Question about Harman Kardon FL8385 5-Disc CD Changer
I get an error signal ''E'' and the carousel (5 disc cd changer) won't turn until it is turned off and on several times. If I can fix it myself, that would be great, otherwise, perhaps you can suggest a good repair shop in the Los Angeles or S. Cal area. The CD changer is the Harman Kardon TL8500/TL8600
  • 382 Answers
They all have belt problems after 6+ years. Take it apart and replace the worn out belts and you are good to go.
Posted on Jan 02, 2010
How do I fix my Sony cd player with 5 disc carousel changer in which the door keeps opening up? When I close the door the carousel moves around a bit but then the door opens up again.
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
I have a Sony mini hifi stereo(pixy) and when ever I close the tray it continues to ... my cd player drawer opens ...
ToddFun.com: Repairing a 5 disk CD player - YouTube
? 10:09
https://www.youtube.com/watch?v=aKE1CbHOBVo
Nov 23, 2011 - Uploaded by Todd Harrison
ToddFun.com: Repairing a 5 disk CD player ... Sony CDP-CX300 300 Disc Changer Belt Repair and ...
Jan 01, 2016 | Sony Audio Players & Recorders
Troubleshoot cd changer
Unfortunately, you have to remove the screws that hold the top cover on the player, unless you can remove the ones still in place one at a time through the door. If you can remove all the ones still in position, you might be able to get the remaining ones by flipping the player over.
Jun 01, 2014 | Sony RCD-W500C 5-Disc CD Recorder
Carousel will not turn
Could be a broken/loose carousel belt. take the cover off and look near the back of the unit and make sure that both belts are on there respective pulleys.
Jan 02, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
I HAVE A 5 DISC CHANGER.......I PLUG IT IN, TURN ON POWER AND THEN PUSH OPEN. OPEN COMES UP ON THE SCREEN BUT THE TRAY DOES NOT OPEN. WILL NOT SKIP FROM ONE DISC TO ANOTHER EITHER???????? ANY...
The 5 disc carousel CD player has a belt driven mechanism in it. And after about 3-4 years the belt looses its tension and cannot push the tray in or out. If you keep your ears on the top cover and turn on the system you will hear a whirring sound coming from the inside which will prove my point.
There are two belts in the machine. One for the eject mechanism and the other for disc change mechanism. One has to seek professional help to replace both because there is timing sequence also involved like the cam shaft of an engine.
Mar 08, 2011 | JVC XL-F154BK 5-Disc CD Changer
How do I clean a 5 CD disc changer?
i think the concept of this type of machine is one actual disc reader (the eye needing the cleaning) and a carousel that carries discs to the play position. So a cd lens cleaner can be placed in any of the carousel parts and do as much good as in another, once should be enough.
Jan 31, 2010 | Panasonic SCAK410 5-Disc CD Changer
Jvc xl-f254 cd changer for home. 5 disc changer. Carousel will not slide out. makes humming noise, possibly trying to open.
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Jan 29, 2010 | JVC XL-F254BK 5-Disc CD Changer
Table Error--carousel will not turn
pull off changer cover, theres 9 screws .looking from the front of the changer, look to left side,thats where there are belts for drive mech. the back one is for the carosel, it might of broke or came off. had the same problem belt came off. works good as new. hope it solves your problem
Nov 27, 2009 | Sony CDP-CX400 400-Disc CD Changer
Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Oct 27, 2009 | Teac Audio Players & Recorders
Chevy Equinox 5 disc cd changer. Car battery died which cycled cd changer several times. Now it just gives cd error message and I cant get the lone cd out and I cannot load a cd.
make sure your alltanator is chargeing from the battery,how you can do that start the car open the hood and take one of the batter cable if the car still run,that means the alltanator is good,if the can turn off when you take the
May 11, 2009 | Car Audio & Video
Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Jan 04, 2009 | Onkyo DX-C380 6-Disc CD Changer
Harman Kardon FL8385 5-Disc CD Changer Logo
397 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
