CD's Can you still buy CD Audio and DTS discs? - only the discs I have purchased that say for data/photo/audio give an error ' DATA DISC' in my machine
    Guru:
  • 1,894 Answers
Wi not. you get audio discs and DTS discs in may music worlds.
many of the players from SONY show tis problem. the dont play lot of CD formats.
so better use AUDIO CDs and DTS CDs...
Posted on Dec 23, 2007
Says NO AUDIO and I have replaced the disk with several other CD-R
it sounds as if the disc was recorded as a data disc cd instead of a audio cd play the disc on a computer to check it
Dec 20, 2012 | Harman Kardon CDR30 2-Disc CD Recorder
Placing good cd-r disc for recording shows "insert
u mabe inserting the wrong disc all phillips cd recorders uses cd-r or cd-rw that says digital audio.
Jul 28, 2011 | Philips CDR785 3-Disc CD Recorder
Toc error 14
On questions like this it would help if we knew the manual was or was not consulted.
And if it was NOT, why.
C14 / TOC Error The unit did not read the TOC information. Insert other discs.
http://www.cdrfaq.org/faq02.html#S2-19
[Extract]
"If you write data to a disc and leave the session open, the TOC -- which tells the CD player or CD-ROM drive where the tracks are -- is written into a separate area called the Program Memory Area, or PMA. CD recorders are the only devices that know to look at the PMA, which is why you can't see data in an open session on a standard playback device. CD players won't find any audio tracks, and CD-ROM drives won't see a data track. When the session is finalized, the TOC is written in the lead-in area, enabling other devices to recognize the disc.
(Something to try: write an audio track to a blank CD, and leave the session open. Put the disc in a CD player. Some players will deny the existence of the disc, some will spin the disc up to an incredible speed and won't even brake the spindle when you eject the disc, others will perform equally random acts. The TOC is important!)"
Mar 02, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Sony RCD-500C I get a data disc message when pressing record
It wants a CD-R Audio or CD-R Music blank disc to record on. It won't record on CD-R data discs.
Feb 28, 2010 | Sony RCD-W500C 5-Disc CD Recorder
When I put a audio disc in my cd player. I get on
this is a error code for can't read disc or bad lens. what you need to do first is try a cd cleaner in it first and then if not you will need to have it repaired because the lens can't read data.
hope you get it going with the cleaner! good luck
Nov 03, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I have been attempting to burn a cd from my itunes library, it keeps giving me an error 2630. Yes I am using a new blank cd.
What type of CD media does your burner support? CD+R CD-R, CD-RW.
A few suggestions:
CD-RW or re-writables do not support audio burning to CD format.
Are songs being burned as a data disc(unplayable files) or CD audio?
Have you exceeded the 700 to 800 MB range of data that a CD can hold?
Try dropping a couple of songs off the list and see what happens.
Try rebooting the computer and try burning again.
Down load a free version of Nero software and try to burn the CD from there.
Oct 13, 2009 | HP HewlettPackard Pavilion ZE5400 series:...
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
I get a "Data Disc" message when I press record.
have you purchased the correct blank discs? sounds like you've inserted discs that can only be used on a PC. these players can only record onto blanks bearing the "compact disc digital audio" mark. these are for use on home audio recorders. hope this helps?
May 02, 2009 | Sony RCD-W500C 5-Disc CD Recorder
Rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
conditions.
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Oct 17, 2007 | Blaupunkt RPD 552 CD Player
199 people viewed this question
 Grubhead
Grubhead
