Question about Maytag Dryers
Dyer not getting hot - Maytag Dryers
  • Maytag Master
  • 7,482 Answers
Sounds like your problem is with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with a continuity meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
Good Luck,
Hope this helps
Posted on Oct 06, 2009
My dyer gets hot then it gets e64 then my dyer stops
It could be clogged vent or faulty sensor or thermostat control board Best way is check for clogged vent or any rust or cracked components and use step by step deduction method for trouble shooting
Dec 08, 2013 | Kenmore Dryers
DRYER VENT PIPE HOT TO TOUCH
there could be a blockage which is preventing the hot air from escaping
Aug 07, 2012 | Whirlpool Dryers
Dyer only blows cold air
U may have a blown thermostat or bad heating element.
Nov 14, 2011 | Dryers
Stackable dyer gets too hot in the back and i cannot find a filter
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 05, 2011 | Samsung DV316LGW Dryer
I have a Kenmore gas dyer that has developed a burning smell
check vent line,either check outside to see if flapper is blowing open or disconnect vent line from back of dryer and see if it helps.if not there are two thermostats Number: 660036 Substitution: 279048 and
Number: 3387134 ,this one is on blower wheel housing and the other is in the back,take back wall off and you'll see it on right hand side on heater vent duct
Nov 03, 2009 | Kenmore Dryers
Dyer not working
Most likely a faulty heating element or a blown thermal fuse. Both components can be tested using a multimeter. Test for continuity. A lack of resistance indicates a bad component. The thermal fuse located just inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long. If it has no continuity, the thermal fuse is blown. Hope this helped and best wishes.
Aug 07, 2009 | Amana ALG331RAW Gas Dryer
My dyer does not get hot.
change your high temp thermostat,remove back panel and it's on your right bottom of box-mike
Jul 16, 2009 | Kenmore 63942 Dryer
Dyer won't get hot,
if it is heating at all you can check your vent going out to see if its stopped up
Apr 24, 2009 | Washing Machines
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
