Problem with General Electric GE 24-Hour Timer, 2-Pin #15004
GE 24 hour programmable basic timer - how do i push the keys down. is there a diagram? I tried and tried.
<br />
The product is the Basic Time.. no pin. #15119
Posted by avatar on Oct 06, 2009
Solutions (4)
Best Solution
So, this timer came with no instructions. What do you want for $3.99. Made cheap in China and instructions cost more than the timer.
The timer has a dial with tabs all around the 24 hour clock. They are in the down position which is on. You must pull all the tabs up in the times you want the timer off. This is different from all the other timers I have that used that have two removable tabs that are placed at the start and end times.
Put the switch on the side of the timer in the timer position.
  • By Author imageedge9 Dec 14, 2009
    • By avatarJeffrey Mayo Nov 29, 2011
    • Thank you. I never would have thought to pull almost all of the tabs for light to be off.
The unit comes with the buttons already pushed down. You have to pop them up.
what is the different between "Timer On" and "Outlet On" on the timer?
problem solved by returning the timer. thank you.
  • By Author imageslui619 Oct 07, 2009
Add Your Solution
See all General Electric GE 24-Hour Timer, 2-Pin #15004 Problems
