Question about Garden
I can get the motor to start but it idles rough and does not get to full throttle before shutting itself off. Also very little water pressure coming out of gun at highest throttle speed when it does run very briefly.
  • 20 Answers
You need to probibly just clean out the carb.
Posted on Oct 06, 2009
Husqvarna 125 BV how to adjust carb screws, yes I can turn them but how to start all the way in on both screws
I would think that the screws have limiter caps, so you cannot turn them all the way in.
1) put both screws at the maximum you can turn them out
2) start and warm up the engine
3) at idle speed, turn the L needle in till the engine speeds up (by itself) and then starts to lower rpms.
4) from that point, turn the L needle back out till engine raises and then lowers. Leave the screw in a setting that the engine sounds a little rough
5) use the same procedure with the H screw (at full throttle)
6) now throttle up from idle
does the engine pick up quickly? settings are good
does the engine stumble and then finally begin to pick up?
Then turn the H out about 1/4 turn. If needed for rough but smooth running, turn the H out again another 1/4 turn.
*Please Note: 2cycle engines should ALWAYS sound just a little rough at full rpms. NEVER adjust a carburetor so that the engine 'screams', you will not have an engine for very long at that condition.
Feb 02, 2017 | Husqvarna 125bvx Hand Held Blower Vac
Rough idle, bogs when I give it throttle then dies
Brad:
Go back to the carburetor adjustment screws and snug them down gently. Do not use force on those screws or you'll damage the needle valve seats. Turn both screws out one and a quarter turns out and start the saw. The motor should stay running.... if not adjust the screws until it stays running. Turn one screw in until you hear the motor start to stall, then turn that screw out just a little bit. turn the other screw in until the saw starts to stall, then turn that screw out a little bit. Now if the saw bogs at full throttle, turn one screw out one quarter turn. See if the saw runs at full throttle... if not turn that same screw in to where it was and try the other screw the same way. If you're good, you can adjust the screw while the saw is running to get the best full throttle run. This is not an exact science, and it takes time and many adjustments to get the saw to idle and run at full throttle. Good luck... and have patience.
Oct 03, 2015 | Garden
'87 Yamaha ProV 50: Will cold start and idle well. After a full throttle 1-2 min run will begin & continue running very rough near idle. Will die without addtl throttle imput.
Hi Roderick:
I'm not familiar with your engine configuration, but on some of the older bikes, vibration eventually can cause a wire to break in the coil. When the engine is cold, the wires make contact and it runs, but as soon as it gets hot, the connection is broken or compromised and the spark quits or drives you crazy.
Since your bike runs when cold and quits when hot, I'd be looking for electrical rather than fuel problems.
Hope this helps.
Sep 09, 2015 | Yamaha Motorcycles
Why are so many trouble diagnostic codes being thrown
sounds like you speed sensor and your throttle poistion sensor
Sep 02, 2014 | Cars & Trucks
Starts with starting fluid runs for a few seconds then shuts down
Good test. Do not keep doing that.
Make a new and accurate gas/oil mixture. Empty and refill. Secure cap. Be sure to flood system during start attempt. Can you smell gas? Oops, too much, better wait 30 seconds for full evaporation.
Two little screws near carb. Both are actually needles and probably have a visible spring which keeps them from vibrating to a new position while in use. One fuel/air mixture at low idle (start). One fuel/air mixture at high RPM.
Try 1 1/2 full turns open from fully closed. Once to get it to idle roughly, adjust to a smooth idle. Do the same at full throttle. You will notice that the more you shut the full throttle down, the higher the RPM will go (assuming that it is near correct). Do not run it to lean. The mechanics of the motor needs the oil from the gas.
Smile always.
Jun 03, 2011 | Garden
Vstar 1100 idling rough and backfiring letting off the throttle
It sounds to me that your carbs might be a little gunked up - you mentioned the gas may have been old, so it's possible that the smaller (idle) jets are slightly plugged up. Fresh fuel might do the trick and/or you could try using a fuel system cleaner and water remover. This problem might 'solve itself' with a little time.
As far as the backfire - this might be either from the carb issue or it could be related to that rattle you mentioned - you could have a loose connection at or near the head - this can **** air and cause a backfire.
I hope this helped!
Jun 09, 2010 | 2003 Yamaha V Star 1100 Classic
Motor would not shut off and radiator fluid shooting out.
cable pulled out of carb top and pulled throttle open. on top of this water pump stuck open and thermasat did not open. Unless water jacket is cracked. Motor went into deseiling and thats why it would not shut down with kill switch
Mar 05, 2010 | 2002 Honda CR 250 R
2005 Jeep wrangler w/rough idle and hesitates when you accelerate
try fuel injectors....run a bottle or two with full tank through it and see if that dont solve the problemo.....
Feb 01, 2009 | 2005 Jeep Wrangler
94 blazer vortec 4.3 idle revs up and dont come down
check your Throttle Positioning sensor that should fix your rough idle the TPS controls the breather on the front of the engine its affixed to the right hand side of the throttle body just infront of the spyder on the V6 Vortec 4.3L Models
Nov 09, 2008 | 1994 Chevrolet S-10 Blazer
Garden Logo
77 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
