Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture, standby light blinking
When turning on the tv, the picture does not turn on, there is a click then the stand by light blinks three times. I realize 3 times means an over voltage problem. My biggest problem now is somenoe telling me if its worth fixing or is it worth the $40 the local service center wants just to look at the tv before I find out how much then to fix it if at all?
  • Anonymous Jan 30, 2008
    Same problem. Not sure what to do.
    same thing here...problem just started today.
  • 21 Answers
MOST LIKELY THE ERROR 3 IS THE 200V LINE TO THE CRT DRIVE IC.IC702. ON THE CRT PC BOARD. IT ALSO COULD HAVE GONE OUT IF YOU HAVE HEAVY USAGE ON THE SET 8-12 HRS A DAY. THE CTR COULD SHOT AND TAKE OUT THE I.C. AS FOR IS IT WORTH FIXING, THEY DON'T MAKE CRT TV'S ANY MORE AND THE NEW SETS SEEM TO HAVE A LOT OF PROBLEMS.
DON..
Posted on Jan 31, 2008
The stand by power lite is steady until you try to turn the tv on, When the tv is powered up, the standby light blinks 6 times, the tv then turn off. no picture or normal sound. what do the six blink codes...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Mar 11, 2015 | Hisense 32K20DW 32" 720p 60Hz LED Smart...
My standby light blinks three times but tv never comes on
These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/.If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 22, 2013 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
My LG 42PQ3000 is making a clicking noise from the large PCB when power is turned on, there is no picture and the stand by light is going on and off
Standby light goin On/Off, means the power supply regulator board is OK. Blinking of the standby light indicates a fault. It might be to the backlight inverter board, or the main board. These blinks of standby light are called blinking codes, from the number of blinks occur at one time switch ON, you can get an idea about the faulty board inside the TV. Count this blinks. If you wish to get more details about these blinking codes, check the site linked here.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 22, 2013 | LG 42PQ3000 42" HDTV Plasma TV
Was watching TV, heard a pop and the screeen went black. Now when I turn it on, the pwoer light blinks green but their is no picture or audio. The light then starts blinking red
Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info.
It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem.
Hope this will help.
Thanks.
Mar 09, 2011 | Sony KDS-50A2020 Television
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
TV turns off but standby still blinking
Hello
Blinking of standby light in Sony sets are fault indications. Just count the number of blinks occur at a time, after switch OFF and switch ON your TV with its FRONT PANEL POWER CONTRO SWITCH. Make this test at least three times, and count the number of blinks keenly and inform me though Fixya. It will help me a great to rach to the faulty section, or even to the exact fault point sometimes. OK.
Feb 17, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
I have Sony 40inch breviary. My tv is not turning on I reset tv but it still not working. Stand by light keep blinking but tv is not turning
Hello
Blinking of standby light in Sony telivisions are fault indications. You just count the number of blinks occur at a time when the set is switched On with its FRONT PANEL POWER SWITCH. Count it three or more times, and make sure about its number of blinks and inform me through Fixya. From that number, I can get into the fault section, sometimes more accurate to the location of the fault. Count it Keenly for at least three times and make sure before reporting. OK.
Jan 18, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
KV-40XBR700, won't come on, standby light blinks 7 times.
sony KV40XBR700 tv no picture but sound is on, standby light blinks 6 times
Jul 20, 2009 | Sony KV-40XBR700 40" TV
Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Dec 22, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
171 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
