Wiring a mic
I have a 6 pin old delta force mic which wont work on the omega s45 magnumthe colour and pins they are on are-
1-white
2-black
3-red
4-blue
5-ground
6-brown
would you know the correct wiring for the s45 omega
thankyou
les
  • Anonymous Mar 15, 2014
    some cut the wires to my stereo they are thick blue thin blue thick white green/yellow i have new stereo but when wired up it works ok till i drive then when i stop car wont lock and clock etc stays on till i unplug stereo
  • 204 Answers
The Delta Force and Omega Force are wired the same way, so if the mic is not working on the radio, check the mic out to make sure it's working. Make sure you have the mic gain turned up on the radio. I assume the mic was not wired for another style of radio??
Posted on Jan 13, 2008
  • Mechanic688
    Mechanic688 Jan 18, 2008
    Just a little more info if you want to wire another mic to your radio, here is the pin-out.
    1- Mic audio
    2- Receive
    3-Transmit
    4-up/down channel
    5-Ground/shield
    6-13.6 volt
    For an aftermarket mic all you need is Pin 1 - 3 - 5.
    your radio will receive without a mic.
    Hope this helps,, Mechanic
Wiring for 6 pin oricom mic plug
I too have an Oricom 6 pin mic with wires broken pin 1 is white, 2 is black and 5 is screen, this does not match any of the above answers and the green blue & red are off with 2, 3, 4, & 6 available
Kevin H
Jun 03, 2013 | Radio Communications
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
How do i wire a d104 desk mic to a madison base radio
You don't mention if the Madison is a 4 pin or 5 pin also you don't mention if the D104 is a 4 wire or a 6 wire microphone so this will be rather lengthly of an answer so if I help you could you atleast do the rating for me ? So here goes 4 pin / 4 wire 1]SHIELD 2] WHITE 3] RED 4] BLACK....O.K. 4 pin 6 wire 1]SHIELD & BLUE 2] WHITE 3] RED 4] BLACK YELLOW NO CONNECTION.....Are you with me so far ? Half over 5 pin 4 wire 1] WHITE 2]SHIELD 3] BLACK 4]N/C 5] RED.....5 pin 6 wire 1] WHITE 2] SHIELD&BLUE 3] BLACK 4]N/C 5] RED.I hope this helps you GOOD LUCK and have a good day Dan.
Jul 12, 2009 | Magnum DeltaForce CB Radio
Explaihow to wire a turner +3 mic to a president washington base
Here you go 1/shield 2/white 3/black 4/red . Good luck......Dan
Apr 28, 2009 | Magnum DeltaForce CB Radio
Omegaforce s45 mic wiring
Sadelta
1-Shield - Ground
2-White - Audio
3-Brown - Transmit
4-Green - Receive
Does this color code look like what you have in your mic?? sorry for the delay,,, Mechanic
May 09, 2008 | Magnum OmegaForce S45 CB Radio
Mic wiring diagram
Same as Omega
#1 Mic Audio
#2 Receive
#3 Transmit
#4 Up/Down for channels
#5 Ground/Shield
#6 13 volt
Jan 13, 2008 | Magnum DeltaForce CB Radio
Mic wiring
Check this link http://www.cbtricks.com/radios/rflimited/omegaforce_s45/index.htmand download the pdf file Owners manual page 8 has the info you need...Chia
Dec 22, 2007 | Magnum OmegaForce S45 CB Radio
Radio Communications Logo
462 people viewed this question
Top Magnum Radio Communications Experts
Jim Goldsmith
Jim Goldsmith
James Walker
James Walker
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
